Molder Which One? - Page 2 - Tools & Equipment - Contractor Talk
Molder Which One?
Old 04-18-2020, 07:25 AM   #21
rrk's Avatar
Rewards Points: 5,398
Re: Molder Which One?
Originally Posted by HAPConst. View Post
Can I ask a stupid question. Why make your own molding? Are you saving that much money vs off the shelf? I have never been on a job where making my own molding hit me as the thing to do.
Ever try to match some older moldings? There is no "off the shelf"
Some times when doing less than a few hundred feet is more cost effective to do it yourself than pay for new knives that you can't keep, pay for set up time and then actually cutting from a custom place.
rrk is online now
Old 04-18-2020, 07:46 AM   #22
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 494
Originally Posted by Bldbiz View Post
I've seen Weinig molders around. Used they are fairly expensive but I understand you get what you pay for. I don't run a lot of trim. Looking to maybe spend $2500.
Thanks Pinwheel.
Granted, you're not going to put a weinig in your shop on your budget. But for what you get & can do with one, they're not that expensive used. With a little shopping, you can put one in shop with a decent library of knives, for under $10k. I've got $8500 in mine, with a large library of knives.
I've got an 18" woodmaster that does a decent job, but it's a hobby machine compared to the weinig. To run crown on the woodmaster, it's a multi run process. And 1/3 the feed speed. At least 2 passes just to get the profile, then either a 3rd trip through with a different knife to cut the back angles or 2 trips through the tablesaw. With the 5 head weinig, it's one pass. It takes longer to set up & dial in the machine than it does to run 1000' of crown.
The other beauty of the weinig, I can run s4s material through it. Which is a huge time saver when I'm preparing stock for a set of cabinets. Takes me about an hour now, to cut rough stock, then finish size all face & door stock for a full set of cabinets. I can process different widths of stock, with just the twist of a handle. Current job, has 4", 3 1/2", 3" 2 1/4" & 1 3/4" stock. All of it final sized without ever turning off the machine, in about 15 minutes of run time.
Doesn't take long to pay for with that kind of labor savings.
pinwheel is online now
Old 04-18-2020, 08:16 AM   #23
Bldbiz's Avatar
Trade: General contractor
Rewards Points: 12
Pinwheel I hear what your saying. Could have bought one 6 yrs ago cheap but passed on it. For the type of work we do I couldn't justify a high capacity molder in the shop to be used very little although once I had one I could probably find work to keep it busy. I'll be 53 this year and still out framing, siding, roofing etc. Custom kitchens/trim are a tough sell for the majority of customers in my area. Maybe in a few more yrs. transitioning to more cabinetry etc. will be a plan.
Kind of like telehandlers or cranes a bigger one would always be nicer.
Bldbiz is offline
The Following User Says Thank You to Bldbiz For This Useful Post:
pinwheel (04-18-2020)
Old 04-18-2020, 02:05 PM   #24
pinwheel's Avatar
Rewards Points: 494
I'm 56 in a week & still humping out hardwood floors. The body is really starting to protest, which is why we're making the transition to cabinets & trim now.
Course, we been doing floors for 25 years & our clients aren't wanting to let us make the transition. They want us to do all of it, cabinets, trim & keep doing their floors.
Old 04-18-2020, 02:44 PM   #25
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 12,521
Get some young bucks to do them for you.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 04-18-2020, 02:54 PM   #26
tjbnwi's Avatar
Rewards Points: 4,734
I wish some of our cabinets were as light as hardwood flooring....
tjbnwi is online now
Old 04-18-2020, 03:03 PM   #27
rrk's Avatar
I don't think the weight is the issue as much as being bent in half with 1 arm in near non stop movement all day long
rrk is online now
Old 04-18-2020, 04:32 PM   #28
pinwheel's Avatar
Rewards Points: 494
I'm actively looking for a young buck to take on as an apprentice with the option of selling the floor business to after a year. Like everywhere, nobody wants to work that hard. Lucrative, or not.
Old 04-18-2020, 04:35 PM   #29
pinwheel's Avatar
Rewards Points: 494
It's not the weight that's the problem. Crawling around on the floor all day & up & down 100 times a day gets harder & harder every year.
The job we're currently on, is 2300' of sanded floor. That's approx 7500# of floor we packed in & up stairs, 70# at a time
Old 04-18-2020, 05:00 PM   #30
rrk's Avatar
did you make the flooring or buy it ? here they used to get it delivered and the poor delivery schlubs had to place it in the room wherever the installer wanted like drywall
If you are looking for an apprentice look for a Brazillian, in NJ 95% or more are Brazilian and most live in the same area and drive all over the state. The ones I have used do great fast work.
rrk is online now
Old 04-18-2020, 06:13 PM   #31
pinwheel's Avatar
Rewards Points: 494
We buy it from a hardwood floor distributor. Comes to my shop via truck line. I'm the poor schlub that has to handle it all. I could mill it with the weinig, but I don't have an end matcher or a source cheap enough for raw materials to make it profitable to mill ourselves.
There's no brazillians around here, just caucasion rednecks. I've had some high school farm boys help me from time to time, those boys aren't scared to work, just haven't found one that wants to apprentice yet.
The Following User Says Thank You to pinwheel For This Useful Post:
rrk (04-18-2020)
