Flooring Nailer - Tools & Equipment - Contractor Talk
Flooring Nailer
Old 05-30-2015, 05:26 PM   #1
cisz's Avatar
Trade: electric, plumbing, drywall, etc.
Rewards Points: 20
Flooring Nailer
Looking for opinions of this flooring nailer: http://www.harborfreight.com/2-in-1-...ler-61689.html
We've got a porter cable compressor with a 135 psi max. The central pneumatic nailer calls for 90 psi. Would there be a problem running it on this compressor?
These are the specs for the nailer:
Specifications
Maximum Air Pressure
90 PSI
Air Consumption
0.9 CFM @ 90 PSI
Air Inlet
1/4′′ - 18 NPT
Fastener Types
Cleat Nails: 16 Gauge,1-1/2′′ to 2′′ Long
Crown Staples: 15-1/2 Gauge,
1′′ to 2′′ Long, 1/2′′ Crown
Magazine Capacity
100 Cleat Nails or 80 Crowns
cisz is offline
Old 05-30-2015, 09:25 PM   #2
Nail Driving Fool
Robinson1's Avatar
Rewards Points: 1,333
Re: Flooring Nailer
Pressure isn't really the issue with nail guns, it's more about volume. Smaller compressors will cycle more. So pay attention to your duty cycle and if you find yourself having to wait for the compressor to catch up then it's time to buy a bigger compressor. 135 PSI will power any nail gun you are likely to need.
ROBINSON
CARPENTRY & PAINTING
Jackson, KY
606-568-7202
Robinson1 is offline
Old 05-31-2015, 03:46 PM   #3
Stevarino's Avatar
Trade: General contractor specializing in kitchen and bath remodeling and design
Rewards Points: 415
Re: Flooring Nailer
I have this nailer. I have used it for two large hardwood jobs and it did pretty good. I had a few issues with the harbor freight staples not setting but it was only on a job where I was setting hickory with lots of knots.
I used it on another job with no issues at all. It also shoots cleat nails which took care of most of the issues I had shooting through hard material. I'm sure a fancier name brand gun would have worked better but for the price it did just fine. I don't do a ton of hardwood jobs so I didn't want to drop the $ on a nice one yet.
Stevarino is offline
Old 05-31-2015, 07:58 PM   #4
jetdawg's Avatar
Trade: tool supplier
Rewards Points: 602
Re: Flooring Nailer
^This right here.
Btw, I wouldn't allow a contractor using hf tools in my house
jetdawg is offline
Old 06-01-2015, 12:37 AM   #5
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,436
Re: Flooring Nailer
I've laid thousands and thousands of feet with your exact set up.
Metro M & L is offline
Old 06-01-2015, 12:37 AM   #6
Particulate Filter
Trade: Flooring
Re: Flooring Nailer
Oil your gun liberally and don't nail knots.
Old 06-06-2015, 02:29 PM   #7
cisz's Avatar
Rewards Points: 20
Re: Flooring Nailer
Thanks to everyone for your responses.
cisz is offline
Old 06-06-2015, 03:02 PM   #8
Ex-Framer
Needles's Avatar
Trade: Finish Carpenter
Rewards Points: 1,682
Re: Flooring Nailer
I used a Norge from Lumber Liquidators about a year ago. Probably made in the same factory as the HF one. I found that 90 psi was a bit much for shooting cleats. Dialed it to around 50-60 using a Hitachi oil comp. The Norge is the same price as the HF.
Needles is offline
Old 06-06-2015, 03:19 PM   #9
AGullion's Avatar
Rewards Points: 1,422
Re: Flooring Nailer
The one Lowe's sells is a good gun for the money in my opinion
AGullion is offline
Old 06-08-2015, 08:06 AM   #10
madmax718's Avatar
Trade: General
Rewards Points: 3,276
Re: Flooring Nailer
I don't know what the differences are, but I have a freeman, and it came with a nice hard case as well. But a flooring nailer is a flooring nailer, as long as it doesn't jam on you, there's really no point in spending more. If it jams on you every 5 min, it will kill your mojo.
madmax718 is offline
Porta-Nails Portamatic 421 Wood Flooring Nailer mobiledynamics Contractor Swap 1 05-29-2014 07:20 PM
t & g flooring nailer cleveman Flooring 29 07-09-2013 07:44 PM
Should we frame flooring joists? DavidReid1985 Flooring 2 10-05-2012 10:31 PM
What nailer to use for Bamboo Flooring aaks38 Flooring 24 10-25-2011 09:25 PM
Manual flooring nailer jdeck Flooring 7 05-01-2011 02:53 PM
