Festool Fan Club Thread - Page 7 - Tools & Equipment - Contractor Talk
Old 04-23-2013, 05:37 PM   #121
tjbnwi's Avatar
Rewards Points: 3,076
Re: Festool Fan Club Thread
I am left handed. Been doing things with either hand for so long it doesn't matter to me anymore.
My preferred framing saw is a blade left Skill worm drive. For some reason I find it more comfortable than the blade right sidewinder. I do push the saw with my left hand. I know its backwards, never claimed I was intelligent.
tjbnwi is offline
Old 04-27-2013, 09:27 AM   #122
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Well couldn't hold out any longer. Went and got it.
www.bcconstructionllc.com
BCConstruction is offline
Old 04-27-2013, 09:37 AM   #123
tjbnwi's Avatar
A few days early......
tjbnwi is offline
Old 04-27-2013, 10:02 AM   #124
Trade: Construction
They got them in over a week ago I think. Not sure when the release date was meant to be but I guess it was early.
Old 04-27-2013, 10:28 AM   #125
tjbnwi's Avatar
May 1st, to pick up in store or for the dealer to ship.
I got my CMS 2 weeks early, dealer asked me not to post it anywhere, I guess they can get in a bit of trouble over it.
tjbnwi is offline
Old 04-27-2013, 10:31 AM   #126
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 3,866
So now you can hold your wiener with your other hand while cutting?
Wanna sell the old one?
Inner10 is online now
Old 04-27-2013, 06:39 PM   #127
Tylerwalker32's Avatar
Trade: General contractor
Rewards Points: 1,844
Used my ts55 today noticed I was getting a tear out on both sides of the cut. It's not terrible but it didn't use to do that. Any solutions to this?
Tylerwalker32 is offline
Old 04-27-2013, 06:48 PM   #128
Trade: Construction
Sorry man i sold it a few weeks back. No ones ever bought any of the stuff i put on here so didn't even think of putting it on here.
Good question. is your splinter strip on the rail and the splinter guard in good condition and setup correctly. Sometimes i can use the saw without the splinter guard and i dont get no tear out but sometimes i have to use it.
Old 04-27-2013, 07:06 PM   #129
duburban's Avatar
Trade: building
Rewards Points: 1,704
Clean your blade. I just did two of mine.
duburban is online now
Old 04-27-2013, 07:13 PM   #130
Bc, I'm pretty sure I have it setup correctly how it came, I thought I may need a new splitter guard. As for the blade it has been a while since I have changed it. What did you use to clean yours?
Old 04-27-2013, 07:40 PM   #131
skillman's Avatar
Rewards Points: 1,968
What did it cost for that baby .
skillman is offline
Old 04-27-2013, 07:42 PM   #132
Trade: Construction
$585+ tax
The Following User Says Thank You to BCConstruction For This Useful Post:
skillman (04-27-2013)
Old 04-27-2013, 07:57 PM   #133
CarpenterSFO's Avatar
Rewards Points: 2,044
Krud Kutter works well. The traveling Festool guy recommended it, too. He was pretty adamant about keeping them clean. It's easy with the Festool blades to let them go too long - they're so expensive. Saw shops will sharpen them, too. Definitely worth it.
- Bob
CarpenterSFO is offline
Old 04-28-2013, 07:17 AM   #134
gillisonconstru's Avatar
Trade: General Contractor/ Carpentry
Rewards Points: 344
If the blade is sharpened won't that affect the saw accuracy on the rail?
gillisonconstru is offline
Old 04-28-2013, 07:27 AM   #135
rrk's Avatar
Rewards Points: 1,478
Replace the rubber/plastic strip at the edge then just do test cut which will recut strip. Just finished doing that about 10 min ago, got new blade after tooth fell off previous new blade.
I have used oven cleaner to clean my blades for years
rrk is online now
Old 04-28-2013, 07:35 AM   #136
I thought about the about the splinter chip. And I have replaced it on all my guide rails before. The issue I keep havering with it is it peels up a bit at the ends, not a huge deal but irritating.
Old 04-28-2013, 07:55 AM   #137
rrk's Avatar
I had that same problem, hopefully this last one works better
rrk is online now
Old 04-28-2013, 09:48 AM   #138
tjbnwi's Avatar
Use the two side tape from a window film kit to hold the ends to the guide rail.
The reason it is lifting is you are not cleaning the rail properly prior to installing the new strip. Seen it many times and it has always been improper prep that caused the problem. I've yet to have one come loose.
tjbnwi is offline
Old 04-28-2013, 09:51 AM   #139
The reason it is lifting is you are not clean the rail properly prior to installing the new strip. Seen it many times and it has always been improper prep that caused the problem. I've yet to have one come loose.
Well when the first one peeled I figured I hadn't cleaned it good enough and the second time I cleaned it really well with some mineral spirits, let it dry and still did that.
Old 04-28-2013, 09:55 AM   #140
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 674
Try lacquer thinner or rubbing alcohol. Mineral sprints can leave an oily residue behind.
overanalyze is online now
Jigsaws...Bosch vs Festool jdeck Tools & Equipment 35 02-23-2016 08:43 PM
Fine Finish w/o Festool basswood Finish Carpentry 78 02-04-2013 08:32 AM
festool Planex and cleantex BCConstruction Tools & Equipment 10 05-11-2012 06:56 AM
Finally met Festool! Knighton Finish Carpentry 13 05-15-2010 07:41 AM
Festool john5mt Tools & Equipment 2 04-08-2010 10:16 PM
