Makita Does It Again - Page 9 - Tools & Equipment - Contractor Talk
Old 11-30-2018, 02:12 PM   #161
test
cedarboarder's Avatar
Trade: General
Rewards Points: 817
Re: Makita Does It Again
Originally Posted by TimNJ View Post
Isn't the Multi-tool just the toolless model and the tool model?
I have the top one, tooless blade change.
could be I've only seen your model for sale with tooless
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is offline
Old 12-06-2018, 04:48 PM   #162
TimNJ's Avatar
Rewards Points: 852
Bummer.
My new 16ga. nail gun quit driving nails.
Couldn't even get it to sink them in 5/4 WP.
Dropped it off at the Makita Service Center wed. afternoon.
"First time I've seen one of these" says the tech.
OK this sucks.
Dropped off the nail gun at the service center. They called me up Mon. and said they have another one for me because it's so new there are no parts in stock, so I went up there and picked it up.
Today I go to use it to nail on some brickmold and the same thing all over again on the new one they gave me.
Working around the corner from the service center tomorrow. Guy should be glad to see me again
TimNJ is offline
The Following User Says Thank You to TimNJ For This Useful Post:
cedarboarder (12-07-2018)
Old 12-07-2018, 02:36 PM   #163
test
Trade: General
Rewards Points: 817
was having same issue with the razor blades breaking. if you put the blade on an a 45 it won't break as easy
The Following 3 Users Say Thank You to cedarboarder For This Useful Post:
Lettusbee (12-07-2018), Peter_C (12-07-2018), TimNJ (12-07-2018)
Old 12-07-2018, 11:00 PM   #164
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
So what do you think of the tool so far? Is it working with the razor blade? Would you buy it again?
Thanks!
Peter_C is offline
Old 12-07-2018, 11:18 PM   #165
test
Trade: General
Rewards Points: 817
Thanks!
For the one wall it was great. On the other wall was 2 layers of fire rated. Hitting tones of screws breaking tones of razor blades (A wall I just built and the plumbers cut up for no reason). But was a elevator room so need the dust control. Glad I didn't use the expensive blades . Just going to cut at the stud edges next time, then just add blocking.
Going to need some more time with it.
It works until you hit a screw.
I'm going to need some more time with it.
Tomorrow I'll be cutting a ceiling so hopefully that goes better with no screws in the way. Ill have a verdict by tomorrow night
The Following User Says Thank You to cedarboarder For This Useful Post:
Peter_C (12-08-2018)
Old 12-12-2018, 03:13 AM   #166
test
Trade: General
Rewards Points: 817
Used it on the ceiling with the drywall blade works great. Cuts dust and the mess down a great deal. I've been in renovations since a teenage, too many years its been dust mess and drywall in my pocket. almost had tears of joy using it lol.
If you do a decent amount of drywall demo its worth it. This saves the vapor barrier from getting cut up and worth every penny in time saved.
The Following 2 Users Say Thank You to cedarboarder For This Useful Post:
Peter_C (12-13-2018), TRThomas (12-13-2018)
Old 12-13-2018, 12:22 PM   #167
TRThomas's Avatar
Trade: Residential Remodeling/Everything
Rewards Points: 382
I'd recommend trying the Tajima blades out, I've had the same pieces of blade in the saw since I first put them in. They are really hard to snap off when using them in a knife, and they are also really flexible which I think aids in them not breaking when I hit screws. I actually think they cut a little better as the cutting edge gets chipped up. As for cleanliness, nothing I've ever used for cutting drywall compares to this thing with a dust extractor hooked up. I'm hesitant to say it gets 100% of the dust, but its pretty damn close.
TRThomas is offline
The Following User Says Thank You to TRThomas For This Useful Post:
cedarboarder (12-13-2018)
Old 12-14-2018, 02:19 PM   #168
TimNJ's Avatar
Rewards Points: 852
Got a replacement for my 16ga nail gun yesterday.
Test fired about a dozen shots at the service center. 2 1/2" into yellow pine 2x4.
Every one right in and countersunk.
I have half a dozen interior doors to put in tomorrow so I will give it a work out.
Still every time I hit "Upload" to post a picture I get "Failed" message.
TimNJ is offline
Old 12-14-2018, 09:13 PM   #169
test
Trade: General
Rewards Points: 817
Must have more tensile strength , the black heavy duty blades SO brittle oddly
Old 12-15-2018, 08:07 AM   #170
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 54
Resize them till they upload. Had the same thing happen.
goneelkn is offline
Old 12-17-2018, 01:02 PM   #171
TimNJ's Avatar
Rewards Points: 852
Name:  Makita Nailer 1.jpg
Got it.
Photo is two pieces of oak 1x and 2" nail shot through them.
TimNJ is offline
Old 12-17-2018, 02:02 PM   #172
test
Trade: General
Rewards Points: 817
Attachment 471311
Got it.
not sure about the through part haha
Old 12-17-2018, 04:20 PM   #173
test
Trade: General
Rewards Points: 817
oh my bad right through er
TimNJ (12-17-2018)
Old 12-17-2018, 05:30 PM   #174
TimNJ's Avatar
Rewards Points: 852
That's the boards turned up side down to show the nails coming out the back
TimNJ is offline
Old 12-19-2018, 04:57 PM   #175
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,452
bummer ,I got this https://www.amazon.com/SIMPSON-STRON...=simpson+epoxy awhile back .Attempted to use it to drill a hole to mount a hold down in a wall and it is to Large .to wide ,to deep . well this makes this alot less reliable or useful .Have yet to use it to do much .
JFM constr is offline
Old 12-19-2018, 11:31 PM   #176
Peter_C's Avatar
Rewards Points: 412
Honestly I can't imagine trying to drill a hole with what you linked above. I have used it for earthquake retrofitting and tying concrete together.
Peter_C is offline
The Following User Says Thank You to Peter_C For This Useful Post:
TimNJ (12-20-2018)
Old 12-20-2018, 12:22 AM   #177
JFM constr's Avatar
not sure what you are saying.you have the machine/tool and you use it to drill holes in concrete or you cannot imagine using it to drill holes with
Old 12-20-2018, 12:42 AM   #178
Peter_C's Avatar
Rewards Points: 412
I was being a taking your words literally, as I have no idea what "machine/tool" you are discussing. You linked to epoxy and said "You attempted to drill a hole with it", for which the epoxy won't drill very well. Sorry for my failed attempt at humor.
Peter_C is offline
Old 12-20-2018, 11:11 AM   #179
JFM constr's Avatar
https://www.amazon.com/Makita-XRH07Z...y+hammer+drill
oops ,thanks for letting me know .wrong link. this there 9/16" cordless hammer drill
The Following User Says Thank You to JFM constr For This Useful Post:
Peter_C (12-20-2018)
Old 01-03-2019, 08:42 PM   #180
TimNJ's Avatar
Rewards Points: 852
Very interesting:
TimNJ is offline
Makita LS1016L blade wobble after 8 months NINZAN STUDIO Tools & Equipment 55 08-06-2014 04:54 PM
Makita 1016 Gary H Tools & Equipment 30 08-15-2013 02:00 PM
So whats the verdict? Kapex or makita???? CITY DECKS INC Tools & Equipment 532 07-20-2013 07:59 AM
Trade Makita impact? CrpntrFrk Contractor Swap 3 10-29-2012 09:57 PM
Makita cordless deal Gary H Tools & Equipment 8 06-10-2012 10:42 PM
