Gas Powered Air Compressor - Page 2 - Tools & Equipment - Contractor Talk
Old 02-28-2015, 07:47 PM   #21
jlyons's Avatar
Trade: capenter
Rewards Points: 219
Re: Gas Powered Air Compressor
We have the makita and have been really happy with it.
jlyons is offline
Old 02-28-2015, 07:49 PM   #22
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Originally Posted by Inner10 View Post
I'm shocked no one said Devilbiss, the arn't thay big in portable compressors but they are huge in industrial here
Yeah I've seen 40 year old devilbiss compressors that have been chugging away with everyday use. Don't know that I've seen a gas powered one.
www.dominionmasonry.ca
dom-mas is offline
Old 02-28-2015, 10:53 PM   #23
kingcarpenter's Avatar
Trade: G.C./carpenter
Rewards Points: 544
Still using both of my ol emglos. Rolairs are good units. My lead man has two and loves em.
kingcarpenter is offline
Old 03-01-2015, 12:12 AM   #24
Sunset Designs's Avatar
Trade: GC and Framing/Finish
Rewards Points: 230
I've got 2 gas Rol-airs and 3 electric. With regular maintenance, they hold up great. One of my gas units is 13 years old and is our go to unit.
Quality Framing, Finish Carpentry, and Seismic Retrofits since 1985
www.Sunsetdesigns.biz
Sunset Designs is offline
The Following User Says Thank You to Sunset Designs For This Useful Post:
SAcarpenter (03-01-2015)
Old 03-01-2015, 01:58 AM   #25
Framer87's Avatar
Trade: Framing
Rewards Points: 1,156
Didn't emglo discontinue and turn into Jenny? Also is "quincy" not reputable. We personally run all emglo's, if ever in trouble than we have 2 rebuilt cores on the shelf ready to go. Just bolt and go. You should be good for life with the electric motor anyways until you try run them off of a generator, that will blow them up if the generator is slightly too small or just a cheap unit putting out "unclean" power
Framer87 is offline
Old 03-01-2015, 02:00 AM   #26
Framer87's Avatar
Trade: Framing
Oh and btw. The older dewalt wheelbarrow units were emglo's. Not sure what they are now though.
Framer87 is offline
Old 03-01-2015, 09:20 AM   #27
Rewards Points: 544
Wish I had those rebuilt cores on hand. Did you already have them? Do you know if there is a source? If ever i have an issue with mine I have an old boy that can put back together anything and everything with a short turn. I've asked him about parts etc. but he won't talk about it.I've never really looked into it. Guess thats why he has a shop stacked with motors and parts and always gets that 12 pack tip from me.
Old 03-03-2015, 08:21 AM   #28
tccoggs's Avatar
Rewards Points: 874
Compressors are pretty simple machines. Parts availability doesn't mean that much because you can typically make another part work without too much trouble. There isn't much stock left about my black max compressor. I swapped the pump, check valves, pressure switch and belt/pulleys. Only thing original are the motor and tank. Pump got killed when one of my guys put the wrong oil in and ran in in the cold, basically ran dry and threw a rod, cracked the cylinder housing. Had a Sanborn 165 pump originally now have a replacement from rite air.
tccoggs is offline
Old 03-03-2015, 08:33 AM   #29
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
I have a hardly use rol air for sale
jlsconstruction is offline
Old 03-03-2015, 09:06 AM   #30
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
I buy my parts from Tool parts direct, e replacement parts and ebay. I did not mention in my earlier post that my compressor is your typical home crapo special, Campbell Hausfeld with another company name on it, think it was extreme. Compressor has a poor heat exchange pipe design which I have replaced 3 times in the past and now the part is no longer available. Aftermarket compressor I replaced wasnít right from day one, seems like the cfm wasnít the same as OEM, I replace the idler valve on all my compressors every spring, luckily its an easy found part. Now that this compressor is 10 years old parts are harder to find
My next compressor must have easily accessible parts, Iíll buy a few belts, idler valves and idler cables soon after purchase.
festerized is offline
Old 07-09-2015, 06:39 PM   #31
David Festa
festerized's Avatar
Decided to buy the Mikita compressor. Used it for the first time today, not bad plenty of air, had 5 guns going today with no issues.
Gas powered air compressor-imageuploadedbycontractortalk1436484868.174050.jpgGas powered air compressor-imageuploadedbycontractortalk1436484884.603279.jpgGas powered air compressor-imageuploadedbycontractortalk1436485138.363493.jpg
Also install a new coil hose water separator and oil lube
New Compressor ** Quiet** MAD Renovations Finish Carpentry 22 04-10-2013 09:04 PM
Opinions On Starting Out With A Gas Compressor sledhead54 Sandblasting 12 03-29-2013 06:17 PM
Problem with my 1997 DPQ250 towable sullair compressor midnightblaster Tools & Equipment 0 11-06-2012 08:54 AM
Com Bus groud to 120V powered box Question Richard_N_S Low Voltage 0 06-14-2012 11:58 AM
installing 250 cfm compressor into enclosed trailer JohnnysMB Sandblasting 44 12-31-2010 11:03 AM
