For Lifting Beams? - Tools & Equipment - Contractor Talk
For Lifting Beams?
Old 09-15-2019, 12:29 PM   #1
GC/carpenter
Calidecks's Avatar
Rewards Points: 2,722
For Lifting Beams?
says 89 bucks. What say you? To good to be true?
https://carfila.com/products/pht-140...z_cTa16h302Guc
Mike.
_______________
Calidecks is offline
Old 09-15-2019, 12:35 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 368
Re: For Lifting Beams?
don't see where it will give you any height.
also seems kind of light weight.
griz is offline
Old 09-15-2019, 12:40 PM   #3
Radical Basement Dweller
Robie's Avatar
Rewards Points: 5,310
If you tell the truth, you don't have to remember anything.
Mark Twain
Robie is offline
Old 09-15-2019, 12:49 PM   #4
tgeb's Avatar
Rewards Points: 314
I was going to guess a max lift height of about 5 feet, the video puts lift height at 6 feet to the hook.
Unless you are using it to pick up beams and move them around a pretty flat site, I don't see much benefit for beams, certainly not for setting beams at any height.
www.gebcon.com
tgeb is online now
Old 09-15-2019, 12:49 PM   #5
Fire up the BBQ
griz's Avatar
Rewards Points: 368
must be used on a hard flat surface only would be a deal breaker for me.
griz is offline
The Following 3 Users Say Thank You to griz For This Useful Post:
hdavis (09-15-2019), Robie (09-15-2019), tgeb (09-15-2019)
Old 09-15-2019, 01:45 PM   #6
GC/carpenter
Calidecks's Avatar
I'd use it to transport the beam to my beam lift or on a cart.
Mike.
_______________
Old 09-15-2019, 01:46 PM   #7
GC/carpenter
Calidecks's Avatar
Holds 308 lbs. Meaning it will probably hold 400 lbs lol
Mike.
_______________
Old 09-15-2019, 02:18 PM   #8
hdavis's Avatar
Rewards Points: 1,526
Mike.
_______________
Too good to be true for a $4400 piece of equipment
hdavis is offline
Calidecks (09-15-2019), Golden view (09-15-2019)
Old 09-15-2019, 02:20 PM   #9
GC/carpenter
Calidecks's Avatar
Originally Posted by hdavis View Post
Roo good to be true for a $4400 piece of equipment
Two different companies as well.
Mike.
_______________
hdavis (09-15-2019)
Old 09-15-2019, 02:24 PM   #10
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 530
extra tool to haul, set up, hook to beam, get stuck on a curb, etc. Have your guys haul the beam. Sometimes working smarter IS working harder.
Golden view is offline
griz (09-15-2019)
Old 09-15-2019, 02:28 PM   #11
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 28
Mike.
_______________
We usually use those roller dollies for getting the beams to the locations.
Easy Gibson
Warren is online now
The Following User Says Thank You to Warren For This Useful Post:
Old 09-15-2019, 02:35 PM   #12
tgeb's Avatar
Rewards Points: 314
Mike.
_______________
It could hold even more, if you've got the right fat guy on the handles.
www.gebcon.com
tgeb is online now
The Following 3 Users Say Thank You to tgeb For This Useful Post:
Calidecks (09-15-2019), griz (09-15-2019), hdavis (09-15-2019)
Old 09-15-2019, 02:40 PM   #13
GC/carpenter
Calidecks's Avatar
I use a drywall cart. But getting it on the cart can be a bitch when dealing with a 20' 7x14 PSL.
Mike.
_______________
Old 09-15-2019, 02:41 PM   #14
GC/carpenter
Calidecks's Avatar
20' 7x14, 4 of them.
Mike.
_______________
Old 09-15-2019, 02:53 PM   #15
KAP's Avatar
Trade: Custom
Rewards Points: 36,588
KAP is offline
The Following 2 Users Say Thank You to KAP For This Useful Post:
A&E Exteriors (09-15-2019), Defenestrate (09-15-2019)
Old 09-15-2019, 04:40 PM   #16
Dan_Watson's Avatar
Rewards Points: 2,746
We use these.
https://www.northerntool.com/shop/to...-_-1206-_-CONF
For lifting beams?-2019-03-29-15.42.15.jpg   For lifting beams?-2019-03-29-12.45.22-2-.jpg
Dan_Watson is offline
The Following 2 Users Say Thank You to Dan_Watson For This Useful Post:
Calidecks (09-15-2019), TheConstruct (09-17-2019)
Old 09-15-2019, 04:54 PM   #17
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 510
For $90 you might as well give it a try.
It even uses a makita battery. I think I have to have one.
Big Johnson is offline
Old 09-15-2019, 07:15 PM   #18
GC/carpenter
Calidecks's Avatar
We use this. Makes easy work out of turning corners. I put 4 swivels on it.
Mike.
_______________
The Following 2 Users Say Thank You to Calidecks For This Useful Post:
hdavis (09-15-2019), TheConstruct (09-17-2019)
Old 09-15-2019, 09:13 PM   #19
TheConstruct's Avatar
Rewards Points: 1,366
Sheesh, what every happened to just blowing out your back like a real man?
TheConstruct is offline
The Following 4 Users Say Thank You to TheConstruct For This Useful Post:
Calidecks (09-15-2019), DaVinciRemodel (09-17-2019), Morning Wood (09-16-2019), TRThomas (09-21-2019)
