My First Festool - Tools & Equipment - Contractor Talk
My First Festool
Old 12-11-2012, 11:20 PM   #1
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,364
My First Festool
My Milwaukee drill died after six years, so I replaced it with this. It does everything, I can put a drill bit in the quick release chuck, drill a hole then quick swap it out for a screw bit.
My only question so far is when I take the bit extension, it will fit in the quick release chuck just fine, but if I take a standard 1" long screw bit, it won't fit in there. I have to insert the bit extension and put the screw bit in that extension, then I run into the problem with the bit constantly falling out and getting lost.
KennMacMoragh is offline
Old 12-11-2012, 11:21 PM   #2
WilsonRMDL's Avatar
Trade: Carpenter/Remodeler
Rewards Points: 532
Re: My First Festool
Just got my first festool today.
Trion jigsaw. Here's to the slippery green slope
Innovative Remodeling LLC
Licensed and Insured
WilsonRMDL is offline
Old 12-11-2012, 11:50 PM   #3
Greg from K/W's Avatar
Rewards Points: 530
You both are going to need such a high dose of penicillin you will crap through the eye of a needle for a month now.
Greg from K/W is offline
Old 12-11-2012, 11:54 PM   #4
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,794
Are you talking about putting a driver tip in it?
You put it into the centrotec bit holder, which should have a fairly strong magnet in it.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 12-11-2012, 11:59 PM   #5
tjbnwi's Avatar
Rewards Points: 2,810
A standard bit will not fit the Centrotec chuck directly. The corners are slightly rounded on the Centrtec. A wire detent bit should stay in the bit holder, if not there is a problem with either the holder or your bits. If the originals stay in ok, your bits may be ball detent so the wire won't grab the bit.
The bit will fit in the motor drive shaft without the Centrotec chuck. On the CXS (small drill) the motor output shaft is magnetic. Yours may be, mine is about 3 years old, haven't killed it yet.
If you got it locally take it back and try another holder. If you got it online hopefully your dealer will service you well. If you want an online dealer who is first rate, let me know, I'll PM his contact info. I would never use Amazon for my Festools.
If you can't get a resolve PM Shane, he'll advise you what steps to take.
I see you got the drill bit set with the counter sink. Those bits are beyond sharp, watch your fingers removing them from the index. You'll cry when you hit something and ruin a bit, then you'll order a replacement, they're that good. The counter sink looks like it shouldn't work, but it is the best I've ever used.
tjbnwi is online now
chris klee (12-12-2012)
Old 12-12-2012, 12:00 AM   #6
Yes, but it still falls out, the magnet isn't that strong. I'm thinking I need to get this one
The bit holder that came with the set doesn't have the ring on the end, which clamps it in.
Old 12-12-2012, 12:03 AM   #7
tjbnwi's Avatar
There is something wrong with your holder, I've read where the magnet sticks to a bit and gets lost.
I have the locking holder in my kit, I use the regular one much more often.
Old 12-12-2012, 12:03 AM   #8
I like Green things
I have not had any real issues with that, with my 4 year old c-12 or cxs. I just have the regular bit holder them came with.
Warner Mill Works
Facebook
YouTube
Old 12-12-2012, 12:08 AM   #9
Hmm, yeah it could be the bits. I bought the drill locally, not online, they had a limited selection of Festool genuine driver bits. So he gave me some other ones, generic driver bits.
For about $18 a bit, yeah that would be frustrating when you hit something. I almost wasn't going to buy them but he said they could sharpen those bits. Plus I wanted the hex shaft so it would fit the Centrotec.
Old 12-12-2012, 12:19 AM   #10
I like Green things
I mostly use the grk tips.
Warner Mill Works
Facebook
YouTube
Old 12-12-2012, 12:41 AM   #11
What is that?
Old 12-12-2012, 06:30 AM   #12
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,598
Grk bits are driver bits made to fit along with grk r4 screws.
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Old 12-12-2012, 06:41 AM   #13
nature boy's Avatar
Trade: Build / Remodel
Luuucky
nature boy is offline
The Following User Says Thank You to nature boy For This Useful Post:
KennMacMoragh (12-12-2012)
Old 12-12-2012, 09:47 AM   #14
I don't get how they size their tips http://www.festoolproducts.com/Drill...show=30&page=3
With the philips head they have:
3-25mm
2-25mm
1-25mm
HiQ 3-25mm
HiQ 2-25mm
HiQ 1-25mm
But judging from the pictures they all look like #2 sized philip heads. They are $11 for each one, if I were to buy every size tip including philip, slotted, sqaure drive, torx, I would probably spend over $300 in tips. I don't see any set where you get one or two of each
Old 12-12-2012, 09:58 AM   #15
Brian Peters's Avatar
Trade: remodeling and some new construction
Rewards Points: 972
3-25mm
2-25mm
1-25mm
HiQ 3-25mm
HiQ 2-25mm
HiQ 1-25mm
The 25mm is the length...about an inch
Brian Peters is offline
Old 12-12-2012, 05:57 PM   #16
Jdub2083's Avatar
Trade: General Contracting / Commercial Carpenter
Rewards Points: 282
t-25 starhead I believe. Well at least t-25 for the general purpose #9's I use a lot of.
Jdub2083 is offline
Old 12-12-2012, 11:26 PM   #17
tjbnwi's Avatar
The #2 phillip tips (all the non-HiQ 25 mm) are 10 pack for $11.00. The HiQ are 3 pack for $15.00. The HiQ are for use with an impact driver.
As stated in an earlier post, the 25 indicates a 25 mm length.
Old 12-16-2012, 08:17 PM   #18
So far I love it, it drives screws better than an impact, it's just more comfortable. The 18V battery lasts forever, I've used it a lot for almost a week and I'm still on the first battery, haven't swapped to the second one.
Old 12-16-2012, 08:20 PM   #19
I like Green things
I have not hardly touched an impact driver in the last 4 years, since I got my C-12.
I am really trying hard to not buy a new C-15.
Warner Mill Works
Facebook
YouTube
Old 12-16-2012, 08:38 PM   #20
Well they just came out with a cordless impact. I don't think it's on their website yet. I think it would only be good for it's intended purpose, driving nuts and bolts. The ordinary drill works better for screws if it's Festool because you can swap between a driver and drill bit pretty fast. Unlike their impact, you'd have to swap chucks to go from driver to drill.
Fine Finish w/o Festool basswood Finish Carpentry 78 02-04-2013 08:32 AM
Unboxing festool CMS BCConstruction Tools & Equipment 11 10-17-2012 08:24 PM
Festool 494369 crown stops for kapex BCConstruction Contractor Swap 4 10-02-2012 09:37 AM
If you could buy only one Festool product redwood Tools & Equipment 110 09-21-2012 03:49 PM
festool Planex and cleantex BCConstruction Tools & Equipment 10 05-11-2012 06:56 AM
