Job Site Trailers, Show Off Your Set Ups! - Page 104 - Tools & Equipment - Contractor Talk
Old 12-17-2015, 07:17 AM   #2061
builditguy's Avatar
Rewards Points: 2,066
Re: Job Site Trailers, Show Off Your Set Ups!
Looking for a suggestion on lights.
My trailer is 8' x 18'. I keep my brake (10'6") set up on the driver's side, all the time. I bend aluminum inside the trailer.
Currently I have 2 fluorescent work lights set up. They don't work the best. It creates shadows and glares on the aluminum that make it a little difficult to see my marks.
I purchased 2 LED shop lights. Now I'm thinking they are too bright for the small space. I have 2 in my 2 car garage and they light it up just fine. So for a smaller space, I think I would have to wear sunglasses inside the trailer.
In the above pics, it appears he has used LED strip lights. About 4 rows. I don't think this will work for me because the ribs of the trailer are exposed. I think the strips will sag between the ribs. I thought about running the strips on top of the ribs. The 8' direction all the way down. Not knowing much about the way the strips are set up, I don't know if I could wire them in that way. I doubt it.
As far as electrical, currently I plug in my trailer, run 2 lights, a radio, and a tower heater.
Unless someone has a better idea, I will probably return the shop lights I purchased and get 2 lights that are single strip LED.
I appreciate the help.
builditguy is offline
Old 12-17-2015, 07:59 AM   #2062
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 942
If you mean you'd want to run them perpendicular to the ribs, put up some furring strips and mount them on those. They usually come with a self-adhesive backing, though reviews on the ones I got said it wasn't all that great. For insurance, I used 3M double-sided tape.
In my van, two strips would be plenty for seeing those pencil marks. Might take a couple more in a trailer.
Tinstaafl is online now
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
brhokel606 (12-17-2015), builditguy (12-18-2015), TNTRenovate (12-17-2015)
Old 12-18-2015, 12:03 AM   #2063
98crewcab's Avatar
Trade: General contractor
Rewards Points: 488
finally added some puck lighting.....was tired of using the flash light to access the trailer at night:/
a $30 set of 6 puck lights
98crewcab is offline
The Following 4 Users Say Thank You to 98crewcab For This Useful Post:
builditguy (12-18-2015), Spencer (12-18-2015), thehockeydman (12-18-2015), TNTRenovate (12-18-2015)
Old 12-18-2015, 07:06 AM   #2064
builditguy's Avatar
That's a good idea about furring strips. I have about 6'8" of inside height so I could do it and it wouldn't be too low.
I did some research on the light strips. Looks like you cut them to the length you want. Then there is a connector that pinches the end. They are labeled positive and negative. The connector then wires into a voltage reducer. Definitely seems like a possibility.
I never painted the inside of my trailer. Your van is white on the inside. My trailer is aged plywood brown. I should have painted it.
Although I like the LED strips. I think I will just return the lights with the double rows of LED and get lights with a single row of LED. For myself. It will be a lot easier to install.
Thank you for your input.
Old 12-18-2015, 07:50 AM   #2065
Owner/Craftsman
OVContractor's Avatar
Trade: Sightline Construction & Renovations Inc.
Rewards Points: 180
Started first phase of the new trailer build.
Definitely need to thank everyone on here for sharing all of their great design ideas; Spencer has been a big influence and of course Ron Paulk has made a big impact on layout.
Had my buddy over last night, he's an industrial electrician and an artist with conduit. Went over the layout for electrical and planned phase two.
Job site trailers, show off your set ups!-1450442905813.jpg   Job site trailers, show off your set ups!-1450442963717.jpg   Job site trailers, show off your set ups!-1450443008582.jpg   Job site trailers, show off your set ups!-1450443020727.jpg
OVContractor is offline
The Following 3 Users Say Thank You to OVContractor For This Useful Post:
98crewcab (12-19-2015), Spencer (12-20-2015), TxElectrician (12-18-2015)
Old 12-18-2015, 08:08 AM   #2066
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,502
Looking good.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
OVContractor (12-18-2015)
Old 12-18-2015, 08:09 AM   #2067
kixnbux's Avatar
Rewards Points: 1,440
Looks sharp! Hopefully next year I can pick up another trailer and put everything I learned building my current one to use in a re design of my next
kixnbux is offline
The Following User Says Thank You to kixnbux For This Useful Post:
Old 12-19-2015, 06:19 PM   #2068
SectorSecurity's Avatar
Trade: Low Voltage Wiring
Rewards Points: 2,828
I would try to build some shelves like I see here, but mine would turn out like this:
SectorSecurity is offline
The Following User Says Thank You to SectorSecurity For This Useful Post:
OVContractor (12-20-2015)
Old 12-20-2015, 10:51 AM   #2069
iceman61's Avatar
Trade: Remodeling, Roofing, Siding
Rewards Points: 115
I used small cut pieces of 1/4" thick lattice between the ribs and roof skin on mine. After those were installed I ran two 16ft strips of 5630 LEDs from front to back on my 16 footer. I'm thinking about two more strips and getting a single power supply to run those plus a 20" LED bar at the outside top of the back door. Two LED bars creates plenty of light but placement of just two creates shadows. Four would knock that out, but we never work inside the trailer.
