Festool Fan Club Thread - Page 361 - Tools & Equipment - Contractor Talk
Old 01-09-2019, 09:40 PM   #7201
john5mt's Avatar
Rewards Points: 1,500
Re: Festool Fan Club Thread
Originally Posted by Deckhead View Post
All valid points.
Something I would definitely consider if I did more trim work. Being as I don't do a bunch, I'm happy with the kapex. I just started using the CMT blade for the kapex and I like it a lot more than the Leitz blades or whatever festool blades are. If the armature of mine goes out I'll probably actually just do a 716 and a unipoint separately. Unipoints can be had for pretty cheap and have the added benefit of having a huge cutting capacity for shop work.
Do you have a part number for that cmt blade for the kapex? I have really liked the cmt blades on my other saws
Remodelling Fool
Helena Siding Windows
https://helenasiding.com/
john5mt is offline
Old 01-12-2019, 08:10 AM   #7202
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 6,762
I don't. I'll look at it today and maybe I can find one. It's a pretty nice blade.
And then I said, supposing you brought the light inside of the body, which you can do either through the skin or in some other way.
Deckhead is online now
Old 01-13-2019, 12:58 AM   #7203
TRThomas's Avatar
Trade: Residential Remodeling/Everything
Rewards Points: 382
This Tenryu blade seems to get good reviews, only 6 on Amazon but they are all 4-5 stars https://www.amazon.com/Tenryu-Festoo...rds=30mm+arbor
Amana makes a 30mm arbor 10" blade that should work. 260mm is a little under 10-1/4" so you're only losing less than 1/8" of actual cut capacity at $58 it may be worth a shot https://www.amazon.com/Amana-610600-...ore+saw+blades
TRThomas is offline
Old 01-13-2019, 01:12 AM   #7204
TRThomas's Avatar
Rewards Points: 382
Originally Posted by cedarboarder View Post
Isn't festtool made for retired doctors playing carpenter? haha
Sent from my SAMSUNG-SM-G891A using Tapatalk
I have to think that's their target demographic given the price tags attached to some of their tools. $600 for a cordless drill, sander, oscillating tool, $900 (I think its actually more for some reason) for a miter saw stand etc.
I must say though, the HK55 is an awesome saw. Had they gone with the dual batteries on the HKC I probably would have bought that instead of the Makita cordless track saw.
I also have their older Trion barrel grip jigsaw, it's been through hell and hasn't skipped a beat. Festools jigsaw blades are also the best I've used and actually reasonably priced as far as Festool cutting implements go.
TRThomas is offline
Old 01-13-2019, 03:12 AM   #7205
john5mt's Avatar
It seems like it wouldn't be a big deal.....but it is. That little peice left in every cut is annoying as f*****
I want the cmt because it's a cmt. They are very good for the money. I've got a chopmaster signature series for it. I want the cmts for more general ourpose. It feels werid cutting deck boards with it though.
Remodelling Fool
john5mt is offline
Old 01-13-2019, 06:12 AM   #7206
TRThomas's Avatar
Rewards Points: 382
Oh sorry, I wasn't implying it left a 1/8" nub on the end of the board, just that you would lose 1/8" in total crosscut capacity. I don't own a Kapex, but I can't imagine the throw on the saw is so exacting that it wouldn't cut all the way through a board with 3/16" smaller diameter blade but again I don't have one so I don't know this for sure. I've seen some videos of people drilling out 10" blades with 5/8" arbors to 30mm arbors and they seem to work fine.
TRThomas is offline
Old 01-13-2019, 06:24 AM   #7207
I'm on a boat!
J L's Avatar
Trade: Yacht carpenter
Rewards Points: 3,468
I've started boring out 10" blades with a 5/8" arbor on my milling machine to have a 30mm arbor hole. It does leave a little nib on any piece being crosscut so I padded my fence out 1/8". No factor.
J L is offline
The Following 2 Users Say Thank You to J L For This Useful Post:
DaVinciRemodel (01-13-2019), TRThomas (01-13-2019)
Old 01-13-2019, 09:37 AM   #7208
tjbnwi's Avatar
Rewards Points: 3,980
If you go with a smaller blade, the Kapex has an adjustment on it that allows the head drop drop farther.
tjbnwi is online now
The Following 6 Users Say Thank You to tjbnwi For This Useful Post:
AustinDB (01-14-2019), J L (01-13-2019), john5mt (01-13-2019), overanalyze (01-13-2019), Sisyphus (01-23-2019), TRThomas (01-13-2019)
Old 01-13-2019, 11:59 AM   #7209
Deckhead's Avatar
Trade: Carpentry,
The number on the blade is 285.060.11M but I couldn't find anything on Google with that number. It's a 260mm blade 60 tooth 30mm bore 15° ATB and 10° hook. 1.88 mm plate and 2.8 mm kerf.
