Job Site Trailers, Show Off Your Set Ups! - Page 102 - Tools & Equipment - Contractor Talk
Old 09-30-2015, 10:44 PM   #2021
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
Re: Job Site Trailers, Show Off Your Set Ups!
OK so I bought a new tool trailer. Tools only no material ever. . . Yeah Right we all know that it will get filled up with trash and you wont be able to get to anything. Well I am going to try something different. A dense pack tool trailer. I special ordered a 5'x8' enclosed trailer added 1' height and side doors on both sides and a ramp on the back. The front 1/2 will be shelved to the ceiling with access only from the doors.
I have 3 types of storage
Systainers,
Brute boxes
Rigid boxes
They all map strangely together 3 Rigid boxes are the same sf foot print as 2 Brute boxes and 2 systainers are the same foot print as a Brute Box
Brute boxes will fit in a 11" high opening while Rigid and Sys 4 's will fit in a 13" tall space.
so here are some pics of the new trailer and my first couple shelving setups.
When I am finished the whole trailer will be full but accessible with every tool I use in 95% of my jobs.
Contractor talk pic editor is drunk tonight
Job site trailers, show off your set ups!-ncm_0046.jpg   Job site trailers, show off your set ups!-ncm_0047.jpg   Job site trailers, show off your set ups!-ncm_0103.jpg   Job site trailers, show off your set ups!-ncm_0139.jpg   Job site trailers, show off your set ups!-ncm_0140.jpg
charimon is offline
The Following 2 Users Say Thank You to charimon For This Useful Post:
overanalyze (09-30-2015), Xtrememtnbiker (10-01-2015)
Old 09-30-2015, 10:52 PM   #2022
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 954
That is cool! I didn't know you could do doors on both sides!
overanalyze is online now
Old 09-30-2015, 11:03 PM   #2023
AGullion's Avatar
Rewards Points: 1,422
How do you like it? I can't seem to deal with many tools in cases, except my track saw and few things.
I love a tall trailer and a ramp door . looks like some pullouts would be good on that side access.
I 've thought a lot of times a small trailer would work well if thought out.
AGullion is offline
Old 09-30-2015, 11:20 PM   #2024
charimon's Avatar
I am taking the next couple days off and working on it to get it set up. and it is my birthday on Friday. I wanted a small trailer that I could access everything from standing on the outside. We use floor grinders that are several hundred pounds so I needed a ramp access in back for when I need to bring them to the jobsite. The next layer of shelves will be the wild one, it is the one that will house my big tile cutters, large dustless cup grinders and other tools that do not fit into any of the boxes that I am using. I will post more pics tomorrow.
charimon is offline
Old 10-01-2015, 05:45 PM   #2025
charimon's Avatar
more pics
Job site trailers, show off your set ups!-ncm_0145.jpg   Job site trailers, show off your set ups!-g.jpg   Job site trailers, show off your set ups!-ncm_0146.jpg   Job site trailers, show off your set ups!-ncm_0147.jpg   Job site trailers, show off your set ups!-ncm_0148.jpg
charimon is offline
Old 10-01-2015, 06:09 PM   #2026
AGullion's Avatar
Tell me about those floor grinders guy...I 've been leveling a slab...lot of grinding
AGullion is offline
Old 10-01-2015, 06:28 PM   #2027
charimon's Avatar
Edco TG-10 10" Turbo Grinder
The TG-10 is four times faster than conventional grinders.
Production Rate:
10" Working width will grind approximately 400-500 square ft per hour at 1/16" with an Edco diamond disc
Grind wet or dry.
Rounded shroud allows you to grind within 1/2 of any vertical surface and also provides better dust control
Less torque on operator
Tapered roller bearings have improved seals for longer life and less maintenance.
Rigid Head Assembly Is Ideal For:
Grinding uneven expansion joints, high spots, joint curls and bridge decks
Removing coatings
It is a great grinder for residential It is not a planetary so it will not do hyper floors, but for prep it is the most aggressive that you can bring down a staircase while being able to run off a dryer outlet.
Grinding rough concrete surfaces
charimon is offline
Old 10-01-2015, 06:32 PM   #2028
AGullion's Avatar
Cool, just spent 1500/on a grinding service ...ouch . I ended up getting up a laser, putting a guide rod on the machine and marked it so operator new how far to cut floor down .
AGullion is offline
The Following User Says Thank You to AGullion For This Useful Post:
charimon (10-02-2015)
Old 10-09-2015, 07:40 PM   #2029
rtb1989's Avatar
Trade: Concrete
Originally Posted by AtlanticWBConst View Post
This is the trailer that I primarily use. The pics are from Last year.
will say the catch all on top left is a great idea. great place for all them flexible forms odds and ends
rtb1989 is offline
Old 10-20-2015, 10:15 PM   #2030
CFDChief's Avatar
Trade: Residential
I went from a 14' single axle trailer to a 18' v nose tandem axle back in January, the back tires are wearing considerably faster than the front tires. Has anyone else experienced this? I'm sure the factory tires are the cheapest they can buy but I don't have any odd wear issues with any of my other tandem non enclosed utility trailers.
