Looking For A New Compact Vacuum Cleaner - Good Suction Is A Must ! - Tools & Equipment - Contractor Talk
Old 04-06-2013, 12:48 AM   #1
plazaman's Avatar
Rewards Points: 1,262
Currently have 4 Rigid 5 hp/ 6.5 hp vacs and they work very well .
However, i am looking for a compact unit without loosing that suction.
Any suggestions that come to mind?
plazaman is offline
Old 04-06-2013, 01:19 AM   #2
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 76
Re: Looking For A New Compact Vacuum Cleaner - Good Suction Is A Must !
Not sure what you mean by compact.
We run a pro team mega backpack & it's the suckinest vaccum we've ever used.
pinwheel is offline
Old 04-06-2013, 06:46 AM   #3
Nick1001's Avatar
Rewards Points: 201
Rigid sells a small one that has plenty of power. I got it at depot around Christmas on sale for $30.
Nick1001 is offline
The Following User Says Thank You to Nick1001 For This Useful Post:
TAHomeRepairs (04-07-2013)
Old 04-06-2013, 07:37 AM   #4
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
probably should be looking into a self cleaning filter model
Tom Struble is offline
Old 04-06-2013, 09:23 AM   #5
plazaman's Avatar
Compact as in small . I considered the backpack , but I'm looking for something smaller . Something that I could possible move with a tote bin .
plazaman is offline
Old 04-06-2013, 09:31 AM   #6
schaefercs's Avatar
Rewards Points: 520
This is the one I've been using for about 3 years. Small and a very good vacuum.
Looking for a New Compact Vacuum Cleaner - Good Suction is a must !-image-2489069934.jpg
schaefercs is offline
Old 04-06-2013, 10:23 AM   #7
Carolina Surface Prep
Rob1954's Avatar
Trade: Media blasting and residential restoration
Rewards Points: 202
I have the 4 gallon Rigid also. It's a good compromise of smaller size with adequate power. The rectangular shape and low center of gravity makes it easier to store and less likely to tip.
I also have the Dewalt 18v hand vac. Not much on power, but kind of convenient when you just have a little bit of dust to get up and you don't want to drag out the bigger vac. Also nice when there is no power close by.
Rob1954 is offline
Old 04-06-2013, 11:47 AM   #8
Trim Carpenter/Remodeler
Sawdust54's Avatar
Trade: Trim Carpenter/Remodeler
Rewards Points: 25
I have the 4 Gal. Ridgid as well for 5 years...love it!
To him that says it can't be done...get out of the way of the one that's doing it.
Sawdust54 is offline
Old 04-06-2013, 12:00 PM   #9
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
I've had that little guy for 4 years, always use bags with it, amazing little vac.
Inner10 is offline
Old 04-06-2013, 12:08 PM   #10
Lettusbee's Avatar
Rewards Points: 1,910
This is the little ridgid that rocks. I bought one for the crew to use last year, and they both went out and bought themselves one for personal use.
Probably not up to RRP work, but it's great everything that doesn't require a big honkin' sucker.
Looking for a New Compact Vacuum Cleaner - Good Suction is a must !-imag1331-copy.jpg
Lettusbee is online now
Old 04-06-2013, 01:08 PM   #11
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
The little Ridgid is a Great Vacuum. Did you know you can Daisy chain them?
By running two in a series, running a hose from the Exhaust of Vac "A" to the intake of Vac"B", you will not increase the CFM but will almost double the Water column. If you use a "Y" adapter you can almost double the CFM but your water column wont change. This is Super handy if you are using Dust Deputy. uf you need the Xtra CFM for a Plainer use the "Y". If you are wanting to capture the max concrete dust on a cup grinder use the Daisy chain.....
They are on sale right now for less than $40
[email protected] $40 -- $80
dust deputy at amazon $50
16 gal ridgid Vacbody for DD $40 ish
(parts 4,5,10,11) http://ridgidparts.com/cgi-bin/etcTa...ure1&image=Vac
You mount the DD on the Ridgid body and lid
so for $170 you will have an unbeatable setup.
"The key is to allow only the complexity that the customer is willing to pay for."
charimon is offline
The Following User Says Thank You to charimon For This Useful Post:
Tom Struble (04-06-2013)
Old 04-06-2013, 02:58 PM   #12
Dirtywhiteboy's Avatar
Rewards Points: 388
I'm always on the look out for a small unit with good suction
Dirtywhiteboy is online now
Old 04-06-2013, 04:41 PM   #13
Hack
asevereid's Avatar
Rewards Points: 538
Preferably made in China?
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is offline
Old 04-06-2013, 05:13 PM   #14
Roofcheck's Avatar
Trade: Know it all
Rewards Points: 2,054
Like 5'3"?
Roofcheck is offline
Old 04-06-2013, 07:26 PM   #15
Trim40's Avatar
Trade: Guy who plays with wood
Rewards Points: 550
With a flat head, so you have somewhere to rest your beer.
Trim40 is offline
Old 04-06-2013, 08:59 PM   #16
David7586's Avatar
Trade: General
Rewards Points: 185
What would you guys recommend as the best bang for buck for a self cleaning unit? I've always used the rigid line of shop vacs but now looking at the fein or festools.
David7586 is offline
Old 04-06-2013, 09:19 PM   #17
Rewards Points: 388
Well the unit would have to be self cleaning
Schmidt & Co (04-07-2013)
Old 04-06-2013, 11:11 PM   #18
WilsonRMDL's Avatar
Trade: Carpenter/Remodeler
Rewards Points: 532
Festool midi
Innovative Remodeling LLC
Licensed and Insured
WilsonRMDL is offline
Old 04-07-2013, 06:03 AM   #19
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
The ridgids ain't upto much filtration wise so if your worried about wastes coming out the rear of the vac for stuff like RRP and hazoudous dust I would steer clear of ridgid. I have had a few and still have 2 but they never get used on site anymore. The fein and festools are vastly better vacs in every way. I would say check the AC versions of the festool vacs out. They ain't cheap but if you do a lot of work with dust like drywall dust and concrete dust you can't beat the AC vacs.
www.bcconstructionllc.com
BCConstruction is offline
The Following User Says Thank You to BCConstruction For This Useful Post:
David7586 (04-07-2013)
Old 04-07-2013, 10:42 AM   #20
David7586's Avatar
Trade: General
Rewards Points: 185
Thanks for the advice. It definitely seemed like the festool was the way to go but was just hoping someone had another alternative. (Haven't drank that green koolaid yet haha)
how should i approach this issue with my worker? welterweight General Discussion 103 02-19-2013 12:20 AM
Fist fight with owners son...not good davinci Off Topic (Non Trade) 65 06-22-2012 07:49 PM
Looking for a good tile cleaner?? Sellncars Tiling 6 09-03-2006 04:54 PM
What is a good jobsite vacuum? Peladu General Discussion 8 01-13-2006 06:59 PM
