Job Site Trailers, Show Off Your Set Ups! - Page 109 - Tools & Equipment - Contractor Talk
Old 01-15-2016, 02:15 PM   #2161
kixnbux's Avatar
Rewards Points: 1,440
Re: Job Site Trailers, Show Off Your Set Ups!
I wouldn't consider barn doors myself. Love my ramp. Rolling table saw in, two wheelers with heavy items. I work alone a lot so ease of loading larger things is a big plus for me. If I need a door I just use the side. Can even put blocks under the end of the ramp and have a decent instant table if needed.
kixnbux is offline
Old 01-15-2016, 02:27 PM   #2162
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
My mates a contractor who I help out a bit and he said he wouldn't get a V nose next time. He said it's the most useless piece of space to have. He's buying something bigger now and no v nose this time around.
There's just no way to make good use of the space. Instead just buy the model that's the right length.
www.bcconstructionllc.com
BCConstruction is offline
The Following User Says Thank You to BCConstruction For This Useful Post:
Randy Bush (01-15-2016)
Old 01-15-2016, 02:32 PM   #2163
kixnbux's Avatar
I like mine. I'd hardly call that space useless. Definitely better than tongue space I'd say.
kixnbux is offline
Old 01-15-2016, 02:37 PM   #2164
Trade: Construction
To me that's a lot of wasted space. I have way more in the front of my flat front trailer. A lot more infact. There's really no good way to make use of that space. If it was me And I had a 14ft trailer with a 2ft V I would rather just have a 16ft trailer with flat front. That way you can make use of that space.
Old 01-15-2016, 02:49 PM   #2165
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,966
Another reason I like flat is the v on tongue is where my LP bottles are mounted,
Sent from my LG-V410 using Tapatalk
Randy Bush is offline
Old 01-15-2016, 02:53 PM   #2166
AGullion's Avatar
Rewards Points: 1,422
I think of it as free , extra space .
AGullion is offline
Old 01-15-2016, 02:54 PM   #2167
Trade: Construction
They cost more though so how are they free
Old 01-15-2016, 02:55 PM   #2168
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,706
It's something to do with the low pressure air behind the trailer. Kind of how a wing works. High pressure in the front low at the back. It sucks the trailer backwards and require way more HP. Ideally you want a smoother transition in the front and back and the truck being in front of the trailer helps this a lot but on the back there's nothing. You ever seen them trucks with the weird looking ends on them.
These things
That greatly reduces the turbulence behind a semi.
Makes a good place to nose into with a load on a trailer behind me.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 01-15-2016, 02:56 PM   #2169
I like Green things
I also prefer a flat front enclosed trailer.
Warner Mill Works
Facebook
YouTube
Old 01-15-2016, 02:56 PM   #2170
kixnbux's Avatar
It gives me a lot bigger opening when walking in the side door. I checked out a lot of flat fronts. I didn't like em. Even pulled one. Wind resistance whatever your reasoning is either way, for me was definitely far less also.
kixnbux is offline
Old 01-15-2016, 02:58 PM   #2171
AGullion's Avatar
Mine didn't . 7x 14 , dual axle $2100
AGullion is offline
Old 01-15-2016, 02:58 PM   #2172
I like Green things
The side doors can be put wherever you want.
Warner Mill Works
Facebook
YouTube
Old 01-15-2016, 03:00 PM   #2173
AGullion's Avatar
I 've seen some that open on the v
AGullion is offline
Old 01-15-2016, 03:03 PM   #2174
I like Green things
Snowmobile trailers typically.
Warner Mill Works
Facebook
YouTube
Old 01-15-2016, 03:04 PM   #2175
kixnbux's Avatar
Now that could be interesting. Full length insides would be available
kixnbux is offline
Old 01-15-2016, 03:06 PM   #2176
Trade: Construction
So how much was the flat front? On the ones i looked at it was anything from $300-$800 extra depending on model from what i remember. $2100 sure is cheap for a trailer though. Think mine was $6500 for same size.
Old 01-15-2016, 03:17 PM   #2177
AGullion's Avatar
Never priced one . This one was used, a 2009 , you can see a tour of it under Andy's Amazing Trailer on tools of the Trade ....its really set up a lot better now.
AGullion is offline
Old 01-15-2016, 03:27 PM   #2178
Owner/Craftsman
OVContractor's Avatar
Trade: Sightline Construction & Renovations Inc.
Rewards Points: 180
My V has two ladders, broom, level, shop vac wand, desk for plans, empty boxes and bags for tool transport, work light, and space for my shop vac to roll under when its not in the house.
I still plan on installing a closed cabinet above the desk height shelf for storage of plans, coffee, etc.
Space is only inefficient if you plan on using it inefficiently
Job site trailers, show off your set ups!-1452889269348.jpg   Job site trailers, show off your set ups!-1452889420388.jpg
OVContractor is offline
Old 01-15-2016, 03:28 PM   #2179
Owner/Craftsman
Rewards Points: 180
It just occurred to me that mud flaps might be a sage investment
The Following User Says Thank You to OVContractor For This Useful Post:
shanewreckd (01-15-2016)
Old 01-15-2016, 03:37 PM   #2180
Trade: Construction
This picture again is a prime example of why they are pointless. It's like no one knows what on earth to do with the area
New to site cjmueller08 New Member Introductions 2 10-24-2008 12:51 PM
New to site from Ca. highlands New Member Introductions 1 10-24-2008 08:19 AM
worlds greatest show truck dlcj Off Topic (Non Trade) 6 02-17-2008 10:23 AM
PLEASE READ: A Quick Note From Nathan Nathan General Discussion 39 10-23-2007 11:25 AM