My guys expressed interest in working inside the trailer until summer came and they changed their minds. I used 3M double sided carpet tape to attach my lights but the jury is still out on how long that will hold. That stuff is very sticky though.
iceman61 is offline
Old 12-20-2015, 05:26 PM   #2070
builditguy's Avatar
I have a fan set up in the front, hanging close to the ceiling. The heat hasn't been an issue for me, but the only thing I do, in the trailer, is bend aluminum.
Old 01-03-2016, 12:42 PM   #2071
BrooklynBravest's Avatar
Trade: Carpentry - Welding/Fabrication
Rewards Points: 804
So I think I am going to pick up my first trailer tomorrow.
A van is out of my price range right now and I need something to get my business off the ground.
Best I found locally was a brand new "Wells Cargo" 6x10, with side door and rear ramp, bull nose front not a full V.
Its $3150.
I am only doing finish carpentry so I need it to fit 8' boards from time to time and hold my tools. It has to fit in my driveway with 2 cars so a larger unit is not really doable.
Here is my plan for it.
What you guys think?
Job site trailers, show off your set ups!-trailer.jpg   Job site trailers, show off your set ups!-trailer-2.jpg
BrooklynBravest is offline
The Following 2 Users Say Thank You to BrooklynBravest For This Useful Post:
charimon (01-03-2016), The.Handyman (01-03-2016)
Old 01-03-2016, 12:48 PM   #2072
kixnbux's Avatar
Got some New Years trailer cleaning and organizing done!
kixnbux is offline
The Following 5 Users Say Thank You to kixnbux For This Useful Post:
brhokel606 (01-03-2016), charimon (01-03-2016), OVContractor (01-03-2016), TaylorMadeAB (01-04-2016), The.Handyman (01-03-2016)
Old 01-04-2016, 01:34 PM   #2073
AGullion's Avatar
Rewards Points: 1,422
Man that looks good.
AGullion is offline
Old 01-04-2016, 01:49 PM   #2074
TaylorMadeAB's Avatar
Trade: Renovations
Rewards Points: 1,686
Its $3150.
Nice job on the drawing!
I'm sure your needs are different than mine, but I have found that you need a large area for fastener storage. Every little box of screws, nails, Brads, etc takes up a lot of space. And if you want to be able to find anything in there, it needs to be organized.
Also do you need sawhorses and step ladders?
TaylorMadeAB is offline
The Following User Says Thank You to TaylorMadeAB For This Useful Post:
OVContractor (01-06-2016)
Old 01-04-2016, 01:51 PM   #2075
Trade: Renovations
What size of trailer is that?
Have you had any issues with keeping your cordless tools in one shelf like that, as opposed to individual slots for each tool?
Old 01-04-2016, 01:59 PM   #2076
kixnbux's Avatar
21' V nose. I tried having my cordless tools in slots and in boxes also but I prefer the ones that I use constantly all day to be right straight in from the door and in plain view. Just faster for me I guess
kixnbux is offline
Old 01-04-2016, 03:56 PM   #2077
Trade: Renovations
Ya makes sense.
Do you find it hard to park that long of a trailer on the job sites?
Old 01-04-2016, 03:58 PM   #2078
kixnbux's Avatar
Ya makes sense.
I'll say it's usually all a person can fit between two driveways
kixnbux is offline
Old 01-04-2016, 04:52 PM   #2079
Trade: Renovations
No kidding, some new developments here barely have room to park one full size truck.
In the last 2 years I can only count a handful of times that I wouldn't have been able to park a long trailer at my job. With my truck which is 20', plus a 16' trailer and tongue, you're looking at 40'+ of rig to park.
Old 01-04-2016, 04:57 PM   #2080
kixnbux's Avatar
That's about right. Around here I usually fit by a couple feet but that's it. If someone parks in your way it's rough
kixnbux is offline
New to site cjmueller08 New Member Introductions 2 10-24-2008 12:51 PM
New to site from Ca. highlands New Member Introductions 1 10-24-2008 08:19 AM
worlds greatest show truck dlcj Off Topic (Non Trade) 6 02-17-2008 10:23 AM
PLEASE READ: A Quick Note From Nathan Nathan General Discussion 39 10-23-2007 11:25 AM
