Festool Fan Club Thread - Page 52 - Tools & Equipment - Contractor Talk
Old 09-04-2013, 07:42 AM   #1021
rrk's Avatar
Rewards Points: 1,648
Re: Festool Fan Club Thread
So if I need to cut 1/2" in on a curved line I need to cut first at 90 then again on my line?
rrk is online now
Old 09-04-2013, 07:44 AM   #1022
rrk's Avatar
Originally Posted by BCConstruction View Post
I wouldn't use a jigsaw in that situation I would use a combination of ts55 and RAS. much more accurate and quicker than a jigsaw.
There are only 2 letters in my reply and it wont work, those 2 letters are not OK
rrk is online now
Old 09-04-2013, 07:55 AM   #1023
Brian Peters's Avatar
Trade: remodeling and some new construction
Rewards Points: 972
OK so let me get this straight...the Carvex won't cut a bevel at all unless you buy the adjustable base?
Brian Peters is offline
Old 09-04-2013, 08:02 AM   #1024
tjbnwi's Avatar
Rewards Points: 3,522
Again, I don't own one, but it does appear that 1/2" would be about the inboard limit from the blade.
I do own the RAS, it is the primary reason that I don't use a jigsaw much any more. You could sand that 1/2" in less time than you can cut it with a jigsaw. The RAS collects about 90% of the dust as you sand. It is one of those tools I keep saying "it not worth it" until I had a chance to use some else's.
Like most everything we do, picking the proper tool is situation dependent. There are those times where a jigsaw is the right tool.
tjbnwi is online now
alboston (09-04-2013), WarnerConstInc. (09-04-2013)
Old 09-04-2013, 08:07 AM   #1025
tjbnwi's Avatar
I believe you are correct.
Old 09-04-2013, 08:07 AM   #1026
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Who said anything about cutting that from the back? If you really felt the need to hack away at it with a jigsaw then I would take the stile down to the maximum difference between the bricks then let's say 3/16th extra stile material than I need. Then I would scribe and then cut with the jigsaw.
Again though I don't do it like that but it will work like that if you need it too.
www.bcconstructionllc.com
BCConstruction is offline
Old 09-04-2013, 08:08 AM   #1027
Trade: Construction
Yep you need the adjustable base.
Old 09-04-2013, 08:21 AM   #1028
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,584
You know the carvex isant really all that pricey when you consider you are also getting a festool fan sticker with the kit.. im sure barri stuck it on his wifes bumper already...
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Old 09-04-2013, 08:22 AM   #1029
Repair & Renovation
Rich D.'s Avatar
I must say i would want the carvex but... My made in switzerland bosch barrel grip is rocking it still
Rich D. is offline
The Following User Says Thank You to Rich D. For This Useful Post:
Brian Peters (09-04-2013)
Old 09-04-2013, 08:34 AM   #1030
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,576
When my old bosch dies, I am going to buy the festool Trion barrel grip, or maybe two of them.
I don't have a need for all the things the carvex comes with or can do. I have a couple bandsaws for that stuff. Although the big radius thing with it might be nice.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 09-04-2013, 08:34 AM   #1031
Trade: Construction
I been trying to think where to stick that sticker. I wish it said festool fanboy though lol
The Following User Says Thank You to BCConstruction For This Useful Post:
Rich D. (09-04-2013)
Old 09-04-2013, 08:44 AM   #1032
Rewards Points: 972
I don't have a need for all the things the carvex comes with or can do. I have a coup, e bsndsaws for that stuff. Although the big radius thing with it might be nice.
Oh but Darcy the Trion doesn't have the stroboscopic LED's that make the blade stand still... seriously though I feel the same way, my Bosch does just fine for what I use it.
Old 09-04-2013, 10:52 AM   #1033
StrongTower's Avatar
Trade: Finish Carpenter
Rewards Points: 1,260
Call me weird, but I never use the bevel on a jigsaw....so used to either tipping the base or using the coping foot. I like the idea of a fixed base for a jigsaw, then I don't have worry about it going all out of whack.
StrongTower is offline
Old 09-04-2013, 05:33 PM   #1034
WilsonRMDL's Avatar
Trade: Carpenter/Remodeler
Rewards Points: 532
I always just tip the base too, never had an issue with doing it that way
Innovative Remodeling LLC
Licensed and Insured
WilsonRMDL is offline
Old 09-04-2013, 05:35 PM   #1035
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,748
Anyone here use the RO90? I'm considering picking one up. I'm primarily using it for trim, windows and face frames. Really interested in how the delta pad works.
Rustbucket is offline
Old 09-04-2013, 05:40 PM   #1036
I like Green things
Do you have another rotex sander? I got rid of my 90 as it was too close in size to my 125 and I already had the dx93 detail sander.
The 90 is an awesome sander.
Warner Mill Works
Facebook
YouTube
Old 09-04-2013, 06:00 PM   #1037
tjbnwi's Avatar
I've used the 90 a lot. All the modes work very well. Rotex mode is a little jumpier than the larger sanders, you have to get used to it.
Biggest issue, buying all the damn paper for it. I know I have more in paper than all my sanders combined. The Granat should serve you well. Tom at Tool Home makes up assortments in Systainers if you wish to go that route.
Old 09-04-2013, 06:09 PM   #1038
Rustbucket's Avatar
Trade: Remodel/Deck
Yes, I have the RO125. I was just thinking this would allow me to better get into corners and sand window frames that are still in place. I'm also considering the triangle sander that looks like the ETS 125.
Old 09-04-2013, 06:23 PM   #1039
BBuild's Avatar
Trade: Remodeling & repair
Rewards Points: 1,100
The ro90 is a little beast. It packs a punch for such a small sander. With some 60 or 80 grit granat you can hog out some wood fast. Good for stripping paint and varnish too. Some 120 in RO mode will give a pretty good finish. Like Tom said in rotex mode it can get a little jumpy but with some practice you can get it to float on the surface. I think the dts400 would compliment your ro125 very well, probably better than the 90 if your going to be sanding in corners a lot. The delta pad on the 90 isn't all that impressive. I don't think its all that much better than my multimaster. Dust collection isn't that great with the delta pad either.
BBuild is offline
Old 09-04-2013, 06:30 PM   #1040
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
I love the 90. I think it is the bomb I use it 2 to 1 to my RO 150.
"The key is to allow only the complexity that the customer is willing to pay for."
charimon is offline
Jigsaws...Bosch vs Festool jdeck Tools & Equipment 35 02-23-2016 08:43 PM
Fine Finish w/o Festool basswood Finish Carpentry 78 02-04-2013 08:32 AM
festool Planex and cleantex BCConstruction Tools & Equipment 10 05-11-2012 06:56 AM
Finally met Festool! Knighton Finish Carpentry 13 05-15-2010 07:41 AM
Festool john5mt Tools & Equipment 2 04-08-2010 10:16 PM
