Ok Darcy... - Page 2 - Tools & Equipment - Contractor Talk
Ok Darcy...
Old 12-14-2015, 06:32 PM   #21
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,434
Re: Ok Darcy...
Go to dollar general and get some totally awesome. Best cleaner I have ever used.
Look up American National knife an order another set.
Use a knotted wire wheel on a grinder to clean table then paste wax it.
I will find a link to a manual for you.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
overanalyze (12-14-2015)
Old 12-14-2015, 06:48 PM   #22
I like Green things
Re: Ok Darcy...
http://www.vintagemachinery.org/pubs...l.aspx?id=4318
Warner Mill Works
Facebook
YouTube
Old 12-14-2015, 06:51 PM   #23
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 436
Re: Ok Darcy...
Awesome Darcy!! You rock!
overanalyze is offline
Old 12-14-2015, 07:19 PM   #24
Always Learning
Rewards Points: 436
Re: Ok Darcy...
How about these for blade setting?
http://www.amazon.com/Big-Horn-19612.../dp/B001DDWQQE
Old 12-14-2015, 07:25 PM   #25
J.C.'s Avatar
Rewards Points: 112
Re: Ok Darcy...
Originally Posted by overanalyze View Post
I've never used those so no comment about them but, I can recommend this One Way Gauge It's great for setting machines up.
I do not prize the word "cheap." It is not a badge of honor...it is a symbol of despair. Cheap prices make for cheap goods; cheap goods make for cheap men; and cheap men make for a cheap country. ~ William McKinley
J.C. is offline
Old 12-14-2015, 07:30 PM   #26
I like Green things
Re: Ok Darcy...
I just use an indicator and mag base from the top.
I use a 4" block to set everything else.
Warner Mill Works
Facebook
YouTube
Old 12-14-2015, 08:59 PM   #27
Railman's Avatar
Trade: Railing
Rewards Points: 543
Re: Ok Darcy...
Same here......
If you go this rout, you can use the indicator for a large variety of uses. The $66 dedicated magnetic set is only good for one thing. The indicator, & magnetic base (need both) will set you back about $30 or so. It's now on sale at $17 + $13. It makes it easy to dial in how proud the knives are above the head.....with practice.
http://www.harborfreight.com/1-inch-...cator-623.html
Don't worry about the brand. It'll work perfectly well.
Railman is offline
The Following User Says Thank You to Railman For This Useful Post:
Old 12-14-2015, 09:12 PM   #28
tjbnwi's Avatar
Rewards Points: 1,780
Re: Ok Darcy...
If you get the HF dial indicator check the stem to make sure moves smoothly. I had one that was a little "sticky". They exchanged it no questions asked.
tjbnwi is online now
Railman (12-14-2015)
Old 12-14-2015, 09:46 PM   #29
I like Green things
Re: Ok Darcy...
I used one for a year. I recently bought a couple Mitutoyo indicators and mag bases.
There is something about quality measuring tools that is hard to describe other then awesome.
The 4" block has been used for a century or more. My 1944 Buss 4l planer manual calls for using a 4" block.
Warner Mill Works
Facebook
YouTube
Old 12-14-2015, 10:35 PM   #30
Always Learning
Rewards Points: 436
Re: Ok Darcy...
Ok..so how do you use the 4" block? With feeler gauges?
Old 12-14-2015, 10:44 PM   #31
I like Green things
Re: Ok Darcy...
No.
You can use it to check that the bed is parallel to the head/knives, let's you check pressure bar height (same as knives to table) then you drop table 1/16" (maybe one turn on height wheel) and check in feed and out feed rollers.
Basic planer settings are the same for any single surfacer.
It's probably in the manual...
Warner Mill Works
Facebook
YouTube
Old 12-14-2015, 10:49 PM   #32
Always Learning
Rewards Points: 436
Re: Ok Darcy...
Gotcha. The manual specs heights and tolerances in thousandths. Looks like I am getting a dial gauge. Thanks for all the help everyone!
Old 12-14-2015, 10:55 PM   #33
I like Green things
Re: Ok Darcy...
http://www.vintagemachinery.org/pubs...l.aspx?id=4983
Check this one. Should be a good section on setting up and troubleshooting as well.
Common to all single surfacers.
Warner Mill Works
Facebook
YouTube
Old 12-16-2015, 05:27 PM   #34
Always Learning
Rewards Points: 436
Re: Ok Darcy...
Good tip on the cleaner!! This cleaned up real well! Going to get 2 new belts and get it adjusted.
Ok Darcy...-1450304789525.jpg   Ok Darcy...-1450304798412.jpg   Ok Darcy...-1450304808502.jpg   Ok Darcy...-1450304815511.jpg
Old 12-16-2015, 05:33 PM   #35
I like Green things
Re: Ok Darcy...
That's a good looking machine.
Totally Awesome is probably the best cleaner I have ever used. You can't beat the price either. Buy some for your wife. She will get all sorts of use out of it around the house.
Warner Mill Works
Facebook
YouTube
overanalyze (12-16-2015)
Old 12-16-2015, 05:34 PM   #36
I like Green things
Re: Ok Darcy...
I wouldn't worry about replacing a belt unless it was coming apart or was noisy.
Warner Mill Works
Facebook
YouTube
Old 12-16-2015, 07:56 PM   #37
Always Learning
Rewards Points: 436
Re: Ok Darcy...
One of the belts to the motor is real loose and the other is tight. Shouldn't they be close to the same tension?
Old 12-16-2015, 08:31 PM   #38
I like Green things
Re: Ok Darcy...
I would run it and see how it does first. Under load there might not be any difference in them. 3hp really only needs on B series belt anyway. I always laugh at the 3 belts on a 1.5hp unisaw or pm66.
Warner Mill Works
Facebook
YouTube
Old 12-17-2015, 12:04 AM   #39
Always Learning
Rewards Points: 436
Re: Ok Darcy...
Got it fired up tonight. Played with the tension on the feed rollers a bit until the snipe was gone. Runs smooth. Waxed the table too. Going to order some extra knives and call this beast in service.
The Following 4 Users Say Thank You to overanalyze For This Useful Post:
pinwheel (12-17-2015), PrestigeR&D (01-11-2016), Railman (12-17-2015), Xtrememtnbiker (12-17-2015)
Old 01-11-2016, 06:26 PM   #40
Wood Craftsman
PrestigeR&D's Avatar
Rewards Points: 4,642
Arrow
Re: Ok Darcy...
Nice machine
Owwm - rules......
B,
PrestigeR&D is offline
The Following User Says Thank You to PrestigeR&D For This Useful Post:
overanalyze (01-11-2016)
Hey Darcy, Nice Ad Seven-Delta-FortyOne General Discussion 22 06-27-2013 07:48 PM
Good show Darcy and Mark !! John Hyatt Decks & Fencing 26 12-03-2011 07:08 PM
Uh oh Darcy, time to start all over...$$ J F Tools & Equipment 14 01-24-2011 10:37 PM
