Oxy Tool Belt Suggestions - Tools & Equipment - Contractor Talk
Old 06-09-2020, 07:35 AM   #1
Nashorn101's Avatar
Trade: Handyman
Rewards Points: 64
I'm a young, individual contractor who does all kinds of work. Mainly trim work, or handyman type work inside of a house. I have yet to frame houses, even though I want to, and plan to.
When I first started, money was tight, so I've been wearing a set of those inexpensive, imported leather bags.
However, now I can treat myself and buy a set of those oxy's that I've always wanted.
May I get some recommendations? Please?
LEATHER V.S. NYLON:
Obviously, nylon bags will always be lighter than leather bags. That being said, leather bags aren't even much heavier than nylon bags. So, I know that I want leather.
BELT V.S. BELT WITH SUSPENDERS
I tried suspenders on my current tool belt setup, and got irritated real quick with them bunching up my shirt, and pulling on my shoulders every time I reached above my head. So, I'm pretty certain I do not want a suspender setup. Unless - a testament could be provided to suspenders reducing cumulative fatigue?
I'm really tempted to keep it simple, and just buy The ProFramer 5080DB. Basically what every career carpenter wears. $280.00 off of Amazon.
Any frank, and honest opinions?
Nashorn101 is offline
The Following User Says Thank You to Nashorn101 For This Useful Post:
wallmaxx (06-09-2020)
Old 06-09-2020, 11:35 AM   #2
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,410
Re: Oxy Tool Belt Suggestions
how much do you carry .the leather weighs more .what pockets do you like .
get diamond backs . they carry better .get the wide belt ,it distributes weight better .
totally my opinion from my exp . i carry everything i can .
JFM constr is online now
Old 06-09-2020, 11:58 AM   #3
Nashorn101's Avatar
Trade: Handyman
Rewards Points: 64
Indeed, the Diamondback Artisan is 4 lbs, 1/3 lighter than the Oxy 5080, at 5.4 lbs.
And, I specifically try to keep what I'm carrying to a minimum.
Have you tried Oxy's before? Do you obviously like your Diamondbacks more?
Sent from my E6910 using Tapatalk
Old 06-09-2020, 11:59 AM   #4
RichVT's Avatar
Rewards Points: 1,287
I don't think that too many of us would recommend a full framer set for inside work.
That being said, I do own the Oxy set pictured and do recommend it. I just don't wear it all the time.
Over time, I've added the Oxy suspenders and the hip pads. The biggest improvement that I made was to add some sex bolts to keep the bags from sliding out of place every time I took the belt on or off.
I'm of the opinion that leather will breath better than nylon. A wide nylon belt would just leave me with a wide sweat stain around my mid section. Maybe Diamond back has something on the inside to prevent that.
RichVT is offline
Old 06-09-2020, 12:16 PM   #5
Nashorn101's Avatar
Trade: Handyman
Rewards Points: 64
My current tool bags' are pretty similar to those Oxy's. And, indeed, you have to be careful with them inside a finished house.
That being said, I've tried a small-profile approach; Duluth pants with the detachable pockets. But found myself still throwing on my tool bags, throwing a hammer in the rear loop and just being mindful about where my bags swing.
If you bought Oxy's again, would you buy another style of Oxy's?
Old 06-09-2020, 01:53 PM   #6
JFM constr's Avatar
used the leather oxi set before diamond back .had that wide sheep skin belt ,loved the smell .
i went to diamond back for the pockets -i wanted tons .i was finish and trim .wanted many tools at my hands .in large houses where having the tool in my belt meant i was not walking all over trying to find it or cutting quality of work because i did not have the right tool .
generally the bags size was not an issue for me . though hammer could be problem . The diamond backs for me meant no more suspenders .
I had issue with all the hassle dropping or adding coats/shirts as temp changed .suspenders were a problem .
they maybe over 20yrs now .showing wear and not as stiff as they were .
