Jetline Vs Chalk Line Vs Mason Twine - Tools & Equipment - Contractor Talk
Old 04-27-2018, 10:03 PM   #1
trevorwastrevor's Avatar
Rewards Points: 30
About to build a 1500' fence for horse pastures. The pasture is somewhat hilly. The homeowner does not want the fence to follow the land but instead create straight runs in between major elevation changes and corner posts. In the past when building these kinds of fences I've used either jetline or chalk line mark the top of post and rail lines. Usually the elevation changed enough that every line of fence wasn't much longer than 40' - 75'.
On the fence that I'm about to do i have couple runs 100' - 150'. I'd like to use mason twine and chalk line for everything because jet line is hard to see. Does anyone have a mason twine brand or chalk line they swear by that doesn't sag much? And while I'm asking, anyone know how much either of these 3 kinds of lines sag on average (per 50' or something)? thanks everyone
trevorwastrevor is offline
Old 04-28-2018, 07:40 AM   #2
Fugetaboutit
Lunicy's Avatar
Trade: Professional fixer upper
Rewards Points: 444
Re: Jetline Vs Chalk Line Vs Mason Twine
If your longest run is about 150', I'd go with a laser. (It helps that I already own one)
Failing that, I'd use a water level.
No sag in either.
Lunicy is offline
Old 04-28-2018, 07:45 AM   #3
Rewards Points: 30
No sag in either.
I would use a laser or a transit if i needed a level line. i don't need a level line though. I need a straight line from point A to point B, 150' apart and they are different elevations. thanks
Old 04-28-2018, 08:39 AM   #4
tgeb's Avatar
Rewards Points: 4
You can still use a laser. Some lasers can be set for slope. 100-150 feet with a stringline I would be more concerned about which way the wind is blowing.
www.gebcon.com
tgeb is online now
Old 04-28-2018, 09:31 AM   #5
Rewards Points: 30
Any specific brand of laser you like that can be set at an angle? Ive always tried to stay away from lasers outside except for when i am using a receiver simply because they are hard to see.
Old 04-28-2018, 10:31 AM   #6
Railman's Avatar
Trade: Railing
Rewards Points: 631
On 100ft & mason line, figure about 1/4" sag & you'll be plenty close for a fence.
Railman is online now
The Following User Says Thank You to Railman For This Useful Post:
Deckhead (04-29-2018)
Old 04-28-2018, 11:55 AM   #7
Texas Wax's Avatar
Rewards Points: 1,886
Any laser that has manual adjustments for level. Set a bench mark same height at each end and adjust the laser's beam to cross both. Works best to have laser very close to one end.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
Running new gas line madrina Plumbing 30 05-01-2014 08:09 PM
Basement pump - Tying house to septic line GTHill Plumbing 6 11-16-2013 03:02 PM
When the thin blue line becomes black killzoneq2 Sandblasting 6 04-24-2013 04:33 PM
Clogged oil line Leo G HVAC 13 02-19-2011 09:36 PM
What size and kind of service line? help !!! mebedave Plumbing 10 10-31-2010 02:41 PM
