Its A Festool Easter - Tools & Equipment - Contractor Talk
Old 04-01-2013, 08:03 AM   #1
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Just woke up and had this lot waiting for me for my CMS. Got here from the UK in one piece as well. Just need to get them home so I can test them out.
Really interested in seeing how well the ts75 works as a table saw.
Will post some reviews when I get a chance.
www.bcconstructionllc.com
BCConstruction is offline
The Following 2 Users Say Thank You to BCConstruction For This Useful Post:
jhark123 (04-01-2013), moorewarner (04-01-2013)
Old 04-01-2013, 10:53 AM   #2
Five Star's Avatar
Rewards Points: 1,010
Re: Its A Festool Easter
It's a festivis miricle
The Bitterness of Poor Quality Remains longer
Than The Sweetness Of A Low Price Is Forgotten
Five Star is offline
The Following 2 Users Say Thank You to Five Star For This Useful Post:
BCConstruction (04-01-2013), moorewarner (04-01-2013)
Old 04-01-2013, 01:24 PM   #3
trowlan1's Avatar
Trade: Project Management Consulting
Rewards Points: 25
I wonder if he got it after the Feats of Strength or The Airing of the Grievances, haha
trowlan1 is offline
The Following User Says Thank You to trowlan1 For This Useful Post:
Five Star (04-01-2013)
Old 04-01-2013, 05:18 PM   #4
BBuild's Avatar
Trade: Remodeling & repair
Rewards Points: 1,100
nice score Is that the saw blade bag?
BBuild is offline
Old 04-01-2013, 05:25 PM   #5
Trade: Construction
Yep that's the bag for the Kapex blades. Sure it can hold my ts55 and 75 blades also.
Old 04-01-2013, 05:41 PM   #6
Fortune and glory, kid.
moorewarner's Avatar
Trade: Remodeler/Restorer
Rewards Points: 1,022
Really curious to hear the updates on this. Do you/will you run the router in a cms? If so which router?
"If you don't have time to do it right, when are you going to have time to do it over?" ~ Wise Old Timer
moorewarner is offline
Old 04-01-2013, 05:47 PM   #7
Trade: Construction
Yep I also have the router insert for the CMS but its the table saw setup I was more interested in. I may just use my OF1400 or I may get the 2200 just so I can leave it in the table.
Old 04-01-2013, 06:12 PM   #8
Several questions...
How would you hook up that 2200 (same set-up I am after), parts from over seas or homebrew?
Are you going to run a ts-55 or 75 in that?
Do you have to make any electrical adjustments to the stock parts?
How did you get over seas parts?
Are you running 2 CMSs, one for router and one for TS or swapping?
Old 04-01-2013, 06:16 PM   #9
Since it is a Festool CMS setup it requires both.
Old 04-01-2013, 06:21 PM   #10
Trade: Construction
I'm not sure exactly why it can't take the 2200 but I have seen 2200 running in them in the uk and us. I have installed a 2200 into the insert my self but not run it. I may be fine with the 1400 but I might just get the 2200 so I have both.
As far as I can see so far the 55 will not fit into the 75 insert.
I will be swapping the inserts out as needed. It's gonna be 99% table saw as I do have a MFT with a custom router table insert already made.
The Following User Says Thank You to BCConstruction For This Useful Post:
Old 04-01-2013, 06:26 PM   #11
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,744
There is some sort of pin missing for the 2200, or something like that.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 04-01-2013, 06:30 PM   #12
tjbnwi's Avatar
Rewards Points: 1,604
The magnetic switch on the CMS is not rated to carry the 2200 load. Due to this, the unit was not UL tested for the 2200. Next question is-Why not change the switch?- Well, then the plug needs to be a 5-20. They have gotten away from the 5-20 On the CT's. Most don't like using the 5-20 to 5-15 adapter.
My CMS came with all the parts necessary to install the 2200 in the table. I have heard that this has since changed, don't know for sure if it has.
BC, I'm very interested in how this works out.
tjbnwi is online now
Old 04-01-2013, 06:39 PM   #13
You and Darcy covered it. Supposedly the 2200 requires a specific mounting ring/plate/pin/something that Festool no longer shipps with the CMS's sold in the states. I have read of homebrew solutions to deal with this, but then there is also the switch issue which I have read less about. Is it that the shipped switch *won't* handle or isn't *rated* to handle the TS-75?
Old 04-01-2013, 06:40 PM   #14
Trade: Construction
When the CMS first come out it def had all the bits in the kit to mount the 2200. No idea if it does now but I thnk the parts are multi purpose between the 1400 and 2200. I have also heard the switch has no problem handling the power the 2200 requires. Just like the Kapex has no problem running on the 3amp max circuit the CT vac has for the receptical outlet.
Off course I can't take the word of people online 100% but the guys currently using the 2200 with the stock switch don't seem to be having any issues currently.
Old 04-01-2013, 06:54 PM   #15
tjbnwi's Avatar
I have run my 2200 in my CMS. No issues what so ever. The CMS/2200 was run through the receptical on my 36 AC. Seeing as Shane reads these, there goes my warranty.
The same anti rotation pin/tab are used on the 1400 & 2200. The centering rings are different. The ring and dust cover may be what is no longer included.
I have a video on my YouTube channel that shows the current draw of the Kapex and my Bosch (not at the same time of course) miter saw run through the CT on a 15 amp circuit. Highest total surge draw was just under 40 amps. Not sure if I ever posted it here.
Incase anyone is interested in the test;
http://www.youtube.com/watch?v=SAa2G...e_gdata_player
moorewarner (04-01-2013), shofestoolusa (04-01-2013)
Old 04-01-2013, 07:41 PM   #16
duburban's Avatar
Trade: building
Rewards Points: 1,772
what are you hoping to achieve with the cms table saw vs a typical contractor saw? i'm seeing the sliding table, portability, customization with all the t track, is there a priority in the switch to the cms?
duburban is offline
Old 04-01-2013, 07:50 PM   #17
Trade: Construction
It's a much better setup for my trailer. Has a built in stand. Takes up same room as my Bosch. Has numerous setups possible. Has better dust extraction than my Bosch. Can be a router table with in a few mins swapping out the inserts. Can use my mft's as out feed support for bigger material.
Old 04-01-2013, 07:52 PM   #18
duburban's Avatar
Trade: building
got it. would you rip a 2x4 on it?
duburban is offline
Old 04-01-2013, 07:53 PM   #19
Same room as a full size or baby Bosch? It's my 4100 and grav rise stand I can't fit in the work van without killing all available space.
Old 04-01-2013, 08:17 PM   #20
duburban's Avatar
Trade: building
sometimes i think about ditching the gravity rise stand too...
duburban is offline
IM ABOUT TO DO IT!!! festool planex. Rich D. Tools & Equipment 97 05-15-2013 05:45 AM
Just seen a review i made in festool catalog BCConstruction General Discussion 14 03-24-2013 03:57 PM
festool cleaning kit.. Rich D. Tools & Equipment 9 03-10-2013 08:32 PM
Unboxing festool CMS BCConstruction Tools & Equipment 11 10-17-2012 08:24 PM
Festool 494369 crown stops for kapex BCConstruction Contractor Swap 4 10-02-2012 09:37 AM
