Festool Fan Club Thread - Page 365 - Tools & Equipment - Contractor Talk
Old 12-25-2019, 11:36 AM   #7281
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,072
Re: Festool Fan Club Thread
Originally Posted by CityDecks View Post
I tried the Maki band ended getting the Bosch 2nd gen 6".
Sent from my E6810 using Tapatalk
The Bosch 6" is a monster.
Sent from my GM1917 using Tapatalk
Inner10 is offline
Old 12-25-2019, 12:25 PM   #7282
CityDecks's Avatar
Trade: Deck Builder
Rewards Points: 2,092
Originally Posted by EricBrancard View Post
I only wish it had a 12 cord. Whos the genius at Makita that decided to put a short cord on a track saw?
I replaced with 14' er.. 10 min upgrade
CityDecks is online now
Old 12-25-2019, 12:28 PM   #7283
CityDecks's Avatar
Trade: Deck Builder
I primarily use Bosch 6 " or ro90. Between the 2 of them there's not a hole lot you can't do.
The Following User Says Thank You to CityDecks For This Useful Post:
Lettusbee (12-25-2019)
Old 12-25-2019, 03:34 PM   #7284
EricBrancard's Avatar
Trade: Builder/Renovator
Rewards Points: 942
I need to find one of those Festool quick connect ends for it. Or maybe Ill just get the cordless one.
EricBrancard is online now
Old 12-25-2019, 09:41 PM   #7285
Inner10's Avatar
You can but the plug-it conversion kit which is basically a pigtail connector.
Inner10 is offline
EricBrancard (01-25-2020)
Old 01-21-2020, 04:47 PM   #7286
AustinDB's Avatar
Rewards Points: 1,426
Checking out the booth at IBS2020
AustinDB is offline
The Following 2 Users Say Thank You to AustinDB For This Useful Post:
DaVinciRemodel (01-21-2020), overanalyze (01-21-2020)
Old 01-22-2020, 10:31 PM   #7287
georgiasparky's Avatar
Trade: Electrical and plumbing
Rewards Points: 12
If you're using a dust extractor, turn it down to 20-25% or so. The swirl marks will most likely go away and the dust pick up will be the same or better.
georgiasparky is online now
Old 01-22-2020, 11:56 PM   #7288
test
cedarboarder's Avatar
Trade: General
Rewards Points: 2,227
the ro 90 will be my first festool purchase.. one day.. I like how they made a sand paper kit with a tool box for it.
Sent from my SAMSUNG-SM-G891A using Tapatalk
cedarboarder is online now
Old 01-24-2020, 12:18 AM   #7289
duburban's Avatar
Trade: building
Rewards Points: 1,772
Ro90 is a contender for my least used Festool
duburban is offline
Old 01-24-2020, 12:30 AM   #7290
test
Trade: General
what about most used?
Old 01-24-2020, 12:35 AM   #7291
tjbnwi's Avatar
Rewards Points: 1,768
I have to ask----what are you planning on using the sander for?
The only 2 Festool sanders I do not own are the RO 150 and ETS 150. Simply because I do not need to stock another thousand dollars worth of sandpaper.
tjbnwi is online now
Old 01-24-2020, 12:50 AM   #7292
test
Trade: General
correction the Dts 400 delta is the one I've been looking at for a while.
The Following User Says Thank You to cedarboarder For This Useful Post:
overanalyze (01-25-2020)
Old 01-24-2020, 12:56 AM   #7293
tjbnwi's Avatar
It's a good sander. Biggest issue is even with the extractor set all the way down they tend to stick to the work surface. Having a protection pad on it not matter the abrasive helps limit the issue.
cedarboarder (01-24-2020)
Old 01-24-2020, 08:22 AM   #7294
rblakes1's Avatar
Rewards Points: 3,596
I was gonna say let me know when you want to get the ro 90, I have an extra
-Rich
rblakes1 is offline
The Following User Says Thank You to rblakes1 For This Useful Post:
cedarboarder (01-25-2020)
Old 01-24-2020, 08:48 AM   #7295
DaVinciRemodel's Avatar
Trade: Design/Build Remodeler
We bought a DTS 400 about a year and a half ago for a specific use (about 6 hours of sanding). We haven't used it since. We use the RO-90 once a year.
We use the chit out of our ETS 125's and RO 125.
I love what I do and I'm very good at it!
Da Vinci on the web or Da Vinci On Facebook
DaVinciRemodel is offline
The Following 4 Users Say Thank You to DaVinciRemodel For This Useful Post:
cedarboarder (01-25-2020), Deckhead (01-25-2020), Lettusbee (01-24-2020), overanalyze (01-25-2020)
Old 01-25-2020, 07:10 AM   #7296
duburban's Avatar
Trade: building
Ets EC 150 3/5 depending on application and Ro 150 are my most used festool sander with the mft tables and track saw being most used Festools
duburban is offline
Old 01-25-2020, 11:33 AM   #7297
Rewards Points: 942
The RTS 400 is my most used at this point.
Old 01-25-2020, 11:57 AM   #7298
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,162
The cordless Delta head is my favorite for small patches and inside corner work!!
overanalyze is offline
Old 01-25-2020, 04:12 PM   #7299
test
Trade: General
The LS 130 is another one I would consider since it comes with the 90 sanding pad.
It would be used mostly for getting in tight spots where the drywall sander cant get too. I want a sander with the best extraction and festool is it.
Old 01-25-2020, 09:10 PM   #7300
tjbnwi's Avatar
DTS 400 with an inferface pad, otherwise it will be to aggressive when hooked to a CT.
cedarboarder (01-25-2020), overanalyze (01-26-2020)
Jigsaws...Bosch vs Festool jdeck Tools & Equipment 35 02-23-2016 08:43 PM
Fine Finish w/o Festool basswood Finish Carpentry 78 02-04-2013 08:32 AM
festool Planex and cleantex BCConstruction Tools & Equipment 10 05-11-2012 06:56 AM
Finally met Festool! Knighton Finish Carpentry 13 05-15-2010 07:41 AM
Festool john5mt Tools & Equipment 2 04-08-2010 10:16 PM
