I Almost Never Buy DeWalt - Tools & Equipment - Contractor Talk
Old 02-07-2019, 05:30 PM   #1
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 322
IMO, the tools are overpriced and have poor ergonomics.
But I couldn't resist giving this little guy a try. Winner! I recently had to drill several holes for electrical wiring through the top plates of exterior walls, belly-crawling in the attic fiberglass under 2x6 rafters.
I was able to use this with a standard 3/4 spade bit, at just a little sideways angle, and it worked fine--even though the only thing holding the bit in was a magnet. As long as you don't try to pull the bit out of the wood before you break through, it retrieves with no problem.
If you don't have one of these in your toybox for those odd situations, you ought to.
https://www.amazon.com/DEWALT-DWARA1.../dp/B00C0VSNKQ
Tinstaafl is offline
The Following 5 Users Say Thank You to Tinstaafl For This Useful Post:
Calidecks (02-10-2019), dsconstructs (02-07-2019), MarkJames (02-07-2019), overanalyze (02-10-2019), SouthonBeach (02-08-2019)
Old 02-07-2019, 05:44 PM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 16,773
Re: I Almost Never Buy DeWalt
I have it and like it.
MarkJames is online now
Tom M (02-07-2019)
Old 02-07-2019, 05:50 PM   #3
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 178
I've got two.
mrcat is offline
Old 02-07-2019, 07:23 PM   #4
Big Johnson's Avatar
Trade: Contractor Grunt
Rewards Points: 672
I have one.
You need to get a set of stubby bits.
https://www.homedepot.com/p/Bosch-Da...007P/203274580
Big Johnson is offline
SmallTownGuy (02-08-2019)
Old 02-07-2019, 07:24 PM   #5
Rewards Points: 672
Stubby Auger bits too.
https://www.harborfreight.com/stubby...-pc-68167.html
Old 02-07-2019, 07:49 PM   #6
Tom M's Avatar
Rewards Points: 7,412
I have one as well. Comes in real handy, a lifesaver sometimes.
Tom M is online now
Old 02-07-2019, 07:49 PM   #7
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 322
Yeah, been thinking about that forever. Just, it's so rare I can't come up with a workaround for those.
Wife just joined Weight Watchers for the umpteenth time. I'm considering starting a chapter of Tool Watchers. Then I could umpteenth too.
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
Calidecks (02-10-2019), TheConstruct (02-08-2019), TxElectrician (02-08-2019)
Old 02-07-2019, 08:00 PM   #8
tgeb's Avatar
Rewards Points: 384
I have a right angle drill for such occasions.
www.gebcon.com
tgeb is online now
The Following 2 Users Say Thank You to tgeb For This Useful Post:
Calidecks (02-10-2019), pinwheel (02-08-2019)
Old 02-07-2019, 08:18 PM   #9
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 322
This guy has a lower profile than any right angle drill I've ever used.
Gumshoe (02-07-2019), overanalyze (02-10-2019), tgeb (02-07-2019)
Old 02-08-2019, 05:59 AM   #10
CityDecks's Avatar
Trade: Deck Builder
Rewards Points: 1,856
There great. Irwin just came out with them or I just found on Amazon. I keep breaking the dewalt. Irwin is a heavier and seems more heavy duty.
Sent from my E6810 using Tapatalk
CityDecks is online now
Old 02-08-2019, 09:06 AM   #11
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 26
Milwaukee's hold the bit in. Had it for years. Don't use it much, but great when you need it.
https://www.amazon.com/Milwaukee-49-...SIN=B000BYEJ02
goneelkn is online now
The Following User Says Thank You to goneelkn For This Useful Post:
Tinstaafl (02-08-2019)
Old 02-08-2019, 10:26 AM   #12
VinylHanger's Avatar
Rewards Points: 11,516
There are at least three Deealt versions. There is a heavy duty version and a cheap light duty version as well.
They all seem to work well. I have had all three. Now I can't find any if them. I think my FIL adopted one if them.
VinylHanger is offline
Old 02-08-2019, 06:33 PM   #13
Deaknh's Avatar
Trade: Handyman
I have the milwaukee version. Indispensable.
Deaknh is offline
Old 02-10-2019, 05:24 PM   #14
GC/carpenter
Calidecks's Avatar
Rewards Points: 3,134
I own that one. Pulled me out of precarious situations many times.
Mike.
_______________
Calidecks is online now
goneelkn (02-10-2019)
Old 02-10-2019, 05:54 PM   #15
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,886
I've got 2 as well.
Sent from my SM-G930W8 using Tapatalk
Aztec Decks
Oshawa deck builder
heavy_d is offline
Old 02-10-2019, 06:22 PM   #16
Bubble stick operator
Defenestrate's Avatar
Rewards Points: 16
Plus 1 to the usefulness, but for all that is good in the world, avoid dewalt's flex shaft right angle doo-hickey. I've busted 2 under pretty light use.
Defenestrate is offline
Old 02-10-2019, 09:17 PM   #17
goneelkn's Avatar
Rewards Points: 26
Mike.
_______________
Yeah, don't use it often, but when you need it, you really need it!!!
Old 02-10-2019, 09:25 PM   #18
Yeah, the flex shafts are pretty weak. Fine for attaching to a bit driver for hand work, but with an impact they don't seem to last very long.
Old 02-10-2019, 11:04 PM   #19
Ed Hartmann's Avatar
Rewards Points: 262
I will have to get one. I also almost never buy DeWalt, but lets not forget to mention that their job sight table saw is a great saw.
Ed Hartmann is offline
The Following User Says Thank You to Ed Hartmann For This Useful Post:
MarkJames (02-21-2019)
Old 02-11-2019, 06:28 AM   #20
going_commando's Avatar
Trade: Electrician
Rewards Points: 256
Those don't like it when you hit nails with paddle bits. The first hole I drilled with mine broke the bearing housing, stripped gears, and twisted the shaft on my paddle bit when I was drilling into a double 2x top plate. Had to use that doohickey since it was 2x8 joists with the ceiling out, but the floor installed above. Ended up having to chuck a stubby paddle bit into an impact.
going_commando is offline
Porter Cable Millworker Tools & Equipment 55 11-01-2013 05:42 PM
Dewalt Customer Service Tylerwalker32 Tools & Equipment 3 02-14-2013 08:16 PM
Dewalt Tough System Vs Bosch L Boxx madmax718 Tools & Equipment 25 01-15-2013 10:41 PM
dewalt tough system storage solution Rich D. Tools & Equipment 39 08-01-2012 01:11 PM
Makita 18v, Bosch 18v, DeWalt 20v....head to head.... CrpntrFrk Tools & Equipment 469 07-12-2012 08:12 AM
