Outside Lazer Level - Tools & Equipment - Contractor Talk
Outside Lazer Level
Old 12-12-2019, 01:35 PM   #1
shesbros's Avatar
Trade: Painting and Remodeling Contractor
Rewards Points: 249
Outside Lazer Level
I'm a small residential contractor but starting to get into a few more additions/bigger projects. The time has come for a new lazer level we can see clearly outside.
I use a Bosch inside and currently outside,but even with the glasses, the green line can be difficult to find outside.
I would really appreciate any info/recommendations.
Thanks
shesbros is offline
Old 12-12-2019, 03:21 PM   #2
META's Avatar
Trade: General and Trades
Rewards Points: 5,638
Re: Outside Lazer Level
Not much out there in terms of visible laser in sunlight regardless of color.
We use a receiver at times for squaring buildings when laser isn't visible, but that isn't as practical for multiple stud heights on walkouts and basement walls on irregular slabs. We just fight the sun utilising shadows and time of day as best we can for those situations.
META is online now
The Following User Says Thank You to META For This Useful Post:
Calidecks (12-13-2019)
Old 12-13-2019, 12:03 AM   #3
Dirtywhiteboy's Avatar
Rewards Points: 12,670
I do my laser work outside first thing in the morning when it's still darkish out. If the sun is out I use the catcher with the PLS or I have a couple Bosch 360 lasers.
Dirtywhiteboy is offline
Old 12-13-2019, 07:46 AM   #4
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 642
Everyone should have a good rotary for grade and height.
For your layout level get the the receiver and learn how to use it. I use mine down in the footer where you can't pull tapes straight across.
That said, learn how to do your layout the old fashioned way too, hard to beat a set of batter boards and some long steel tapes for your pre-layout. They are very fast and 100% accurate as long as you figure your diagonals properly (easier than ever with tools on your phone now).
NYCB is offline
Old 12-13-2019, 01:29 PM   #5
shesbros's Avatar
Rewards Points: 249
Thanks very much for the input.
I'll work a little more with the targets and just get more comfortable overall.
Thanks!
shesbros is offline
Old 12-15-2019, 11:15 AM   #6
AustinDB's Avatar
Rewards Points: 1,340
using the green 'target' with my dewalt helps when working further from the unit.
AustinDB is offline
Old 12-15-2019, 04:26 PM   #7
GC/carpenter
Calidecks's Avatar
Rewards Points: 2,828
We are so good at squaring up building lines with a tape and string line I'm not sure a Lazer for that would make it any better or faster. Especially with the slopes we deal with. With that said my rotary level is invaluable for elevations.
In my experience never double check anything the same way. There's almost always two ways to check something to see if you get the same end result.
Story poles are your friend.
Mike.
_______________
Calidecks is online now
402joel (12-16-2019)
Old 12-17-2019, 08:20 AM   #8
NYCB's Avatar
Rewards Points: 642
Mike.
_______________
The layout lasers are great for once you get your holes dug and footers poured.
I can get a lot closer with that than I can with tapes and a level if there isn't a full dig.
If it is a full dig, steel tapes 100% as long as I can pull them straight across.
Usually I will use the laser to get started, then either get forms up or start building wall until I'm just high enough to double check everything with tapes, and if it's off a bit we can still tweak it or shimmy some forms over.
The beeper is invaluable though, trying to do it with the target thing is an exercise in futility, unless you want to do layout at 10pm when it's dark.
NYCB is offline
Old 12-17-2019, 12:26 PM   #9
GC/carpenter
Calidecks's Avatar
Downhill is what I'm talking about. We are spot on every time.
So we pull an imaginary Pythagorean
(so to speak) downhill to be be able to get square on the ground with a slope. The math works perfect. Finish floor was to determine top of piers which gave us one of the numbers for the Pythagorean.
Mike.
_______________
Mike.
_______________
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
cedarboarder (12-17-2019), META (12-17-2019)
