Festool And Hardie Siding - Tools & Equipment - Contractor Talk
Old 03-11-2015, 06:29 AM   #1
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 230
Got about 3,000 sq ft of hardie siding to throw up in a couple days. Hardi dust really sucks in the heat. Anyone use a Kapex and tracksaw on it hooked to a dust collector? Will I mess up my warranty?
Deckhead is online now
Old 03-11-2015, 06:57 AM   #2
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 320
Re: Festool And Hardie Siding
Won't that destroy your blades?
I don't see why it would do anything to the warranty.
Xtrememtnbiker is offline
Old 03-11-2015, 07:00 AM   #3
aaron_a's Avatar
Trade: Remodeling and fine carpentry
Rewards Points: 2,238
That's gonna kill your blades for sure. I think a couple guys on here have hardie blades for their track saws
aaron_a is offline
Old 03-11-2015, 07:05 AM   #4
Rewards Points: 320
Yeah, Tom and Barri do I believe. NAINA blades. If there is a blade that was designed for FC you could get it bored for the Kapex.
OP, I assume you're aware of the shears for FC? Practically dustless.
Old 03-11-2015, 07:05 AM   #5
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Highly unlikely it will affect the saw to even need to worry about warranty. You can get blades for cutting cement board products.
But if I was you I would buy a shear if the jobs big enough to warrant buying it.
Plus just to ease your mind incase you do use your kapex here's one being tested with some of the most abrasive dust on the planet
www.bcconstructionllc.com
BCConstruction is offline
Old 03-11-2015, 08:28 AM   #6
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 230
My machinery guy has blades, I got that worked out, just wanted first hand experience.
I try not to do much hardi anymore but its for my sister. Long story short I sided a fresh market (grocery store) that was just north of 20k sq feet on cmu/tie beam and thick guage metal. It ruined me to ever want to do hardie siding again.
Old 03-11-2015, 09:33 AM   #7
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,670
I prefer to cut it with either nibblers or shear.
The 55 works good on it too. I think cmt makes a blade.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
ROVACON (03-13-2015)
Old 03-12-2015, 10:11 PM   #8
mgb's Avatar
Trade: Finishing Carpenter
Rewards Points: 1,116
Oh boy, I definitely wouldn't use that saw for cutting hardi. I suppose if it's just a one time deal maybe its not so bad.
That stuffs like sandpaper, it'll mess up the table/fence in no time.
The shears do work well, quiet/dustless, but not the best cut quality in my experience.
I agree the dust is horrible. I was wondering how a carvex with a hardi blade would do the other day.
Or you could buy a cheaper 10" Cms that has decent dust collection.
mgb is offline
Old 03-13-2015, 12:18 AM   #9
Framer87's Avatar
Trade: Framing
Rewards Points: 1,156
Did hardy a few times. Burned out the armature on a Bosch tablesaw and dewalt chopsaw never sounded the same since. Hardie dust is hard on everything. Even my Pam gun had withdrawal sympthoms for a long time!!
Framer87 is offline
Old 03-13-2015, 07:39 PM   #10
tjbnwi's Avatar
Rewards Points: 4,332
These are the CMT Hardie blades for the TS-55. Tom stocks the 4 tooth (.04H). It works very well on siding and backer board.
The TS-55 is my go to for cement base sheet goods. CMT also makes a blade for the Kapex for cement products.
236.160.04H
236.160.10H
By the way, ditch the Hardie and go with LP Smartside.
tjbnwi is offline
Deckhead (03-14-2015)
Old 03-13-2015, 07:58 PM   #11
Framer87's Avatar
Trade: Framing
Does that come prepainted? Only ever seen primed
Framer87 is offline
Old 03-13-2015, 08:00 PM   #12
Rewards Points: 320
236.160.04H
236.160.10H
Why Smartside?
Old 03-13-2015, 08:04 PM   #13
tjbnwi's Avatar
Wood based product. We all have tools for it. Holds up better to physical damage. 50 year warranty.
tjbnwi is offline
Old 03-13-2015, 08:05 PM   #14
tjbnwi's Avatar
The CMT blade also works well on plaster.
Festool and hardie siding-img_3129.jpg   Festool and hardie siding-img_3130.jpg   Festool and hardie siding-img_3131.jpg
tjbnwi is offline
Old 03-13-2015, 08:07 PM   #15
tjbnwi's Avatar
Blade on the saw.
Festool and hardie siding-img_3132.jpg   Festool and hardie siding-img_3133.jpg
tjbnwi is offline
Old 03-13-2015, 08:08 PM   #16
Rewards Points: 320
Never looked at it. I'll have to check it out. Hardie is our go to replacement for Masonite siding. We always prime the ends before installing.
First whole house we did I read up on it more. Found out it's not impervious like we had assumed since it was cement board.
Old 03-13-2015, 08:10 PM   #17
Rewards Points: 320
That looks handy. We use an angle grinder and a vacuum currently for that sort of stuff.
Old 03-13-2015, 08:35 PM   #18
tjbnwi's Avatar
Hardie is closer to a sponge the impervious.
tjbnwi is offline
The Following 3 Users Say Thank You to tjbnwi For This Useful Post:
Deckhead (03-14-2015), m1911 (03-13-2015), Xtrememtnbiker (03-13-2015)
Old 03-14-2015, 06:33 AM   #19
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 230
That makes it look like youre in an anti gravity room. My guess is screw and a clamp of some sort on the back of the track?
Those blades were the ones... except my machinery guy said he has no clue how long till he could get the kapex blade... said, "a long time".
Agreed on the smart side for tools and workability. For whatever reason its not pushed down here... probably the corrosive atmosphere. I'll have to talk to the guys at The lumberyard. I still have yet to use it but might soon.
Old 03-14-2015, 07:05 AM   #20
tjbnwi's Avatar
Yep, screw in the end holes or clamps.
tjbnwi is offline
