Opinions Please (drill Press) - Tools & Equipment - Contractor Talk
Old 11-12-2018, 03:23 PM   #1
GC/carpenter
Calidecks's Avatar
Rewards Points: 160
I'm thinking of investing in a drill press with a 6" spindle travel to drill holes for cable rails. Set up a jig and fence system specifically for that task.
I need to drill a 3/16" hole through a Trex post sleeve, into a 4x4 Doug Fir post and through the otherside in the middle. I believe 13 holes per post 50 posts for this particular project.
Is this something that will work more efficiently using a press in your guys opinion?
The finish guys may have some answers for me. Thanks
I have my eye on this one
https://www.toolnut.com/teknatool-ne...yABEgI6CPD_BwE
Mike.
_______________
Calidecks is offline
Old 11-12-2018, 04:50 PM   #2
hdavis's Avatar
Rewards Points: 4,408
Re: Opinions Please (drill Press)
IMO, it would be faster to set up one jig for the 13 holes and hand drill them all. I'll use something like an 18" bit so I have plenty to keep from having slop.
Making the jig on a drill press is a time honored tradition.
hdavis is offline
Old 11-12-2018, 05:12 PM   #3
GC/carpenter
Calidecks's Avatar
Rewards Points: 160
Make the jig out of hardwood, or metal?My concern with metal is scratching the post sleeve. My concern with a wood jig is slop.
Mike.
_______________
Old 11-12-2018, 05:15 PM   #4
GC/carpenter
Calidecks's Avatar
Rewards Points: 160
Something like this?
Mike.
_______________
Old 11-12-2018, 05:27 PM   #5
hdavis's Avatar
Mike.
_______________
Make it out of wood, but drill the holes oversized and put sections of pipe in as sleeves so you don't get much wear or slop.
I say wood, because you'll get the slight expansiin and contraction with varyung moisture content that your wood post will have.
If you need thus to last practically forever, you put an oversized metal sleeve in that's fixed, and a correct sized sleeve inside of that which is free to spin, but has a retainer to keep it from riding up while you drill.
That approach would be something to have a machinist make the internal and oversized sleeve for you.
hdavis is offline
Calidecks (11-12-2018), Fixed (11-19-2018)
Old 11-12-2018, 06:03 PM   #6
hdavis's Avatar
Mike.
_______________
Yup!
hdavis is offline
Old 11-12-2018, 08:52 PM   #7
tjbnwi's Avatar
Rewards Points: 5,984
If you want to go with that drill press, I've read nothing but good things about them.
There is an entire thread on FOG dedicated to the Voyager. Tips on how to make tables and other accessories for it.
tjbnwi is online now
Old 11-13-2018, 02:32 AM   #8
TRThomas's Avatar
Trade: Residential Remodeling/Everything
Rewards Points: 382
I would suggest a drill press over a jig, once you have a drill press you will find many more uses for it. There are also drill/mill hybrids, but they get expensive really quickly and unless you're working with metal you don't need one.
With the drill press, all you would need to know is your on center hole spacing, drill the first hole in all your posts, then set a pin or dowel with a beveled edge on the top, the exact diameter of the holes you are drilling on a piece of plywood with a fence to keep them centered, or off center.. whatever you're going for, then just drill, advance last drilled hole onto the dowel/pin, etc etc
Drill presses are also great for mortise/tennons with forsner bits or mortising setups ($$$) drilling flush mount hinges, really anything you need to drill a straight hole in, a press is the best way to do it in a shop setting. They are also almost universally variable speed, so your bits will go a lot further and work much better doing so as you can set the speed according to the bit. Also.. heh.. you have much more control over the drilling operation so you're less likely to get blow out the back side of the wood you're working on because you're just applying very minimal pressure to a hand wheel/lever.
I've had limited success with wooden drilling jigs, something always ends up walking or wallowing out the wood guide holes causing quite an error once you've drilled 6" through something. Steel guide bushings work well to prevent this from happening, but the time it would take to build a one time use jig like that you could have bought the drill press, assembled it, drilled all of the holes and put down a couple drinks.
TRThomas is offline
The Following 2 Users Say Thank You to TRThomas For This Useful Post:
Calidecks (11-13-2018), Fixed (11-19-2018)
Old 11-13-2018, 02:46 AM   #9
TRThomas's Avatar
Rewards Points: 382
Also, there are tons of commercially available drill press auxiliary tops, fences, jigs and whatnot available. Kreg and Woodpeckers off the top of my head but there are many more. One thing I've been meaning to make is a top out of laminate or formica with a t-track that runs parallel with a t-track adjustable fence and centered on the center axis of the drill press arbor. This way, you can use a t-bolt with different diameter cylinder nuts (5/16 11/32 3/8 ... 3/4) to use as indexing pins that can be easily set and adjusted.
