Panel Pilot Bit For Window Cutouts - Tools & Equipment - Contractor Talk
Old 09-27-2018, 08:54 PM   #1
Lettusbee's Avatar
Rewards Points: 1,910
I've not had good luck with Routering out wall sheathing for windows.
Problem might be with my no name bit.
Can I get a recommendation please.
Lettusbee is online now
Old 09-27-2018, 09:06 PM   #2
Tom M's Avatar
Rewards Points: 172
Re: Panel Pilot Bit For Window Cutouts
Search the framing thread. I remember this conversation. I forget the verdict. I think it was loneframer
Tom M is online now
Lettusbee (09-27-2018)
Old 09-27-2018, 09:27 PM   #3
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 84
https://www.toolnut.com/bosch-85601m...-trim-bit.html
Big Johnson is online now
Old 09-27-2018, 10:13 PM   #4
META's Avatar
Trade: General and Trades
Rewards Points: 56
We can knock out the cuts quicker with circ saw. I've used a large router bit, but don't hit a random nail...
META is offline
Old 09-27-2018, 10:23 PM   #5
Rewards Points: 84
Routers do a nice job but they have to be plugged in and it seems the wind always favors plastering me with OSB shavings.
I like a cordless recip with a demo blade. Clean cut, fast, no cords and not much mess.
Old 09-27-2018, 10:55 PM   #6
GC/carpenter
Calidecks's Avatar
Rewards Points: 102
Use anything with a vac port.
Mike.
_______________
Calidecks is offline
Old 09-28-2018, 12:38 AM   #7
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,562
I always used a router, i think the last one was freud. It might not be as fast as a circ saw, but It's pretty close and the cut doesn't leave rough edges which I like because I installed the windows.
Airdrie AB Renovation Contractor | Kitchen Renovations | Basement Developments | Facebook
JT Wood Construction Serves Airdrie, Cochrane, Olds, Mountainview, Rockyview and Crossfield, Alberta.
JT Wood is offline
Old 09-28-2018, 12:40 AM   #8
GC/carpenter
Calidecks's Avatar
Rewards Points: 102
Whiteside makes some great router bits.
Mike.
_______________
Old 09-28-2018, 06:02 AM   #9
Tom M's Avatar
Rewards Points: 172
I don't use them but I thought the sentiment was more power and a smaller bit. Less friction with the glues. I think this would be a good one.
https://www.acmetools.com/shop/tools...hoCPjYQAvD_BwE
Tom M is online now
Old 09-28-2018, 06:29 AM   #10
Rewards Points: 84
The smaller the bit the faster it heats up. The more it heats up, the more it dulls.
META (09-28-2018)
Old 09-28-2018, 06:32 AM   #11
Tom M's Avatar
Rewards Points: 172
So maybe a downcut spiral bit is less stressful than flutes
Tom M is online now
Old 09-28-2018, 10:26 AM   #12
GC/carpenter
Calidecks's Avatar
Rewards Points: 102
Yep solid carbide.
Mike.
_______________
Old 09-28-2018, 12:35 PM   #13
Rewards Points: 84
The one I listed I used to get 2 houses worth of windows out of plus a bunch of odds and ends cutting. The weak point is the bearings. They blow apart when the bit is still fairly sharp. Key is to get the ones with 2 bearings. Single bearing set ups donít last as long.
Shower glass panel isnít perpendicular to the curb RookiePlumber Kitchens & Baths 20 11-04-2017 07:05 AM
New main panel or sub panel? Gregavi Electrical 21 03-09-2015 05:39 PM
Help with new panel problems cwatbay Electrical 10 03-18-2013 05:31 PM
