Grinder Advice. - Tools & Equipment - Contractor Talk
Grinder Advice.
Old 08-10-2014, 01:06 PM   #1
FinishingEdge's Avatar
Trade: Renovation
Rewards Points: 117
Grinder Advice.
Been using the cheap Bosch and Makita grinders for a while now, and without success. They just can't seem to handle cutting back stucco for window installations. Anyone have any recommendations of something better and more reliable?
http://www.boschtools.com/Products/T...?pid=AG50-11VS
FinishingEdge is offline
Old 08-10-2014, 01:06 PM   #2
Trade: Renovation
Rewards Points: 117
Re: Grinder Advice.
Or this
http://www.makita.ca/index2.php?even...id=221&catid=3
Old 08-10-2014, 02:37 PM   #3
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,434
Re: Grinder Advice.
I have a makita for my junker, a VS metabo for other tasks.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
FinishingEdge (08-10-2014)
Old 08-10-2014, 02:50 PM   #4
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Grinder Advice.
idk..ive had a 7 amp Hilti for a long time now..
Tom Struble is offline
Old 08-10-2014, 03:42 PM   #5
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 3,116
Re: Grinder Advice.
I have a bosch and hilti, grinders have a pretty rough life.
Inner10 is online now
Old 08-10-2014, 05:19 PM   #6
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Re: Grinder Advice.
I have burnt up a few grinders some in as little as 10mins. They were dewalts best models too. I went for the 13amp Makita in 4.5" and so far its ground down about 2000sqft of concrete and no magic smoke yet. I am pretty hard on them and prob push down too hard but this Makita is going strong so far.
Makita 9564PC
www.bcconstructionllc.com
BCConstruction is offline
The Following User Says Thank You to BCConstruction For This Useful Post:
Old 08-10-2014, 06:06 PM   #7
Wood Craftsman
PrestigeR&D's Avatar
Rewards Points: 4,642
Arrow
Re: Grinder Advice.
Bosch.....
She has served we well....
What to do!.........so many selections,......
B,
PrestigeR&D is offline
The Following User Says Thank You to PrestigeR&D For This Useful Post:
Old 08-10-2014, 06:16 PM   #8
Tom M's Avatar
Rewards Points: 11,312
Re: Grinder Advice.
My bosch 4.5" maybe 18 yrs old. I used to cut in lots reglet flashing in masonry when I roofed allot, also cut back stucco for windows & doors. I still use it for all kinds of stuff. Last week I put a sanding disk on it. Never had it serviced.
Tom M is offline
The Following 2 Users Say Thank You to Tom M For This Useful Post:
FinishingEdge (08-10-2014), PrestigeR&D (08-10-2014)
Old 08-10-2014, 07:02 PM   #9
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 711
Re: Grinder Advice.
From my research and experience while tuckpointing the brick walls of a factory, all of the electrics are basically the same, and succumb fairly quickly to dust in the guts.
Go with air if you really want one that will last.
Tinstaafl is online now
Old 08-10-2014, 08:11 PM   #10
barry1219's Avatar
Trade: Certified Building Contractor Florida
Rewards Points: 344
Re: Grinder Advice.
I think maybe you need to spend more on the wheels you use to grind and less on the actual tool. I have done several hundred windows with bascially the same 3 grinders over the last 5 years. They are Dewalt, Bosch and Makita. Basically I found trying to use one wheel for cutting through stucco, window flange material -usually aluminum- and some wood trim was not suited for one style of wheel.
I use a continuous diamond wheel to remove stucco. Switch to another grinder with a black abrasive cutoff wheel for the aluminum flange and lastly sometimes a cup grinder with diamond bits to flush cut the opening square.
I will list the wheel I use here:
cutoff wheel for metal flange - http://www.bing.com/images/search?q=...electedIndex=1
continuous diamond wheel -
http://www.bing.com/images/search?q=...electedIndex=6
Cup grinder-
http://www.bing.com/images/search?q=...lectedIndex=45
I have had to learn the hard way that multiple grinders already set up are the quickest way to cut windows out...a good vacuum is helpful as well especially if you can hold it when you do the bulk of the cutting of the stucco..dust is the enemy.
Last edited by barry1219; 08-10-2014 at 08:13 PM. Reason: links were not showing up
barry1219 is offline
The Following 2 Users Say Thank You to barry1219 For This Useful Post:
FinishingEdge (08-10-2014), Sisyphus (08-11-2014)
Old 08-10-2014, 09:14 PM   #11
Wood Craftsman
Arrow
Re: Grinder Advice.