The Following User Says Thank You to JFM constr For This Useful Post:
Nashorn101 (06-09-2020)
Old 06-09-2020, 06:43 PM   #7
Design Build
wallmaxx's Avatar
Trade: well....that was unpleasant
Rewards Points: 3,252
I used the free leather DeWalt bags for 21 years. No issues. No suspenders. I just recently bought the 7-bag oxy framer......because I can.
Oxy leather is very nice.
Youíre making the right move investing in quality gear. Enjoy whichever kit you go with.
Life - Liberty - Pursuit of Happiness
Freedom is a God-given right
2A is my personal guarantee
wallmaxx is offline
The Following User Says Thank You to wallmaxx For This Useful Post:
Old 06-10-2020, 07:47 AM   #8
RichVT's Avatar
I would probably get the same style but unless they get stolen, I don't think they will ever need replacement.
RichVT is offline
The Following User Says Thank You to RichVT For This Useful Post:
Nashorn101 (06-10-2020)
Old 06-10-2020, 03:27 PM   #9
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,498
I always thought the pro trimmer bags were pretty sexy. Designed for interior work. Leather. Maybe just enough for what you do.
sparehair is offline
The Following User Says Thank You to sparehair For This Useful Post:
Nashorn101 (06-11-2020)
Old 06-10-2020, 11:57 PM   #10
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,164
I bought Oxy Framers Nylon. Took it down to my local cobbler and had him remove bags and put them on the other side. I'm left handed but the left handed bags that Oxy sells isn't what I wanted. So I went custom.
Mike.
_______________
Calidecks is online now
Old 06-11-2020, 06:56 AM   #11
RichVT's Avatar
On my bags, the small pouch at belt level (where I keep my tape measure) was right in the middle making it hard to reach into the main pouch.
I took it off and moved it to one side using a speedy stitcher and some copper rivets to reattach it.
RichVT is offline
Old 06-24-2020, 05:52 PM   #12
ChuckEV509's Avatar
Trade: Laborer for General Contractor
You might look into Atlas 46. They have really customizable gear.
I used to wear a cheap pair of framer bags with clip on suspenders all the time, but the bulk was always getting hung up on ladders or studs. I got sick of them when I started framing more. A more quality set of bags would probably be better. As for suspenders causing your bags to lift your shirt and hold your shoulders downs, I find it helps to have the belt of the tool bags riding kinda high (above the waist of my pants)
Now I wear an old single bag that I found at a thrift store (double pouch with cats paw holder and hammer holster that I don't use) on one side, and I added a little dewalt pencil holder that holds pencils tape measure, chisel, knife, mini stringline (30' and it clips onto a pencil pocket). Plus I added a CLC hammer loop to be on my right side which I really prefer.
It's light enough that I ditched suspenders (lightweight tools helped that too, stilleto 14oz framer, mini stringline, plastic speed square, soon to get stilleto cats paw). Any other tools that I need, I put in a duffle tool bag. I've been working on having a duffle for each task (framing, concrete, roofing, siding, trim, demo). One friend of mine has his duffle tool bag on wheels for extra convenience. But I manage to make do with the basics, and the lightweight and slim setup lets me be like a ninja.
I think when I finally invest in new bags, I'll go for Atlas 46 and make a setup similar to what I have now.
ChuckEV509 is offline
Old 06-25-2020, 07:44 AM   #13
hoser's Avatar
Trade: General, Finish Carpentry, Cabinet Builder
Rewards Points: 128
I’ve been using the Occidental pro framer bags for a long time. Most the time I’m doing finish carpentry. They can get a little tight in closets and such, but I’m so used to them that I just naturally move my body a certain way or throw a hand in a pouch to keep it DP from swaying and I can slide through a 2-0 door without an issue, and that’s with my hammer hanginG on the side. Suspenders are definitely a must! I helped my brother in law frame for a bit and I took the suspenders off so I could take my shirt off in the summer and I instantly could feel it in my hips, hard to even walk after a few hours. I know for a fact the suspenders have helped me over the years. I also have the pouch with the phone holder attached to my suspenders, it looks a bit nerdy, but it really is handy, and it gives me a place for some extra tools. Leather is the way to go for sure. Try to find a different retailer other than Amazon to buy them from.