TRThomas is offline
The Following User Says Thank You to TRThomas For This Useful Post:
Robie (11-13-2018)
Old 11-13-2018, 07:45 AM   #10
rrk's Avatar
Rewards Points: 32
That is a lot of moving wood for 13 holes in 1 post times 50
easier/ faster to move the drill
rrk is offline
Old 11-13-2018, 10:21 AM   #11
GC/carpenter
Calidecks's Avatar
Rewards Points: 160
Then I have a staircase with two landings and a return. The posts will need drilled at an angle.
Mike.
_______________
Old 11-13-2018, 04:39 PM   #12
TRThomas's Avatar
Rewards Points: 382
Mike.
_______________
Most drill press tables tilt (the one you linked does, +- 45deg.) but I don't know if 6" of throw would get you through the posts you are making at ~32deg. (or more?) without re-chucking the bit which would essentially double your work.
A jig with guide bushings ( https://www.amazon.com/06111TK-3pck-.../dp/B005GFL5IU https://www.grainger.com/category/dr...xoC99YQAvD_BwE or similar ) might work, but 6" through Trex a 4x4 then Trex with a 3/16" drill without it running out on you, not to mention there is a bit of slop between the bushing and the bit, is a tall order. The longer the guide bushing the less angle the bit can achieve before it starts drilling. Since you really want the cables to be perfectly straight straight through the posts, maybe drill half through 1 side then half through the other and hope they meet in the middle?
TRThomas is offline
Old 11-13-2018, 04:57 PM   #13
hdavis's Avatar
Mike.
_______________
Same answer.
hdavis is offline
Old 11-13-2018, 07:11 PM   #14
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 634
I would suggest a drill press also, but that one (to me) seems overly expensive though.
I would think that you could get a much less expensive one that will do just as good a job, maybe two for that price.
Just my thought.
Andy.
ScipioAfricanus is offline
Old 11-13-2018, 10:44 PM   #15
GC/carpenter
Calidecks's Avatar
Rewards Points: 160
Just my thought.
Andy.
Not with a 6 inch spindle travel. That's key.
Mike.
_______________
ScipioAfricanus (11-14-2018)
Old 11-13-2018, 11:21 PM   #16
Jay hole's Avatar
Trade: General contractor
Rewards Points: 1,727
What about something like this????
Jay hole is offline
Old 11-14-2018, 12:23 AM   #17
GC/carpenter
Calidecks's Avatar
Rewards Points: 160
It's not accurate enough. Plus I can't attach it to the post sleeve.
Mike.
_______________
Old 11-14-2018, 03:14 PM   #18
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 158
There are old mortising machines on the market which have the handy foot feed lever allowing both of your hands to move the stock and your foot to move the trunion. You'd have to inquire about the specific trunion travel depth. If you got a 3 phase motor you could power it and infinitely control the speed with a conversion box for $175-200.
P42003 is offline
The Following 2 Users Say Thank You to P42003 For This Useful Post:
Calidecks (11-14-2018), TRThomas (11-14-2018)
Old 11-14-2018, 03:15 PM   #19
Business Owner
P42003's Avatar
Rewards Points: 158
http://vintagemachinery.org/classifieds/ads.aspx
P42003 is offline
The Following User Says Thank You to P42003 For This Useful Post:
Old 11-16-2018, 09:18 AM   #20
r a s's Avatar
Trade: division twelve
Rewards Points: 1,172
The reviews on Amazon may prove helpful and the three reviews on Toolnut were more thorough than most.
If the price is even an issue then you may want to see what is available locally on Bidspotter.com. There are lots of companies that use them to move surplus drill presses.
r a s is offline
Temp replacement drill. Suggestions? renov8r Tools & Equipment 25 03-07-2013 11:40 PM
looking at a festool cordless drill fr8train Tools & Equipment 31 05-10-2009 02:28 PM
Need help picking new heavy duty drill cmd17uc Tools & Equipment 5 01-19-2009 03:27 PM
corded dewalt drill trigger speed control question michigan roman Tools & Equipment 1 12-03-2008 01:13 AM
