Milwaukee Switch Blade Selffeed Bits Problem - Tools & Equipment - Contractor Talk
Old 11-06-2014, 10:16 AM   #1
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Bought a set of the above cutters and have issues with them not self feeding. Any of you guys have these? What am I doing wrong?
The self feed part keeps clogging with material and won't self feed.
Attachment 120935
www.bcconstructionllc.com
BCConstruction is offline
Old 11-06-2014, 10:48 AM   #2
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,748
Re: Milwaukee Switch Blade Selffeed Bits Problem
What are you drilling into?
Rustbucket is online now
Old 11-06-2014, 11:37 AM   #3
Trade: Construction
Just 2x4's
Old 11-06-2014, 04:38 PM   #4
Rustbucket's Avatar
Trade: Remodel/Deck
I've had problems like that with composite, but less so with wood. The screw might not be aggressive enough. Don't think you're doing anything wrong. The screw does look a little short in the picture. I'm no engineer, but I would think you would need 4-5 threads grabbing the wood before the cutters engage. It looks like maybe only a couple threads are engaging, and they simply shear from the torque, packing the wood into the valleys.
Old 11-06-2014, 07:13 PM   #5
Eaglei's Avatar
Trade: carpenter & Masonry
Rewards Points: 1,510
Are you using a high torque right angle drill. Sometimes you really need to get good leverage to get it started , when it get's going hold on and brace it . My friend had his nose rearranged by a Millwauke right angle drill .
Eaglei is offline
Old 11-06-2014, 07:50 PM   #6
Trade: Construction
It does seem like the threads are too fine and striping out easy. I'm using it on the big dewalt one with the safety cut off to stop it smashing you up.
I'm gonna use them on some other material and see how they get on. I love the way the blade can be removed and sharpened though.
Old 11-06-2014, 08:22 PM   #7
hdavis's Avatar
Rewards Points: 2,892
3 on the thread issue. When I've had a bit that would do that, I take a needle file and deepen the threads. It may not fix it 100%, but it makes it workable.
hdavis is online now
Old 11-06-2014, 09:04 PM   #8
D.S.I.'s Avatar
Trade: REMODELING
Rewards Points: 277
That f-ing reverse gets me every other week, check it out.
D.S.I. is offline
The Following User Says Thank You to D.S.I. For This Useful Post:
Calidecks (11-07-2014)
Old 11-06-2014, 09:09 PM   #9
skillman's Avatar
Rewards Points: 1,968
It's more to do with the heat from the bit spinning causeing the wood to melt in place .
skillman is offline
Old 11-06-2014, 09:58 PM   #10
Rustbucket's Avatar
Trade: Remodel/Deck
Three is pretty common with machine screws, but I was thinking that the taper on the lead screw would make the first 3 threads marginally effective. You don't get to the meat of that screw until several threads in.
The Following User Says Thank You to Rustbucket For This Useful Post:
hdavis (11-07-2014)
Old 11-07-2014, 02:07 AM   #11
GC/carpenter
Calidecks's Avatar
Rewards Points: 18,162
Did you hit a pitch pocket? Maybe it's just pitch
Calidecks is online now
Old 11-07-2014, 06:46 AM   #12
Trade: Construction
I kept thinking I was hitting knots but every time I looked in the partial hole it was clean wood. It's my first time using them so perhaps it's more to do with technique than the bit as I'm sure they must have tested these things before releasing them.
Old 11-07-2014, 08:31 AM   #13
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,525
Try more pressure when you start so it screws in rather than making shavings. Might lube the threads, too. More pressure until it grabs is the main thing.
MarkJames is offline
Old 11-07-2014, 11:07 AM   #14
Gary H's Avatar
Rewards Points: 2,342
My set came with course and fine thread screws. That looks like a fine thread.
Gary H is offline
Old 11-07-2014, 03:21 PM   #15
chewy's Avatar
Trade: Electrical Apprentice and Data Technician.
Rewards Points: 1,208
You might be drilling to fast perhaps?
chewy is offline
Old 11-07-2014, 04:17 PM   #16
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
or too slow?
Tom Struble is offline
Old 11-08-2014, 06:34 AM   #17
Box Builder
Morning Wood's Avatar
Rewards Points: 9,696
Push harder
Morning Wood is offline
The Following User Says Thank You to Morning Wood For This Useful Post:
Eaglei (11-08-2014)
bosch table saw problem Mrmac204 Tools & Equipment 15 01-20-2013 09:47 AM
problem with a large order of pond products Outdr Contractr General Discussion 6 12-20-2012 07:51 AM
WTS Milwaukee M12 Red Lithium 12v Batteries (4-6 For Sale) EDCivilian Contractor Swap 2 12-17-2012 11:47 AM
milwaukee saw with blade on left 6391-21 bigjohn Tools & Equipment 11 06-11-2011 03:00 AM
smart light switch circuit toastermaker Electrical 7 12-07-2005 11:45 PM