Little heavy on the hook but I Ilike it better than the festool blades...
Old 01-14-2019, 12:50 AM   #7210
john5mt's Avatar
Thank you sir!
I will do some searching.
Remodelling Fool
john5mt is offline
Old 01-23-2019, 03:35 AM   #7211
john5mt's Avatar
The Kapex lives again!!!
Remodelling Fool
john5mt is offline
The Following 2 Users Say Thank You to john5mt For This Useful Post:
DaVinciRemodel (01-23-2019), J L (01-24-2019)
Old 01-23-2019, 10:29 AM   #7212
GC/carpenter
Calidecks's Avatar
Rewards Points: 8,698
Makes me wonder if full kerf blades are too much for kapie.
Mike.
_______________
Calidecks is online now
Old 01-23-2019, 10:39 AM   #7213
CityDecks's Avatar
Trade: Deck Builder
Rewards Points: 2,760
Yes and plug in to vac. 110 vs 220 over there
Mike.
_______________
Sent from my E6810 using Tapatalk
CityDecks is offline
The Following User Says Thank You to CityDecks For This Useful Post:
Calidecks (01-23-2019)
Old 01-26-2019, 02:13 PM   #7214
duburban's Avatar
Trade: building
Rewards Points: 1,796
If you’re like me and have an mft3 that isn’t permanently setup, this TSO square sure makes life easier...
Looked at connecting a Seneca parallel guide stop by need to drill some holes and get some additional hardware. Love the evolution/integration of all these jigs and add-ons
duburban is offline
The Following User Says Thank You to duburban For This Useful Post:
overanalyze (01-26-2019)
Old 01-26-2019, 03:51 PM   #7215
World's Tallest Midget
Mort's Avatar
Trade: Concrete
Rewards Points: 1,580
Anybody know of a 3D printer file to adapt an RO150 head to a Bosch 1250devs? Sander works great but I feel like the dust collection sucks and the more holes in the Festool paper would help.
I hate signatures.
Mort is online now
Old 01-26-2019, 05:48 PM   #7216
duburban's Avatar
Trade: building
Nice idea, I bet a machined part would be more stable. There are some high end 3D printers that may be up to the task
duburban is offline
Old 01-26-2019, 06:22 PM   #7217
duburban's Avatar
Trade: building
duburban is offline
Old 01-26-2019, 08:45 PM   #7218
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 340
Don't bother rigging something up. TSO is about to release their own guide which a member on here has been testing for a while and has said it's very good.
Using the single arm parallel guide in conjunction with the square Tom was never more than 1/128" off in 8'.
https://tsoproducts.com/tso-products...arallel-guide/
Xtrememtnbiker is offline
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
john5mt (01-26-2019)
Old 01-26-2019, 09:25 PM   #7219
tjbnwi's Avatar
What Travis said. They'll be shipping in a few weeks.
Duburban, you have a late release GRS 16 PE, the TPG will mount right to it.
For those who have an early release GRS 16 or GRS 16 PE, TSO has a drilling jig to retrofit for the TPG.
They look different than below, the picture is a second gen prototype.
It's a single arm system unless you're looking at narrow rips/cuts.
Any questions (besides cost) just ask.
Sisyphus (01-27-2019), Xtrememtnbiker (01-26-2019)
Old 01-27-2019, 12:35 AM   #7220
john5mt's Avatar
Found some
https://www.mcfeelys.com/cmt-general...0-mm-bore.html
Remodelling Fool
john5mt is offline
Jigsaws...Bosch vs Festool jdeck Tools & Equipment 35 02-23-2016 08:43 PM
Fine Finish w/o Festool basswood Finish Carpentry 78 02-04-2013 08:32 AM
festool Planex and cleantex BCConstruction Tools & Equipment 10 05-11-2012 06:56 AM
Finally met Festool! Knighton Finish Carpentry 13 05-15-2010 07:41 AM
Festool john5mt Tools & Equipment 2 04-08-2010 10:16 PM
