Metal Stud Finder Suggestion - Tools & Equipment - Contractor Talk
Old 09-29-2018, 02:36 PM   #1
gowings's Avatar
Trade: Remodel and Repairs
Rewards Points: 973
I'm looking for a highly accurate metal stud finder.
I do have a franklin I use for wood stud finding.
I have 3 tv mounts to do on metal stud framing. So time to invest in a new toy.
Any suggestions
gowings is offline
Old 09-29-2018, 02:42 PM   #2
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 298
Re: Metal Stud Finder Suggestion
I may be missing something but wouldn't a CH Hansen magnetic stud finder do the trick?
Xtrememtnbiker is offline
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
TRThomas (09-29-2018)
Old 09-29-2018, 03:03 PM   #3
gowings's Avatar
Rewards Points: 973
I found a few vids.
Does it find edge to edge. That's critical for the 1/2" toggle straps I use. Staying away from the rib of the metal stud edge
gowings is offline
Old 09-29-2018, 03:54 PM   #4
tjbnwi's Avatar
Rewards Points: 3,478
Originally Posted by gowings View Post
I found a few vids.
With a little practice you’ll be just fine.
It is easy to feel the magnetic pull change.
tjbnwi is offline
TimNJ (09-30-2018), TRThomas (09-29-2018)
Old 09-29-2018, 06:39 PM   #5
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 566
Zircon multi scanner 740 had one for years came with a c.d. works great finds all in the walls.
Still "Shakin" the tree boss
sunkist is offline
Old 09-29-2018, 06:55 PM   #6
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,080
Franklin works fine for metal studs.
Inner10 is offline
Old 09-29-2018, 07:35 PM   #7
Inner10's Avatar
And if you're curious I've mounted literally hundreds of TVs on metal studs in apartments/hotels with mine...also often using the 1/2" snap togglers. Keep in mind that the toggler needs 1-7/8" behind wallboard so an 1-5/8" stud makes it a real pain in the ass.
Inner10 is offline
Old 09-30-2018, 06:17 AM   #8
rrk's Avatar
Rewards Points: 1,628
If you cut 3/16 off of one side of the metal and insert that end first it will make it much easier
rrk is offline
Old 09-30-2018, 08:50 AM   #9
TimNJ's Avatar
Rewards Points: 4,464
I have some really strong magnets that are shipped with doors that have internal blinds. I stack three of them and it is very easy to find a metal stud behind the rock with them. You can tell when you are approaching the edge of the stud.
TimNJ is offline
Old 09-30-2018, 10:59 AM   #10
Inner10's Avatar
That's what I do, nip the end with my side cutters and give em a wack using a screwdriver and a pair or cutters like a hammer.
Inner10 is offline
Old 09-30-2018, 11:21 AM   #11
cedarboarder's Avatar
Trade: Workaholic
Rewards Points: 2,328
maginet worked really well for plaster and lath walls,
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is online now
Old 09-30-2018, 09:40 PM   #12
Lettusbee's Avatar
Rewards Points: 838
Has anyone definitively endorsed the walabot app? Is it worth the $100
Lettusbee is offline
Old 10-01-2018, 10:21 AM   #13
Trade: Workaholic
not that I've seen. I heard thru the grape vine it's not good and buggy.
The Following User Says Thank You to cedarboarder For This Useful Post:
Lettusbee (10-01-2018)
Old 10-01-2018, 10:27 AM   #14
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 3,429
Get a small Rare Earth Magnet disc.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 53,000 Subscribers and over 9,500,000 Views
https://www.youtube.com/paulpeck
Twitter Facebook Google+ Instagram
Sir Mixalot is offline
Metal stud radius soffit framing AMEDDIO100 Drywall 7 05-01-2013 06:22 AM
Paper Faced Metal Bead... or??? Rich D. Drywall 27 01-12-2013 01:22 PM
Metal Stud Framer Going to NYC Zendik Help Wanted or Looking For Work 4 07-16-2008 05:37 PM
Metal stud spacing? CM Mann Commercial Construction 17 09-19-2007 12:58 AM
Quality stud finder?? MKamis Tools & Equipment 11 08-05-2007 11:12 PM
