Oxygen Acetylene Settings - Tools & Equipment - Contractor Talk
Old 03-18-2014, 08:19 PM   #1
MJconstruction's Avatar
Rewards Points: 151
I tried searching for threads and came up with nothing so I'm trying here. I have to dismantle a air handler this week and generally stick to commercial carpentry but I'll have to use a torch to cut it up. I have used torches before but have never had to set the regulators. I have read all over different numbers and my buddy told me 7 for acetylene and 11 for oxygen. Then I read almost 40 for oxygen and ten for acetylene. Anyone have some advice for what you have your regulators set at. And any tips would be much appreciated.
MJconstruction is offline
Old 03-18-2014, 08:43 PM   #2
tgeb's Avatar
Rewards Points: 456
Re: Oxygen Acetylene Settings
Try a look at this, there is a chart a little ways down the web page.
http://weldingweb.com/showthread.php...ator-pressures
I don't have a lot of experience with cutting and welding either, I just adjust the flame till it looks pretty, and hope for the best.
From my brief read of the link, having a properly sized torch set up can effect the production.
www.gebcon.com
tgeb is online now
Old 03-18-2014, 08:46 PM   #3
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
^^^^ what Tom said
That's a great forum with a lot of good info on all aspects of welding/cutting.
-Steve
TimelessQuality is offline
The Following User Says Thank You to TimelessQuality For This Useful Post:
tgeb (03-18-2014)
Old 03-18-2014, 09:22 PM   #4
HUI's Avatar
Trade: Utility, sitework, and erosion control contractor
Rewards Points: 178
I was told when I was in school it is when you start in the am. 7 and 30
HUI is offline
Old 03-18-2014, 09:33 PM   #5
Anti-wingnut's Avatar
Rewards Points: 3,428
I was taught 7 and 25
Anti-wingnut is offline
Old 03-18-2014, 09:37 PM   #6
HUI's Avatar
Rewards Points: 178
I usually turn it all up when I'm using a rose bud. But any of those numbers seem to be a good starting point
HUI is offline
Old 03-18-2014, 09:43 PM   #7
Don't exceed 15 psi or you could cause an explosion
Old 03-18-2014, 09:48 PM   #8
tnt9324's Avatar
Trade: Excavation, Natural gas service work
It really depends on what you are cutting. I've spent many hours behind a torch and what I have found to work the best is start at 5 and 10 psi and go up from there. That's a good setting for smaller gauge metal. Anything larger just slowly increase the pressures. There is no exact pressure you have to be at. One thing I will say for sure that if you are heating a piece and it seems like it is taking a long time for it to become molten, increase your acetylene, then increase your oxygen accordingly. Just experiment with it. You'll get the hang of it quick!
tnt9324 is offline
The Following User Says Thank You to tnt9324 For This Useful Post:
tgeb (03-18-2014)
Old 03-18-2014, 11:21 PM   #9
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,754
As Anti-wing nut said, don't exceed 15psi on the acetylene side. When you open the tanks, open the oxygen all the way, but only crack the acetylene. 1 turn max. I usually go no more than 1/2 or 3/4.
Acetylene is very unstable, and can explode. I usually keep the acetylene regulator set below 10psi, and never go above 12psi. The 15psi Anyi-wing it mentioned seems about right for maximum safe working pressure.
Acetylene is unstable above 15 psi. It is dissolved in acetone and the cylinders are filled with a porous material to keep the gas stable at the 1700 or so psi that they are pressurized to. It can also become unstable if the tank is emptied too fast, such as when using a rosebud tip with a small tank, even if the pressure is below the limit. Never withdraw more than 1/15 of the volume of the tank per hour if using continuously, or 1/10 intermittent.
Also remember that oxygen can also be a dangerous gas. Never use it to blow off you clothes or anything else. It can cause spontaneous combustion. My dad worked on an oil rig in the late 60's, early 70's. One of the guys used the oxygen tank to blow off his coveralls after work and went inside to his quarters. When he sat down and lit a cigarette he went up on flames!
Rustbucket is online now
Old 03-19-2014, 05:31 AM   #10
Rewards Points: 151
Thanks for all the advice I'll see how it goes today I am going to start at 5 and 25 it's mostly light metal.
Old 03-19-2014, 09:20 PM   #11
pritch's Avatar
Trade: superintendent
Rewards Points: 691
Remember to always keep the acetylene tank standing upright, too! If you do have to lay it on it's side for whatever reason, stand it upright for at least a half-hour or so before using it.
My dad gave me concrete tools for my 18th birthday. 37 years later and I still haven't come up with a mean enough way to get him back.
pritch is offline
Old 03-19-2014, 10:10 PM   #12
I've used them laying down a few times...
Can you share why that's wrong?
-Steve
Old 03-20-2014, 06:22 AM   #13
HUI's Avatar
Rewards Points: 178
As long as the axcelyne tank is up right a little you should be ok. If it is laid down too far you will acetone in your regulators
HUI is offline
The Following User Says Thank You to HUI For This Useful Post:
TimelessQuality (03-20-2014)
Old 06-08-2014, 03:05 PM   #14
tntframing's Avatar
Trade: carpentry
Rewards Points: 30
Right now I'm set a 30/ 8 on my rig.
tntframing is offline
Why is wood rotting ? SKC Construction 47 05-27-2018 04:50 PM
Settings for Milwaukee model 4910 paint sprayer Camyankee Tools & Equipment 0 08-14-2012 09:20 PM
lime application spreader settings dale rex Landscaping 0 07-21-2012 03:13 PM
Facebook Settings? DaVinciRemodel Marketing & Sales 16 01-24-2010 09:38 AM
