Festool Fan Club Thread - Page 77 - Tools & Equipment - Contractor Talk
Old 12-22-2013, 01:11 AM   #1521
tjbnwi's Avatar
Rewards Points: 3,546
Re: Festool Fan Club Thread
Originally Posted by john5mt View Post
What size pipe is that to make it fit in the front of the ct and the hose?
2" Sch 40 PVC. I'll post a link to the process that I used. It is on FOG not sure if it will be allowed to stay here.
tjbnwi is offline
Old 12-22-2013, 05:58 PM   #1522
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,584
Originally Posted by "DaVinciRemodel
The simple act of installing toe kick:
• Hook-up to the Kapex – make length cut.
• Hook-up to the 55 – remove majority of scribe.
• Hook-up to the grinder – finish-off the scribe.
• Hook-up to the Dominao – attach toe to end panel.
• Hook-up to the grinder – slight adjustment to the scribe.
Next piece:
• Hook-up to the Kapex…
Well I know how to kill two of those steps.. just plug the grinder into an extension cord.. no need to plug it into the dust extractor right ?
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Old 12-22-2013, 06:15 PM   #1523
Dirtywhiteboy's Avatar
Rewards Points: 10,162
I've been trimmin out a big house lately using the domino a lot each day That thing could come up missing
The HO is a trim contractor that does a lot of military work.
Dirtywhiteboy is online now
moorewarner (01-03-2014)
Old 12-22-2013, 06:19 PM   #1524
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Yeah the domino is a sweet bit of kit. Have so many projects I want to use it on.
www.bcconstructionllc.com
BCConstruction is offline
Old 12-22-2013, 07:52 PM   #1525
tjbnwi's Avatar
Here is the thread from FOG that I documented the boom arm build in;
http://festoolownersgroup.com/festoo...demonstration/
tjbnwi is offline
john5mt (12-22-2013)
Old 12-23-2013, 09:21 AM   #1526
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
Rewards Points: 818
Originally Posted by overanalyze View Post
Another outside the box idea is to streamline you process. Do all your cuts on the Kapex, then all the scribing, etc....and also a cheap vac switch and a shop vac with a bag and filter on the Kapex would save some money over a second CT collector. Still can use the 1-1/2" hose for max extraction.
That world help until my ADD kicks in I have a hard enough time keeping one number and one work piece in my head at a time.
Originally Posted by tjbnwi View Post
This indeed would help. I never thought about putting a multi plug before the CT unit.
Still want dust extraction with the RAS and even with my regular grinder I follow it with the vac hose.
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is offline
The Following User Says Thank You to DaVinciRemodel For This Useful Post:
overanalyze (12-23-2013)
Old 12-26-2013, 12:36 AM   #1527
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 14,026
Hey BC did you ever figure out what to put in the tackle box yet, I got one for Christmas and looking what to do with it.
Deckhead is offline
Old 12-26-2013, 07:35 AM   #1528
Repair & Renovation
Rich D.'s Avatar
One thing you could do is order more boxes and use it for screws
Rich D. is offline
Old 12-26-2013, 08:05 AM   #1529
Trade: Construction
Not as of yet. Prob in the next few weeks after I go through and clean up the trailer.
Old 12-26-2013, 09:45 AM   #1530
N.Schiffer's Avatar
Trade: Custom Builder
Rewards Points: 75
So I just got the new track saw, first festool and love it. However two questions
1. Is it normal to have a smell while the saw is running? It's almost smells similar to the old electric drills, just more faint.
2. I was trimming down a solid wood door and while cutting the saw bound up 3 times, while on the track pushing with medium pressure. Is this saw known to not have as much torque as say my makita right hand saw?
