Hitachi C10fs Compound Saw Brake Doesn't Work. Any Help? - Tools & Equipment - Contractor Talk
Old 09-24-2011, 12:38 AM   #1
ICoatproducts's Avatar
Trade: Decorative concrete / epoxy
I have a 10 yr old hitachi sliding compound saw C10FS and the brake recently stopped working. Can anyone help me with fixing this feature as I feel it will save my fingers and/or arm. I can take it some where but it sounds like an easy fix. Secondly, I removed the guard and want to know if I need that in order for the vac/ bag to actually collect dust seeing the bag does zero good right now.
This is my first post so hopefully I'm in the right area.
ICoatproducts is offline
Old 09-24-2011, 12:41 AM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 12,497
Re: Hitachi C10fs Compound Saw Brake Doesn't Work. Any Help?
replace the on off switch.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
The Following 2 Users Say Thank You to Leo G For This Useful Post:
MALCO.New.York (09-24-2011), Splinter hands (09-24-2011)
Old 09-24-2011, 01:35 AM   #3
Mike-'s Avatar
Trade: Renovation Specialist.
New part = switch
Mike- is offline
Old 09-24-2011, 05:05 AM   #4
Handle It!
MALCO.New.York's Avatar
Rewards Points: 2,000
"Switch" means trigger.
Ultimate Wisdom---------
MALCO.New.York is offline
Old 09-24-2011, 06:12 AM   #5
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
When the blade brake gets funny in my chopsaw, it always gets a new set of brushes.
loneframer is offline
The Following User Says Thank You to loneframer For This Useful Post:
Tom Struble (09-24-2011)
Old 09-24-2011, 07:13 AM   #6
It's Not a Toomaa!!
HandyHails's Avatar
Trade: Remodels
Rewards Points: 1,000
My hitachi was doing the same thing. I replaced the brushes to no avail. Replacing the trigger did the trick. Get them both at the same time to save yourself a headache. The new trigger switch ought to be about $20.
Josh
hhicontracting.com
HandyHails is offline
Old 09-24-2011, 09:52 AM   #7
Mike-'s Avatar
I also have owned the hitachi miter saw and it was switch related. And a Bosch I has to was a switch.
Mike- is offline
Old 09-24-2011, 11:19 AM   #8
LRG WoodCrafting
Leo G's Avatar
The switch is set up to start the motor when you pull the trigger and to short it out when you let go. This creates an opposite magnetic field and brings the motor to a quick stop. But it also causes a high current to flow through those contacts which causes arcing. After a while the arcing burns out the contacts and they no longer will short out the motor and it will free spin down with no braking effect.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
The Following 3 Users Say Thank You to Leo G For This Useful Post:
CalebBruster (05-09-2020), MALCO.New.York (09-25-2011), Tom Struble (09-24-2011)
Old 09-24-2011, 11:24 AM   #9
Mike-'s Avatar
That's it!!!
Mike- is offline
Old 09-24-2011, 11:26 AM   #10
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
sounds like a switch problem
Tom Struble is offline
Old 09-24-2011, 11:53 AM   #11
Thumbs up
Thanks everyone. I'll start with the trigger on/off switch then move onto brushes.
I appreciate your help, I'm really liking this site. This was my first post and we have a bunch of replies so quickly.
Thanks!
Old 09-24-2011, 09:19 PM   #12
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
It is either the brushes or the trigger. Try the brushes first, if it still doesn't work replace the switch and all will be well. Or Just replace both and don't worry about it.
Look to the right, in the column called Popular parts the first two items are the Brushes which go for $5 a pair and the Switch which goes for $16.
http://www.ereplacementparts.com/hit...297_14912.html
TBFGhost is offline
Old 09-25-2011, 04:16 AM   #13
Handle It!
Do NOT "move onto brushes"... Do BOTH.
THAT is how someone REPAIRS something rather than "fixing" it.
There are 3 levels of rectification of a problem.
1: Rigging It: Doing WHATEVER it takes to make something usable for an undetermined period of time.
2: Fixing: Modifying or maintaining that which is broken to the point that it is "as good as new".
3: Repairing: REPLACING broken element with a NEW and pristine part(s).
Old 09-25-2011, 05:03 PM   #14
Thx Malco for the advise. I'll do both then.
Old 05-09-2020, 07:31 PM   #15
CalebBruster's Avatar
Rewards Points: 2
Thanks to this thread, I was able to quickly fix this issue. I was completely mortified that the switch was stuck in the "ON" position, I had no way of turning it off except by unplugging it. I also had a hard time understanding why the blade brake wasn't working.
After reading the recommendations, I decided to open up the handle. It was filled with sawdust and other schmutz. I blew out the area with compressed air and nailed the switch with CRC QD Electronics Spray Cleaner and....it didn't work. Saw still turned on by itself.
So I disconnected the switch, sprayed it even more with QD, tapped it briskly a few times, sprayed some more, blasted it with air, and reconnected. VIOLA, problem fixed. Thanks guys. Especially to those who explained the functionality of the switch and braking system.
https://www.crcindustries.com/produc...-oz-05103.html
CalebBruster is offline
Old 05-10-2020, 03:56 PM   #16
VinylHanger's Avatar
Rewards Points: 13,452
Mortified is a bit strong.
That's for showing up at work with no pants on and not realizing it until lunch.
Not having a tool break down. If that's all it took, I'd be mortified daily.
Sent from my SM-N975U using Tapatalk
VinylHanger is online now
C10fsh hitachi compound mitre GREATER OXFORD Tools & Equipment 14 07-10-2011 07:54 PM
Looking for work southern dutchess county NY "JJ" Help Wanted or Looking For Work 1 05-25-2010 01:03 PM
Help! Did Work But Not Paid! Appreciate Any Feedback... Amac General Discussion 11 12-04-2009 02:14 AM
Florida Contractor Does work and doesn't get paid!!!!! localtradesman Business 40 10-13-2009 11:48 AM
Any Plumbers looking for work in Boston, MA area? sadegs Help Wanted or Looking For Work 2 02-20-2009 07:45 PM