Their all designed for a short life span........at some point..."early in the romance" they die ........
Nothing out in the hand tool industry is being built that will last a lifetime......they don't want that.......$$$$$$$$$$$$
JMPOV ,
B,
Old 08-10-2014, 09:17 PM   #12
QCCI's Avatar
Trade: General Contractors/Specialty Contractors
Rewards Points: 952
Re: Grinder Advice.
Metabo
QCCI is offline
The Following User Says Thank You to QCCI For This Useful Post:
Old 08-10-2014, 09:28 PM   #13
Wood Craftsman
Arrow
Re: Grinder Advice.
6 months from know some manufacturers is going to come out with the
Latest and greatest.......
Perfect example...
Bought the Milwalkie driver drill charger combo 2-1/2 years ago....now they have brushless....."fuel"..,,,,
Had my driver serviced 2 times ......service and reputation is write there IMO , ......but when it runs out of warranty,,,,,'....
You should see the piles of cordless tools where I do work for sometimes...box piled to the rim of a 4x4x4 cB heavy box of cordless tools........ It is mind blowing,......made me think....
I don't mind spending coin for serious tooling......as long as it will get me through the warranty..........
1,2,3? Years,.....
And if you think your Festool's are going to last a lifetime......I want to party with you......
JMPOV ,
B,
Old 08-11-2014, 08:17 AM   #14
tdmopar59's Avatar
Trade: Construction Services
Rewards Points: 152
Re: Grinder Advice.
For what it's worth.... I have a milwaukee (11 amp I believe) and I can't say I use it everyday but for odds and ends with tile and little masonry jobs I haven't had any issues...
tdmopar59 is offline
Old 08-11-2014, 12:51 PM   #15
deter's Avatar
Trade: Project Managment & hack-of-all-trades
Rewards Points: 38
Re: Grinder Advice.
Do you use the grinder without the shield? might just be getting too much crap in it
I've had a makita 4.5" grinder for 15+ years that has a little overload switch on the butt. When I hog on it too much, it trips. I use the piss out of it too. Not sure if that is still a feature on grinders... as I haven't had to buy one since.
I did get a dewalt grinder a few years back as a "freebie" for buying a bunch of wheels. It doesn't have the overload like the makita
deter is offline
Old 08-11-2014, 12:53 PM   #16
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,742
Re: Grinder Advice.
How about one of these?
https://www.youtube.com/watch?v=rAvzob2R60k
Rustbucket is online now
Old 08-11-2014, 02:16 PM   #17
sapple89's Avatar
Trade: B
Rewards Points: 64
Re: Grinder Advice.
+1 for air grinders.
My DeWalt is an absolute beast. I cut some stucco a few weeks ago and it did a great job.
sapple89 is offline
Old 08-11-2014, 06:28 PM   #18
Nail Driving Fool
Robinson1's Avatar
Rewards Points: 1,333
Re: Grinder Advice.
I've always had really good luck with Milwaukee grinders. A couple years ago I went through a period where everything I was getting offered was tile work. I don't know how many pieces of backer board I cut with a Milwaukee 4 1/2" grinder and a diamond blade. Never phased it, that grinder is still on my tool trailer running like new and never cut anything but tile and concrete.
ROBINSON
CARPENTRY & PAINTING
Jackson, KY
606-568-7202
Robinson1 is offline
Old 08-11-2014, 06:46 PM   #19
Gary H's Avatar
Rewards Points: 2,342
Re: Grinder Advice.
Dewalts have been good to me
Gary H is offline
Old 08-11-2014, 07:10 PM   #20
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 1,563
Re: Grinder Advice.
I run a milwaukee as well, it's been really good to me.
WBailey1041 is offline
Im bidding for a commercial painting job. any advice? BaranG Painting & Finish Work 13 02-25-2014 01:54 AM
Need advice on taping tools for a remodeler, specifically compound tubes bretth0214 Drywall 3 10-17-2012 07:14 AM
Advice sought on prefinished hardwood installation UpNorth Flooring 5 07-28-2012 08:31 PM
Need some advice on dealing with a possible client MP CONST Business 11 07-19-2012 12:16 AM
Best paint / advice for aluminum siding? Jdub2083 Painting & Finish Work 15 07-12-2012 01:15 AM
