Makita LS1016L Blade Wobble After 8 Months - Tools & Equipment - Contractor Talk
Old 11-10-2012, 03:07 PM   #1
designer + carpenter
NINZAN STUDIO's Avatar
Trade: carpentry
Rewards Points: 510
I've bought this miter saw brand new from HD this past March. I've used it off and on since then as required by the job (not used every day). I jump back and forth from framing to finish carpentry, and stuff in between.
Anyhow, I'm doing a cabinet & trim installation job these last few weeks and decided to clean the blade (bunch of pitch built up from a hardwood floor job). I normally use this CMT 80T blade for finish work. I took blade off and used CMT blade cleaner, got all the pitch off, put the blade back on the saw. I immediately noticed wobble. First, it was non-normal vibration that was never there while blade is spinning freely. Second, I can see the obvious wobble as the blade comes to a stop as I sight straight down through the blade guard. I took the blade off once more and reinstalled it just to make sure I didn't under or over crank the arbor with just enough pressure to keep tight. Same issue. I'm kinda peeved because I had some tear out on pre-finished custom built-in pieces I was installing yesterday and now have to do touch-ups (boo).
So fellow Makita users....before I go contacting Makita service, what should I check for (obvious stuff). I read on line something about arbor run-out? Not sure how to check for this. I know some people have had wobble issue with this saw. I'm surprised that it's cropped up now after 8 months of trouble free use. First thing Monday, I'm going to put the Makita factory blade back on and see what happens.
Oh and as a side note, both sets of rails have started to show rust at the very ends that are exposed when in the closed position. I'm working a job right now that right in front of the ocean so it comes with the territory but nevertheless, it's not "new" anymore.
NINZAN STUDIO is offline
Old 11-10-2012, 03:36 PM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,411
Re: Makita LS1016L Blade Wobble After 8 Months
Get a new blade and see if it still does it.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 11-10-2012, 03:50 PM   #3
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,754
May have just warped the blade. If it gets a lot of pitch buildup, it will also heat up the blade more when cutting.
Rustbucket is offline
Old 11-10-2012, 04:49 PM   #4
Trade: carpentry
Rewards Points: 510
Warped really? This blade is thick and has almost 1/8" kerf.
(Fixed my spelling thx Leo)
Old 11-10-2012, 04:51 PM   #5
LRG WoodCrafting
Leo G's Avatar
Heat destroys metal. Warped, really.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 11-10-2012, 04:55 PM   #6
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
it can very easily be a warped blade.. if it still happens with a new blade could be the bearings.. dewalts are notorious for this issue
woodworkbykirk is offline
Old 11-10-2012, 05:08 PM   #7
Trade: carpentry
Rewards Points: 510
Thx for the spell check. I'll order the exact same blade and see what happens. In the mean time I'll see if the Makita factory blade behaves any different.
Old 11-11-2012, 11:39 AM   #8
Wood Craftsman
PrestigeR&D's Avatar
Rewards Points: 4,642
Arrow
Get yourself a GOOD blade, quality.....
Replacing the saw because of a bad performing blade might be an expence you can avoid......
Just saying...
B,
PrestigeR&D is offline
Old 11-11-2012, 11:56 AM   #9
Northwood's Avatar
Rewards Points: 266
Had the same symptoms with my dewalt. Didn't know about ereplacementparts.com and also time sensitive so I had it fixed by dewalt. Expensive and disappointing.
Northwood is offline
Old 11-11-2012, 01:13 PM   #10
Fire up the BBQ
griz's Avatar
Rewards Points: 1,852
Warped blade is a very good possibility. It does not take much to warp them no matter how thick.
Also check between the blade & arbor plate to be certain there isn't a piece of crud in there.
griz is offline
Old 11-11-2012, 04:00 PM   #11
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Is that the CMT ITK Plus blade from Lowes? I have used them and they are good blades, but it doesn't mean your hasn't gotten warped. Most of the time it happens from the saw getting bound up.