CFDChief is offline
Old 10-20-2015, 10:22 PM   #2031
kixnbux's Avatar
Rewards Points: 1,440
My 21' V Nose is doing that same thing. Actually broke the spring from the trailer frame on the far back of both sides just backing into a job one day. Weighed the trailer and it's far from weight capacity so I don't know. Making me mad though
21' cargo craft v nose
kixnbux is offline
Old 10-20-2015, 11:11 PM   #2032
Love me some Concrete
brhokel606's Avatar
Rewards Points: 4,113
How much weight is on the back part? The only way for the tires to wear like that is improper weight distribution or you have the tongue to high. It is a delicate balancing act between little tongue weight and not to much on a one side or the other. If you broke a spring, the weight is to high on that axle. You are going to have too weigh things and move them around, just cause you are under weight means nothing if you have 5k on back axle and 1k on front axle.
I know I'm crazy...I love concrete
brhokel606 is offline
Old 10-20-2015, 11:17 PM   #2033
brhokel606's Avatar
Also, if you are doing alot of sharp cornering it will wear the back tires as they slide when cornering sharp, the front ones roll and the trailer pivots on the front ones, makes the back tires slide. Also check your air pressure in each tire, make sure they are at recommended PSI.
Old 10-21-2015, 08:54 PM   #2034
CFDChief's Avatar
Trade: Residential
Air pressures are checked regularly and as far as weight placement I would say if anything it would be a little heavy on the front not the back. I hope its just caused by turning on city streets and not an axle out of alignment.
CFDChief is offline
Old 10-21-2015, 09:28 PM   #2035
Radical Basement Dweller
Robie's Avatar
Rewards Points: 34
Handy gadget.....available on Amazon
http://www.sherline.com/lm.htm
Plus, the state police here told me to call them and they would let me know where their mobile weigh stations were going to be set up and they would be happy to weigh front/back/left/right of the trailer at no charge.
When the debate is lost, slander becomes the tool of the losers.
Robie is online now
brhokel606 (10-21-2015)
Old 11-03-2015, 09:22 PM   #2036
Pau@CleanCut's Avatar
Trade: TreeService
Rewards Points: 4
We have 6 Tandem axle trailers and they ALL wear the back tires much sooner than the fronts. It is because every time you turn the back tires just slide, and peel that rubber off. We have tried adjusting loads, raising the tongue (2 are gooseneck, 4 bumper pull) and adjusting tire pressures. All of this was a waste of time, just get used to the fact that once the rear tires are down to about 1/3 of treads, rotate all 4 and you will have about twice the amount of time, than if you don't rotate!
Pau@CleanCut is offline
The Following 3 Users Say Thank You to [email protected] For This Useful Post:
CFDChief (11-05-2015), JohnnyRad (01-03-2016), TxElectrician (11-04-2015)
Old 11-05-2015, 12:09 PM   #2037
98crewcab's Avatar
Trade: General contractor
Rewards Points: 488
my rears would do the same, then with the new set of tires, i adjusted the hitch so that the trailer would ride level (was tongue low on the last set of tires) and now seems to be wearing evenly......
with the tongue low, the rears would drag around more, now they have closer to equal resistance before "giving out" and dragging
98crewcab is offline
The Following User Says Thank You to 98crewcab For This Useful Post:
Old 11-07-2015, 11:54 AM   #2038
totes's Avatar
Rewards Points: 910
3 storage solutions in my trailer that have been working well for me.
Job site trailers, show off your set ups!-img_9093.jpg   Job site trailers, show off your set ups!-img_9094.jpg   Job site trailers, show off your set ups!-img_9095.jpg
"faster horses, younger women, older whiskey, and more money"
totes is offline
The Following 6 Users Say Thank You to totes For This Useful Post:
CFDChief (11-07-2015), masterofsome (11-09-2015), OVContractor (11-08-2015), overanalyze (11-07-2015), Spencer (11-08-2015), TNTRenovate (11-07-2015)
Old 11-08-2015, 07:21 PM   #2039
Owner/Craftsman
OVContractor's Avatar
Trade: Sightline Construction & Renovations Inc.
Rewards Points: 180
Just bought my first trailer this summer, a 7'x14' Titan by Stealth. This winters project will be to get it set up as a mobile tool box by the spring rush. I found some great videos by Ron Paulk about his trailer set up but this forum has had a TON of great tips too.
I'm upgrading from a converted GMC minivan I had decked out with shelves and storage so it's going to be a dramatic change.
I'll post progress shots as it comes together and try to make sure I give the proper shout outs for canabalised ideas
OVContractor is offline
The Following User Says Thank You to OVContractor For This Useful Post:
charimon (11-09-2015)
Old 11-09-2015, 06:56 PM   #2040
totes's Avatar
Rewards Points: 910
I want to keep my trailer above freezing overnights, to protect glue, paint, caulk, ect.
My space heaters lowest setting is 55f degrees, but for energy conservation I only want the heater to kick on at 35f degrees or so.
Has anyone integrated a feature like this in their trailer? I could use some ideas or a good off the shelf thermostat for this particular need.
totes is offline
New to site cjmueller08 New Member Introductions 2 10-24-2008 12:51 PM
New to site from Ca. highlands New Member Introductions 1 10-24-2008 08:19 AM
worlds greatest show truck dlcj Off Topic (Non Trade) 6 02-17-2008 10:23 AM
PLEASE READ: A Quick Note From Nathan Nathan General Discussion 39 10-23-2007 11:25 AM
