Inverter - Tools & Equipment - Contractor Talk
Inverter
Old 08-03-2011, 08:00 PM   #1
celcon's Avatar
Trade: general contractor
Inverter
I want to hook up an inverter in the truck yo charge my cordless batteries .has anyone done it and does it work
celcon is offline
Old 08-03-2011, 08:07 PM   #2
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,704
Re: Inverter
Why wouldn't it?
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 08-03-2011, 08:13 PM   #3
GettingBy's Avatar
Rewards Points: 6,486
Re: Inverter
Look for the input current on your cordless battery charger nameplate. This is the current your small inverter must supply.
Your charger probably takes 120 vac at 1A or so, so the inverter will pull about 10A from your car battery.
GettingBy is offline
Old 08-03-2011, 08:16 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 254
Re: Inverter
Charging batteries is no challenge at all for an inverter; you can run corded power tools on them as long as they carry enough power. One caveat: some chargers may not work with the modified sine wave output of your typical cheap inverter.
More expensive units produce a pretty pure sine wave that's good for just about any type of equipment.
Tinstaafl is online now
Old 08-03-2011, 08:17 PM   #5
celcon's Avatar
Re: Inverter
Will any inverter work i checked them out and there are different types -syn wave i have heard that the batteries need a clean power generator to charge properly. I would like to charge multiple batteries at one time
celcon is offline
Old 08-03-2011, 08:42 PM   #6
GettingBy's Avatar
Re: Inverter
The charger manufs can advise you on the square wave, modified sine wave or pure sine wave decision.
The cheapest inverters put out a square wave.
If you draw more than 10A you may not be able to use the cigarette lighter connector so you'd need clips onto the battery or run a special hookup directly to the battery. The inverter needs to withstand the "load dump transient" that vehicle power can produce when the engine is running.
Old 08-03-2011, 08:45 PM   #7
VinylHanger's Avatar
Rewards Points: 11,470
Re: Inverter
Mine would work for the standard Dewalt or Ryobi chargers, but wouldn't work for the musical Makita chargers. Not sure why, but it sure sucked when I got to the job and my batteries were dead. I just had the small cheapy plug in Y-type inverter with two plugs.
VinylHanger is offline
Old 08-03-2011, 08:49 PM   #8
Service Contractor
tburritt's Avatar
Trade: Under Ground Utility Estimator/Residential Contrac
Rewards Points: 25
Lightbulb
Re: Inverter
I have 3 set ups in my van/truck.. 110V from home or job power, if not available the generator on the back step/bumper can be used or a large inventor can be turned on running off the 2 truck batteries. The fourth would be to get a belt driven alternator/generator off the motor. In past experiences I have found that charging batteries off anything other than 110V land power or from the grid does shorten the batteries life cycle. The reason (told from an electrical engineer) is that the voltage fluctuates on all sources but more dramatically on power you generate. The generator is the worst because the generator motor revs up and down depending on load which changes voltage. Plug in a light and you will see the difference. An inventor looses voltage as your batteries in you truck drain down. The fluctuation in voltage affects batteries being charged worse than any other tool or function because the batteries charge to a particular voltage or current in the batteries memory and normal chargers cant regulate that voltage change in conjunction with the batteries voltage required to bring to full charge. I have found that after charging Dewalt batteries for instance they loose memory charge rather quickly but if you zap them with a quick current from a say wire feed welder you can snap the level in memory and bring them back to life a few times. Be very careful doing that! Sorry for being long winded but I didn't know how to say it any other way but I have ruined a lot of batteries charging them by generator and inventors in the past and that gets expensive quickly. My two cents worth.
Troy B.
A small fish in a BIG pond making a difference one job at a time!
http://www.jwbservicesinc.com
tburritt is offline
Old 08-03-2011, 09:06 PM   #9
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 254
Re: Inverter
That used to be true, and may still be for really cheap inverters, but for the most part these days they will simply shut down if the input voltage falls below the level needed to maintain adequate output.
The memory effect of ni-cads is becoming less of an issue these days as we move to NMh and LI batteries. But even so, shortened battery life can be acceptable if the alternative is loss of production or no production at all.
We don't always have the option of plugging into the grid at some jobsites.
Old 08-04-2011, 05:58 PM   #10
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Re: Inverter
I just use a little guy from HF to charge batteries in the truck...
It charges my 14.4 Makita, 10.8 volt Makita and 6 Volt Paslode batteries just fine.
http://www.harborfreight.com/80-watt...ter-66944.html
TBFGhost is offline
Old 08-04-2011, 06:03 PM   #11
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Inverter
don't most manufactures offer a car charger option?
Tom Struble is offline
Old 08-04-2011, 07:17 PM   #12
GettingBy's Avatar
Re: Inverter
But not all at once, right? The 10.8 v Makita may take 80 w for 15 minutes to charge it.
Old 08-04-2011, 07:59 PM   #13
celcon's Avatar
Re: Inverter
Thanks guys
celcon is offline
Old 08-07-2011, 01:01 AM   #14
Kingstud
Kingstud's Avatar
Trade: Handyman
Rewards Points: 75
Re: Inverter
I installed a xantrex 600w true sine wave I got a great deal on amazon.
put the inverter behind my seat w/ 00 cable. I'd like to setup a land line rv type plug when I'm on the job.
this guy has good info http:www.donrowe.com
The chair is against the wall, John has a long mustache.
Kingstud is offline
Old 08-07-2011, 10:11 AM   #15
GettingBy's Avatar
Re: Inverter
This works on paper and might work in the real world.
You have a battery of voltage V and amp-hours A, so the battery watt-hours are VxA. If you want to charge this battery in a quarter hour you need 4 x V x A.
So a 12 V, 2 A-h, battery charged in 15 minutes takes a minimum of 4 x 12 x 2 = 96 w for 15 minutes.
Old 08-07-2011, 10:58 PM   #16
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,006
Re: Inverter
In short yes a cheap POS inverter will work fine. I have 3 I bought from Canadian Tire and they work just dandy...I run my 20V laptop charger, 24V Hilti, 14V Hilti, 18V Ridgid, 18V Dewalt. I have never had more than 2 chargers going at once.
Inner10 is online now
Iraq Power Inverter Tiger General Discussion 4 06-15-2011 11:17 PM
Inverter Question? Williams Ex Co Electrical 8 10-14-2010 01:18 AM
2000w inverter generator AustinDB Tools & Equipment 5 09-26-2010 05:38 PM
Is a charger and power inverter really needed? brendanstl Tools & Equipment 28 02-01-2010 01:45 PM
Wiring in an inverter. Hersheyplumbing Electrical 23 02-08-2009 11:13 AM