PLC Custom Interiors and Woodworking
Lebanon, NJ (908)246-3797
https://www.facebook.com/PunchlistCarpentry?ref=hl
TBFGhost is offline
Old 11-11-2012, 05:41 PM   #12
Trade: carpentry
Rewards Points: 510
No I bought this one from Amazon. The only local place that carries them around me is Cabinetware about $20 more retail. I was in Lowes today and it seems that they've cleared out their CMT stock.
Old 11-12-2012, 04:53 PM   #13
Finish Carpenter
TBFGhost's Avatar
They did, they now carry Irwin "Marples"...
TBFGhost is offline
Old 11-12-2012, 05:21 PM   #14
Kent Whitten's Avatar
Rewards Points: 2,040
You get 8 months out of a blade? Holy ****!
Anything can happen to warp the blade. A kickback can do that.
I used to get Amana blades. There were two different models of the same size, almost exactly the same blade, but one is total junk on a SCMS and the other is top notch. Can't explain how that is.
I am now completely Forrest sawblades for the SCMS.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 11-12-2012, 05:47 PM   #15
Trade: carpentry
Rewards Points: 510
Yes, I have 8 months on this blade. It's still sharp enough to scratch my fingernail. I don't use my miter saw on a daily basis for the 8 months. I had demo, flooring, and framing jobs in between the trim / cabinet installs. I do clean the blade often when I do use the saw, that might make a difference. And I don't cut any rough wood like studs, PT, or plywood other than cabinet plywood.
Update: all is well in Makita 1016 land. I pulled the blade off this morning and behind the last arbor plate was a bit of pitch buildup. Not sure how it got there because the arbor plates get cranked down hard. I wiped it off and made sure to blow the area out with an air chuck. Blade no longer wobbles crazily and cuts true and straight. There is still a tiny bit of vibration at full throttle but it feels the same as when I first got the saw so I think it's normal. The cuts are straight when I flip a test piece over. Thanks for the tips gentlemen.
Old 11-12-2012, 07:41 PM   #16
Wood Craftsman
Arrow
When was the last time you had it professionally sharpened....
B,
Old 11-12-2012, 08:12 PM   #17
Trade: carpentry
Rewards Points: 510
Haven't needed to yet, seriously. I've got a bunch of 12" blades from my old Dewalt saw all freshly sharpened with that waxing around the teeth. I use National Saw Company out of Lakeland FL. Their sales rep, John Huggins, picks up blades from whatever job site you're on. Excellent service.
Old 02-04-2013, 08:44 PM   #18
Trade: carpentry
Rewards Points: 510
Another issue has popped up with my Makita. The miter table detents are "loose". As I swing the table, it'll slide into "0" (or any of the other detents 22.5, 31.6, 45) and the thumb lever pops up. But I have play left and right on each detent...about 1/4 degree left to right. Might not seem like much but it's a big deal for me. I've messed up a few cuts until I realized the problem after first squaring the fence thinking that was the problem. I'm having to lock down the table at each detent now. Any ideas?
I looked underneath the table and basically there's a pin (233 in the diagram) that springs forward into a cut out in the base, maybe that pin is worn out and needs replacement? Anyone else have this happening with their LS1016L?
Old 02-04-2013, 09:59 PM   #19
Craftmark's Avatar
Rewards Points: 250
No I have not had that problem with the detents. Sounds like something is loose or worn.
If your interested in good blades buy a Forrest Chopmaster or a Tenyru miterpro.
Craftmark is offline
The Following User Says Thank You to Craftmark For This Useful Post:
NINZAN STUDIO (02-04-2013)
Old 02-04-2013, 10:02 PM   #20
Wood Craftsman
Arrow
Detents...
B,
The Following User Says Thank You to PrestigeR&D For This Useful Post:
Craftmark (02-05-2013)
saw blade deflection? detroit687 Finish Carpentry 7 05-31-2012 11:21 AM
Need new blade for scms C.M.J. Tools & Equipment 8 05-15-2010 07:12 PM
blade wobble TimPa Tools & Equipment 21 02-19-2010 05:29 PM
Blade Wobble New Miter Saw balanceact Finish Carpentry 7 06-03-2008 08:12 AM
Best Utility Knife Journeyman T Tools & Equipment 48 02-20-2008 08:54 PM
