Mud Mixer Drill - Tools & Equipment - Contractor Talk
Mud Mixer Drill
Old 07-26-2009, 03:32 PM   #1
nwksremodeler's Avatar
Trade: a little bit of everything, roofing, windows, doors, kitchen & bath remodels
Rewards Points: 244
Mud Mixer Drill
My old mud mixing drill (United Electric Co., ancient) shot the brushes and possibly the armeture so I was looking for suggestions for a replacement? Was looking at just a standard 1/2" drill to do the job. I also came across a new one made by Diablo, Diablotools.com has anyone used one, whats your thoughts???
nwksremodeler is offline
Old 07-26-2009, 07:07 PM   #2
improving homes
platinumLLC's Avatar
Trade: Roofing/Remodeling
Rewards Points: 346
Re: Mud Mixer Drill
This is the one that I use, just I have the older model. Have used it for about 5-6 years now and like it. http://www.dewalt.com/us/products/to...p?productID=19
platinumLLC is offline
Old 07-26-2009, 07:14 PM   #3
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Re: Mud Mixer Drill
I have a Craftsman 1/2" triple reduction drill that turns 450 RPMs. You'll spin the bucket with yourself on top of it before you stop the drill. I used it to drill 3/4" holes through treated pilings with up to 14" diameter with a ship auger. It very closely resembles a B&D model from the same era. 20 years old.
loneframer is offline
Old 07-26-2009, 07:24 PM   #4
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 335
Re: Mud Mixer Drill
I got that 20 year old B&D drill. Haven't used it a whole lot over the last 5 years or so. Got it out a couple months ago to mix some joint compound and the drill spun about 5 times and stopped spinning. Upon inspection later I discovered that the shaft had sheared off cleanly. Where I use to work, the drywall finishers used and abused these drills and now under very light use, I've destroyed it.
We actually used a cordless 1/2" drill to mix some thinset last week and it seemed to do ok.
Warren is offline
Old 07-26-2009, 07:28 PM   #5
KemoSabe
loneframer's Avatar
Re: Mud Mixer Drill
I just went to the garage to see if I could find mine, as I haven't used it in about 8 years. I guess I should put it through the paces seeing that non-use is a form of abuse.
Old 07-26-2009, 08:41 PM   #6
joeslob's Avatar
Trade: Renovations
Rewards Points: 75
Re: Mud Mixer Drill
If you're looking at a dedicated mortar/mud drill, check out these... http://www.csunitec.com/mixers/
We use them for mixing epoxy mortar systems, and they're the toughest handheld mixers we've come across.
joeslob is offline
Old 07-26-2009, 11:57 PM   #7
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,108
Re: Mud Mixer Drill
I have a 20 year old makita 1/2 inch drill; its so beat up I don't care what kind of abuse I put it too. I've gone through many brushes, triggers and switches and the powercord as been replugged its now about 2 feet lol still works.
Inner10 is online now
Old 07-28-2009, 10:03 AM   #8
All ahead flank
Bill in VaBeach's Avatar
Trade: Kitchen and Bath Remodeling, Home Improvement
Rewards Points: 75
Re: Mud Mixer Drill
I'll second loneframer. I use a triple-reduction older Porter Cable 1/2" drill, max rpm probably 700, that will out torque anything you put it up against. Bought it new several years ago and it's a beast, and because of this can't justify buying a separate mixing tool...yet.
Bill in VaBeach is offline
Old 07-28-2009, 10:13 AM   #9
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,206
Re: Mud Mixer Drill
http://www.amazon.com/s/ref=nb_ss_hi...refix=diablo+m
We Fix Houses is offline
Old 07-28-2009, 03:58 PM   #10
JohnLINY's Avatar
Trade: Carpenter/Remodeler
Rewards Points: 75
Re: Mud Mixer Drill
I use an old Milwaukee Hole Hawg. It has enough torque to probably break your wrist. Low speed turns at 300 rmp so it is a beast. It is made like a tank and practical weighs as much as one.
JohnLINY is offline
Hitachi sds plus drill samthedog Tools & Equipment 4 05-27-2009 08:48 PM
QEP grout mixer mickey69125 Drywall 7 03-05-2009 07:50 PM
corded dewalt drill trigger speed control question michigan roman Tools & Equipment 1 12-03-2008 01:13 AM
metal drill bits SES Constructio Tools & Equipment 11 11-06-2008 04:41 AM
Morter Mixer Vs Cement Mixer personalt Masonry 6 07-29-2007 08:16 PM