Thanks
Nick Schiffer
Specializing in Custom Sheds
Custom Carpentry
& General Construction
N.Schiffer is offline
Old 12-26-2013, 09:51 AM   #1531
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 306
Originally Posted by N.Schiffer
So I just got the new track saw, first festool and love it. However two questions 1. Is it normal to have a smell while the saw is running? It's almost smells similar to the old electric drills, just more faint. 2. I was trimming down a solid wood door and while cutting the saw bound up 3 times, while on the track pushing with medium pressure. Is this saw known to not have as much torque as say my makita right hand saw? Thanks
Maybe it's the new festool smell. I can't remember if mine did.
As far as the second thing. I have had it bind a couple times. It's on things that are warped though and they are trying to close back up. Not sure why it would bind on a door unless it also had some tension that was pulling it.
Xtrememtnbiker is offline
Old 12-26-2013, 11:22 AM   #1532
Trade: Construction
Thanks
New electric smell is normal. should go away after its used a bit.
Shouldnt have any issue with a solid door. I chopped up some butchers block maple the other day and it went through easy but i dont force the cut. i just let the blade do the cutting. If you try and puch it through faster than the blade can remove material then it will bog down.
Old 12-26-2013, 11:23 AM   #1533
Brian Peters's Avatar
Trade: remodeling and some new construction
Rewards Points: 972
I don't have one, but shouldn't the riving knife help with the binding?
Brian Peters is offline
Old 12-26-2013, 11:30 AM   #1534
Rewards Points: 306
The board I was ripping was pulling so much even the knife wasn't keeping it from binding. I just pulled up and went back in and it was good to go.
Old 12-26-2013, 11:31 AM   #1535
Rewards Points: 306
Originally Posted by BCConstruction
New electric smell is normal. should go away after its used a bit. Shouldnt have any issue with a solid door. I chopped up some butchers block maple the other day and it went through easy but i dont force the cut. i just let the blade do the cutting. If you try and puch it through faster than the blade can remove material then it will bog down.
As far as the blade doing the cutting thing... Is a 48 tooth that comes on it the best option for ripping. It's a crazy clean cut but I had been wondering if I shouldn't get one with less teeth. Especially for stuff that doesn't need to be perfect.
Old 12-26-2013, 11:35 AM   #1536
Trade: Construction
it does help but not in all situations. I was cutting down some rough 4/4 the other day and part of the board was so warped that when i cuut it the off cut sprung back into the blade but it didnt bind on the rear of the blade but on the middle. This has only happen 2x for me ever but they do help with most binds.
Old 12-26-2013, 11:38 AM   #1537
Trade: Construction
Depends what your doing. I use my 48tooth for nearly all cuts on my ts55 but on my ts75 in the table saw i use the 16tooth. i get a lot more vibration on the lower tooth count blade which does 2 things. a rough cut and damage to the splinter strip.
The Following User Says Thank You to BCConstruction For This Useful Post:
Northwood (12-26-2013)
Old 12-26-2013, 11:49 AM   #1538
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,588
I use the 24t blade most of the time on my 55. The 48t is a plywood cross cut blade imo.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
The Following 2 Users Say Thank You to WarnerConstInc. For This Useful Post:
BlueRidgeGreen (12-26-2013), Xtrememtnbiker (12-26-2013)
Old 12-26-2013, 12:40 PM   #1539
Trade: Construction
I never tried the 24t. Seems that could be a good in between blade.
Old 12-26-2013, 12:58 PM   #1540
N.Schiffer's Avatar
Rewards Points: 75
Thanks guys.
Nick Schiffer
Custom Carpentry
Jigsaws...Bosch vs Festool jdeck Tools & Equipment 35 02-23-2016 08:43 PM
Fine Finish w/o Festool basswood Finish Carpentry 78 02-04-2013 08:32 AM
festool Planex and cleantex BCConstruction Tools & Equipment 10 05-11-2012 06:56 AM
Finally met Festool! Knighton Finish Carpentry 13 05-15-2010 07:41 AM
Festool john5mt Tools & Equipment 2 04-08-2010 10:16 PM
