Need Help To Demo A Pool With No Excavator Access - Tools & Equipment - Contractor Talk
Old 05-24-2011, 07:35 PM   #1
remodair's Avatar
Trade: General HVAC
We are working on a pool demo and there is no access for the excavator. Does anyone have any suggestion on what to use for the top portion of the pool wall. It's really thick and jackhammer is too heave to hold horizontally for a long time and it can barely brake the walls. Thanks.
remodair is offline
Old 05-24-2011, 07:44 PM   #2
The Grand Wazoo
KillerToiletSpider's Avatar
Rewards Points: 1,944
Re: Need Help To Demo A Pool With No Excavator Access
Dynamite.
I may be going to hell in a bucket, but at least I'm enjoying the ride.
KillerToiletSpider is offline
Old 05-24-2011, 07:47 PM   #3
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,670
Dexpan.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 05-24-2011, 07:50 PM   #4
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
I have seen people use SCDA's (silent chemical demolition agents) to take out areas that couldn't be broken up with machines. It worked well but I'm unsure of cost.
www.bcconstructionllc.com
BCConstruction is offline
Old 05-24-2011, 08:01 PM   #5
3bar's Avatar
Trade: carpenter
Rewards Points: 492
mini-excavator? crane it in.
3bar is offline
Old 05-24-2011, 08:43 PM   #6
remodair's Avatar
Trade: General HVAC
Originally Posted by WarnerConstInc. View Post
Dexpan.
Thanks WarnerConstInc., but how can we use it on vertical walls? How will it stay in?
remodair is offline
Old 05-24-2011, 08:47 PM   #7
remodair's Avatar
Trade: General HVAC
Thanks BCConstruction, but above question applies. How do we keep it in the wholes, since the walls are vertical?
remodair is offline
Old 05-24-2011, 09:17 PM   #8
JonM's Avatar
Rewards Points: 1,244
Just like the old days...get a 2 piece section of scaffolding with a 4 x 4 across the top...tie a rope around the 4 x 4 and the front of the jackhammer and have at it horizontally....done it a hundred times...but it does help to be young...
JonM is offline
Old 05-24-2011, 09:43 PM   #9
jhark123's Avatar
Trade: Pro Cat Herder
Rewards Points: 1,724
a breaker and a laborer or three
jhark123 is offline
Old 05-24-2011, 09:46 PM   #10
Fire up the BBQ
griz's Avatar
Rewards Points: 3,034
Either crane in a Mini Ex w/a breaker point or saw cut the damn thing.
You're gonna wear your self out thinking about it.
griz is online now
Old 05-24-2011, 09:48 PM   #11
I like Green things
drill the holes at a downward angle and put a plug over the holes?
just think out loud here.....
Warner Mill Works
Facebook
YouTube
Old 05-24-2011, 09:48 PM   #12
I like Green things
if all else fails, look for some amish or mexicans.
Warner Mill Works
Facebook
YouTube
Old 05-25-2011, 12:53 AM   #13
remodair's Avatar
Trade: General HVAC
Thank you all for all your recommendation! We will try the old fashion method by JonM and see if it will work. Thanks again!
remodair is offline
Old 05-28-2011, 09:32 PM   #14
6 K's Avatar
Trade: excavating
can you take the walk out or patio out on top then work your walls down?
6 K is offline
Old 05-29-2011, 04:22 AM   #15
Joasis's Avatar
Rewards Points: 4,918
If you cannot get equipment in, how will you fill the hole?
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
Old 05-29-2011, 08:01 PM   #16
Bosch Power
notillegal's Avatar
Trade: carpenter/G.C.
Rewards Points: 75
just fill the hole with the mexicans you use for demo labor, top dress with loam, and throw down some sod. All done
notillegal is offline
Old 05-29-2011, 10:05 PM   #17
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
How is he going to carry out all the crete? For the cost of labor there has to be a way to get a machine in. Even some of these micro mini's will be better than by hand and can fit through a doorway.
woodchuck2 is offline
Old 05-29-2011, 10:12 PM   #18
Head Grunt
woodchuck2's Avatar
A friend of mine just bought one of these and it weighs around 2500lbs and can lift up to 500lbs. It has expandable tracks so it can get into very narrow placed and i saw his was plumbed for either a thumb or other hydrolic tools.
Need pool replastering help CutTwice Pool Construction & Enclosures 0 05-06-2011 12:11 AM
Local SEO NickWasHere Marketing & Sales 48 04-01-2010 06:48 AM
Pool Demolition tgeb Pool Construction & Enclosures 4 05-02-2009 10:37 AM
