Non Powder Actuated Concrete Nailers - Tools & Equipment - Contractor Talk
Old 08-07-2019, 10:02 PM   #1
diplomat
Golden view's Avatar
Rewards Points: 1,036
Anyone have experience with Pnumatic or even cordless concrete nailers as an alternative to my slow ramset gun?
I probably shoot 1000 nails a year into concrete for 3/4" furring, bottom plates, and drain mat on foundations. I'd prefer to shoot nails with washers. I see there are some "T-nail" guns. I don't know what application those are typically used for.
Thanks for any help.
Golden view is online now
Old 08-07-2019, 10:17 PM   #2
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,366
Re: Non Powder Actuated Concrete Nailers
I've used the trakfast gun for shooting hat channel and wall track. It's FAR easier on the hands, quieter, less smelly (debatable), and much faster, but it's also a lot more bulky and not able to fit in tight spaces because the cylinder jug is so large to get the needed power.
I've never used anything larger than a 3/4" pin so I'm not sure how well it would work through a furring strip but I'm sure someone here has.
I would never use powder again if possible. I had to clean it all the time just like the impulse guns but it's worth it in my opinion.
I'd suggest renting one first and see how you like it. Some of the guys liked the powder better so it depends on your preference.
Hope this helps.
-Dennis
WarriorWithWood is offline
The Following User Says Thank You to WarriorWithWood For This Useful Post:
Golden view (08-07-2019)
Old 08-07-2019, 10:21 PM   #3
diplomat
I'd be fine with a single shot gun. Still much faster than loading the charge every time.
Something like this.
Old 08-07-2019, 10:43 PM   #4
General Contractor
greg24k's Avatar
Rewards Points: 8,518
I have been using a Hilti DX36 for the last 25+ years never had any issues.
greg24k is offline
Tom M (09-04-2019)
Old 08-07-2019, 10:52 PM   #5
diplomat
Looking to get away from powder actuated, but maybe having 10 shots is all I need.
greg24k (08-08-2019)
Old 08-08-2019, 06:35 AM   #6
TimNJ's Avatar
Rewards Points: 6,032
I have been kicking around replacing my Hilti with the Makita GN420cse if I can get it shipped here from UK.
I was able to get the finish nailer shipped.
TimNJ is online now
The Following User Says Thank You to TimNJ For This Useful Post:
Bull Trout (09-11-2019)
Old 08-08-2019, 11:24 AM   #7
Dirtywhiteboy's Avatar
Rewards Points: 13,482
I have the T-nailer and it works good for CFS and shooting into cinder block and new concrete. The pin is small in diameter. It does not replace a ram set gun that shoots a fat pin.
Dirtywhiteboy is online now
Golden view (08-08-2019)
Old 08-08-2019, 08:16 PM   #8
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
Trakfast use one all the time for 3/4 fur strips and window bucking, not a cheap tool use to come free with a big pin order, worth while trying to find a used one fuel comes with the pins also use it for metal track when doing condo's and such.
I use a Ramset Cobra for bottom plates 2x4 pt.
I have 'T' nailer and have never used it once was on clearance al Lowes for $120.00 so I bought it as they cost about 5 bills, any one reading this thread that would like to buy it PM me, it has just sat in m van for seven years riding with me
Still "Shakin" the tree boss
sunkist is offline
Old 08-08-2019, 08:40 PM   #9
META's Avatar
Trade: General and Trades
Rewards Points: 6,370
I don't have any experience with it, but am looking at the MAX 2.5-in Concrete Nail Gun, Model # HN120.
META is online now
Old 08-08-2019, 08:52 PM   #10
diplomat
Pricey tool and needs a special compressor. Would be the ticket if I did hundreds of shots a week.
META (08-10-2019)
Old 08-10-2019, 08:58 PM   #11
META's Avatar
I did quick math and I think break even was around 6-8k nails driven, depending on fastener pricing...and the comparable tool cost. I compared the Ramset Cobra+, which I actually just bought this week.
META is online now
Old 09-03-2019, 12:36 PM   #12
madmax718's Avatar
Trade: General
Rewards Points: 3,276
I've had such terrible luck with the ramset (not from the tool, but from the concrete and brick). often times just cracking or spalling the concrete, no matter how light (or heavy) a load I use. I have found it to be pretty good on cinder block though, but sometimes drilling tapcons are the way to go. As long as the surface is reasonably clean, I'll hot glue the strip so that it stays in place, and then go around drilling the holes. Not as fast as ramset's, or other methods, but its an option.
madmax718 is offline
Old 09-04-2019, 11:35 AM   #13
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
I hear that, but check your driver, if the tip of the rod is at all worn or damaged it will start to shoot the pins with a slight angle and it causes more blowout. I hear ya on the tossing it back in the truck and using tapcons...so much so that I use the damn thing a fraction as much as I thought I would....but when I do use it it's a huge time saver.
Inner10 is offline
Old 09-04-2019, 04:18 PM   #14
RamsetTech's Avatar
Trade: Concrete Fastening
Rewards Points: 4
With most cordless gas powered concrete nailers you get about 3/4-inch embedment into concrete. If you need more embedment, you would have to go to powder actuated or a drill and fill solution like Tapcon.
Checkout the Ramset TF1200 TrakFast for versatility
https://www.ramset.com/products/tool...framing/tf1200
Or the T3MAG if you do a lot of metal drywall track, hat channel, etc
https://www.ramset.com/products/tool...-framing/t3mag
RamsetTech is offline
The Following 2 Users Say Thank You to RamsetTech For This Useful Post:
Golden view (09-04-2019), META (09-13-2019)
Old 09-10-2019, 11:04 PM   #15
madmax718's Avatar
Trade: General
I'll give it a check but I had less than 100 shots through it.
Old 09-13-2019, 05:37 AM   #16
META's Avatar
If you're firing into mature concrete, the depth of embedmant usually reduces.
META is online now
Old 09-13-2019, 07:34 AM   #17
tgeb's Avatar
Rewards Points: 620
I have a ramset gun that I haven't used in years.
I buy the ramset nails and hand drive them. It's faster, safer, less blow out and quieter.
www.gebcon.com
tgeb is online now
Old 09-26-2019, 02:08 AM   #18
Tech Geek
I've resorted to hand driving when fastening wood to new Crete..... Not so much when fastening track/wood to old Crete with river rock aggregate.
-Dennis
