Getting Stuck On Wood Pump Jack Poles - Tools & Equipment - Contractor Talk
Old 04-26-2011, 05:49 AM   #1
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
I use Pump jacks once in a blue moon and got a nice set of Werner steel jacks with work bench and all that. But, I keep getting jammed up on the way down
The poles are DF, decently straight and dry....I read in a few places that even small inperfections will jam up the jacks and today I am gonna take my hand planer to the poles to just smooth them out a bit.
Anyone else have ideas besides going alum?
TBFGhost is offline
Old 04-26-2011, 06:14 AM   #2
Project Manager
CookeCarpentry's Avatar
Trade: Project Manager
Rewards Points: 2,016
Re: Getting Stuck On Wood Pump Jack Poles
You're not going to want to hear this....but go aluminum. So much safer. I can't tell you how many guys I know who have stories about wood pole pump jacks breaking.
Search on craigslist - there are a lot of guys selling them.
I picked up a set of (2) 20' poles, 6' extensions, two pumps, roof brackets, and a 24' 3-man work pick, for a grand earlier this year.
CookeCarpentry is offline
Old 04-26-2011, 06:20 AM   #3
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
If you have to use wood poles, for whatever reason, learn that simply by releasing your foot hold down a couple of times you can get past any imperfection.
Can be fun when it drops 3' for no apparent reason!
Framer53 is offline
Old 04-26-2011, 06:20 AM   #4
tcleve4911's Avatar
Trade: Remodeling contractor
Rewards Points: 1,008
Is the DF a solid 4x4 or 2-2x4's ?
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 04-26-2011, 07:12 AM   #5
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
2-2x are stronger and it's what we always used
Tom Struble is offline
Old 04-26-2011, 05:27 PM   #6
Finish Carpenter
TBFGhost's Avatar
two 2 bys.
I have never had it drop any more then 6" before it catches, and never unexpected. It only does it when I am on the way down
Planing did the trick as well, no more sticky jacks and the wood poles become VERY sturdy if you brace them as per OSHA. Most times with most people they underbrace...so those stores of breakake don't carry much weight with me.
I don't use them often at all, only when I need to get in akward areas for exterior trim replacements and such...there is no way Alum, new or used makes $$$ sence for me.
TBFGhost is offline
Old 04-26-2011, 05:29 PM   #7
Project Manager
Originally Posted by TBFGhost View Post
two 2 bys.
That's what I said...until I got a set....now I come up with all kinds of scenarious to use them.
I'm searching for my next set already...I plan on competing with Lone.
Old 04-26-2011, 05:37 PM   #8
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
I pawned a set to a buddy of mine last year, so now I'm down to 9, although I lent 3 of those to a friend of mine about a year ago.
Until you set up 24'ers in a stairwell, in order to trim windows, I'll always be one up on you on the unique scenario division.
Getting Stuck on Wood Pump Jack Poles-006.jpg   Getting Stuck on Wood Pump Jack Poles-005.jpg
loneframer is offline
The Following 2 Users Say Thank You to loneframer For This Useful Post:
CookeCarpentry (04-26-2011), woodworkbykirk (04-26-2011)
Old 04-26-2011, 05:40 PM   #9
KemoSabe
loneframer's Avatar
BTW, on the subject of "the coronary drop", if you depress the foot-pedal enough to take the pressure off of the release, you'll never have to change your shorts mid-day again.
Well, not because of the pump jacks anyway.
Old 04-26-2011, 05:40 PM   #10
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
Always wanted to know how you set them up, Lone....
Framer53 is offline
Old 04-26-2011, 05:44 PM   #11
KemoSabe
loneframer's Avatar
In that particular case, I used a splice with an 8' and a 16' tower. The 16 was a tight wiggle to get in there. I put the 8'er at the bottom, with the pump already installed, then lifted the 16'er onto the splice.
Old 04-26-2011, 05:45 PM   #12
Trade: siding
Rewards Points: 20
we used to beat them down with a hammer
Old 04-26-2011, 06:05 PM   #13
KemoSabe
loneframer's Avatar
Yet, no entry in the Hammer Challenge?
Anyway, I was on wooden poles on the other side of this house, about to the second floor barge board, trying to pump up. It was all I could do to get about a foot up. Turned around to see the 4' level locked under a shake and the pic bowed out and down about 6" each way and twisted.
When I kicked the foot release, the pump not only dropped, but dropped with the recoil from the bowed pick. Pump went down a good bit, but I was clinging to the pole, getting rattled around pretty good.
Last time I sided on woody's.
Old 04-26-2011, 06:12 PM   #14
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
we just got a set of aluminum pumps. 24' pole... only prob first job there on and they arent tall enough.... gc has to wait til his next draw to buy 12' extensions though
woodworkbykirk is offline
Old 04-26-2011, 06:21 PM   #15
KemoSabe
loneframer's Avatar
I started with 3 poles, 3 12' extensions a 16' pic and a 28' pic. Borrowed a 24' pic. This setup worked well with average building length of 56'. Used extension ladders for work tables.
I bought them for my first cedar siding job, but ended up using them to sheath, paper and install windows on almost every house after that. A few houses down the road, I picked up 5 more tower set-ups, then bought 4 more used about 3 years ago.
I cut some of the used towers down to 16s and 8s for a better variety of lengths. Dismantled one of the jacks to pirate parts off of too.
Old 04-26-2011, 06:32 PM   #16
Finish Carpenter
TBFGhost's Avatar
Yup....the only time I have one drop a bit is when I don't do that.... but I honestly get so used to that drop then it doesn't bother me one bit anymore. I have never, ever free fell for more then 6"
TBFGhost is offline
Old 04-26-2011, 06:33 PM   #17
KemoSabe
loneframer's Avatar
When you get one that goes about 2' or so, you'll never forget it. I didn't.
The Following User Says Thank You to loneframer For This Useful Post:
Framer53 (04-26-2011)
Old 04-26-2011, 06:41 PM   #18
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
Pansy!!
Framer53 is offline
Old 04-26-2011, 06:45 PM   #19
KemoSabe
loneframer's Avatar
Pansy!!
Call me Pansy, if you will, but all the plumbers (Mike) call me Sally.
Old 04-29-2011, 09:32 AM   #20
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 496
I will trade my 8 wooden setups, for 3 aluminum ones.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
So after I was stuck in the mud... 6stringmason Off Topic (Non Trade) 48 10-20-2010 11:21 PM
Best wood species for bare clapboard siding pipeorgan89 Windows, Siding and Doors 4 10-17-2010 02:37 PM
Partition Wall on Wood Floor? zinman7 Framing 2 09-16-2010 06:28 AM
Sump Pump output mpt1123 Plumbing 6 01-19-2010 06:25 AM
WTB Pump jack system al10fred1081 Contractor Swap 4 02-18-2008 10:07 PM