hoser is offline
Old 06-30-2020, 09:27 PM   #14
maxfederle89's Avatar
Trade: Seamless Gutter Company
Rewards Points: 100
I am a hardcore Occidental man. My current setup (actually only the second set I've bought brand new) is the Finisher nylon bags with a leather belt and traditional hammer holster. Great setup. I work for a reno company. From demo to trim. I wear these bags for nearly everything and load them up according to the job at hand. The only time I ditch them is for a little CLC let her belt with a bunch of individual tool holders. I wear it for heavy demo (hammer, knife, big cat's paw) or when I'm installing hardware in a finished space.
Sent from my Pixel 2 XL using Tapatalk
maxfederle89 is online now
Old 06-30-2020, 09:30 PM   #15
Rewards Points: 100
Originally Posted by hoser View Post
Iíve been using the Occidental pro framer bags for a long time. Most the time Iím doing finish carpentry. They can get a little tight in closets and such, but Iím so used to them that I just naturally move my body a certain way or throw a hand in a pouch to keep it DP from swaying and I can slide through a 2-0 door without an issue, and thatís with my hammer hanginG on the side. Suspenders are definitely a must! I helped my brother in law frame for a bit and I took the suspenders off so I could take my shirt off in the summer and I instantly could feel it in my hips, hard to even walk after a few hours. I know for a fact the suspenders have helped me over the years. I also have the pouch with the phone holder attached to my suspenders, it looks a bit nerdy, but it really is handy, and it gives me a place for some extra tools. Leather is the way to go for sure. Try to find a different retailer other than Amazon to buy them from.
You know, I used to be a suspender guy. I still have the Occi Strongholds. They are awesome, but in the last few years they just hang in the van. My body changed and they make my back hurt now. I'm not saying OP shouldn't get some kind of suspenders, I feel every guy should give them a try with their bags. The pursuit of comfort should be a top priority to be as efficient on the job site as possible.
The Following 2 Users Say Thank You to maxfederle89 For This Useful Post:
Calidecks (06-30-2020), hoser (06-30-2020)
Old 06-30-2020, 11:32 PM   #16
hoser's Avatar
Rewards Points: 128
I found that making sure they are adjusted properly makes a big difference. Regularly make sure that you have even weight on both shoulders and then make sure that your belt is tensioned properly. I find that having any of these things not properly adjusted can cause issues.
hoser is offline
The Following User Says Thank You to hoser For This Useful Post:
maxfederle89 (06-30-2020)
Old 07-01-2020, 01:24 AM   #17
Design Build
wallmaxx's Avatar
Being fiscally modest (cheap) I tried to integrate my old load bearing vest onto my spankin new leather occidentals.....uh.....FAIL.
1. Too hot
2. Too much nip friction
Ended up ordering the big sheepskin inner belt pad. That was awesome.....during the dry and cold. Rain or heat.....not so much.
Ordered the oxy suspenders. All is in balance now.
PS........the video says there are pre-drilled holes...............yeah............about that. Now I have their 2 holes and my 2 holes...............I always do that it seems.
wallmaxx is offline
maxfederle89 (07-03-2020)
Old 07-03-2020, 08:16 AM   #18
Rewards Points: 100
1. Too hot
https://www.youtube.com/watch?v=FEeLQwK2hps
I have the Occi inner belt too. I really like it but I wish the hammer was centered and the the two little straps on the front were spaced out a little more. But that thing is SUPER comfy. I'll probably get me some red leather from Tandy and redo the little straps a bit.
