Festool Fan Club Thread - Page 359 - Tools & Equipment - Contractor Talk
Old 12-17-2018, 01:47 PM   #7161
BlueRidgeGreen's Avatar
Trade: Craftsman
Rewards Points: 526
Re: Festool Fan Club Thread
Originally Posted by Deckhead View Post
If it means anything mine is one of the first ones out (2008 I think?) And I bought it used from my machinery guy in 2012 and I have no issues with it. It's actually the longest I've ever had a Miter saw without a major issue. Normally I figure if I can get three years out of them then it's worth it to just sell at a really low price or give it away and buy new. Kapex had to last 6 and it's been much longer.
Add to that the fact it is so much more accurate and faster than most other saws, I wouldn't hesitate if you're looking for one in the shop. Not sure I'd run one on jobsites often though.
Now the HKC? **** that. Go buy a mafell. I still hate my HKC every time I pull it out.
Why?
Iím about to buy one.
BlueRidgeGreen is offline
Old 12-17-2018, 05:08 PM   #7162
Tom M's Avatar
Rewards Points: 11,388
I think I've asked this question before but forget the answer.
Has anyone picked up the newer more flexible looking hoses are they worth the money to swap out on older vacuums?
Tom M is online now
Old 12-17-2018, 06:05 PM   #7163
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 6,950
Originally Posted by BlueRidgeGreen View Post
Why?
The power is ****. Don't think for a second you'll ever cut framing with the HKC. Get the chorded HK instead if you're going festool. The HKC is okay for PVC and maybe light trim but that's about it. I use it almost exclusively now as a battery powered track saw for thin stuff. It's fine for pickets on railing, PVC decking, and probably miratec trim. That's about it's usefulness. It's a great concept for stair stringers, except it can't cut through them unless you cut three times because it will bind up.
Still pissed off I sold my TS55 because this was meant to replace it. I thought it may be a learning curve but it's still a POS a couple years later.
5/4" exotics you can forget about it. It won't cut through dick, let alone really hard wood. In this case battery is not better. I probably wouldn't buy the electric model either and just go with a mafell which has really good results. For 200 bucks in difference, it'd well be worth it to have a working saw for a good concept.
And then I said, supposing you brought the light inside of the body, which you can do either through the skin or in some other way.
Deckhead is online now
Old 12-17-2018, 06:08 PM   #7164
Trade: Craftsman
Rewards Points: 526
Ohhhh yeah.
Iím definitely getting the corded.
Didnít know the right code I guess.
My buddy loves his.
Been thinking about one for a while.
Thanks Brotato Chip.
I appreciate the feedback.
The Following User Says Thank You to BlueRidgeGreen For This Useful Post:
Deckhead (12-17-2018)
Old 12-17-2018, 06:15 PM   #7165
tjbnwi's Avatar
Rewards Points: 4,148
Yes.
tjbnwi is online now
Tom M (12-17-2018)
Old 12-17-2018, 06:55 PM   #7166
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 362
Despite the lack of power, I have been satisfied with mine thus far. We do a lot of pvc and Boral trims. Being able to take it to the pile, with no cord, is what really matters. We routinely have it on the lift with us in case we need to trim a piece, rather than bring it all the way back down.
Easy Gibson
Warren is offline
The Following 2 Users Say Thank You to Warren For This Useful Post:
Deckhead (12-17-2018), overanalyze (12-17-2018)
Old 12-17-2018, 07:05 PM   #7167
Justin Huisenga's Avatar
Trade: Finish carpenter
Rewards Points: 1,740
Originally Posted by DaVinciRemodel View Post
Since my Kapex was down for a period of time, I got a couple of brand new yellow saws. They cut wellÖ the dust collection is just phucking terrible. You guys that work new construction can tolerate the yellow dust machines. In remodel, we gotta be cleaner. Glad Tom was able to save my Kapex.
Thanks, Tom
I forgot one additional thing. No laser line is like a step back into the stone age. Lining-up a cut is time-consuming.
You can substitute a Bosch dust port for the stock and it makes a difference. DC is in the neighborhood of the Kapex but the problem is the improved DC makes it cut like a Kapex. Drops get sucked into the blade and turn into missles. I have the boot on my 716 currently but only hook a bag to it. Fits the Makita bag which works way better than the Dewalt. It does't get everything but I brick the bag half a dozen times a day. On NC its pretty common to have only one outlet so the first tool I do without is a vac on the miter saw.
Never really cared for lasers on a miter saw. On the rare occasions I have used a Kapex I turn the lasers off. The XPS light on the DeWalt saws is accurate. Never needs to be adjusted for inaccuracy and automatically adjusts blades of slightly different kerf. Between that and a ZCI plate I never creep at a cut.
Justin Huisenga is offline
The Following 4 Users Say Thank You to Justin Huisenga For This Useful Post:
Lettusbee (12-17-2018), overanalyze (12-17-2018), Sisyphus (12-19-2018), Xtrememtnbiker (12-17-2018)
Old 12-17-2018, 07:05 PM   #7168
Deckhead's Avatar
Trade: Carpentry,
Yeah, for some guys I'm sure it's fine. I use a lot of exotics, which it isnsimply too wimpy for. I did use it for some hardi and it worked great (used the ts55 blade for hardi I still had). PVC trims for an exterior door and it was nice as well. I just planned to use it for wood and there is no way it can do that.
Old 12-17-2018, 07:32 PM   #7169
I don't do much conventional trim work. Mine is mostly mitered cuts in the shop. I take it to jobs maybe once every 3-4 months.
I'm open to other saws... Kapex has been really good to me though. For some reason I still have it in my head a Miter saw should be a slider. I know it shouldn't be, still just a thing about not being able to cut all the way through a stair tread. I was scarred by this early in my career
Stairs are just about the only time I pull a slider out onto a job. Crown over 7" is usually a built up. Same with base over 6 1/2". Everything else fits under the arm of the 716 and I can rig the saw to cut 9" crown in position if I need to.
The Kapex was a nonstarter for me for the simple reason that it won't cut 5 1/4" base in position. Being married to thin kerf tooling didn't help its case much either. I don't balk at the cost of a tool if I see value but still aside from above average DC I don't see it in that saw. The set up in the pic is a fairly common one for me. Pair of really well tuned up 716s spinning industrial tooling. Flies through a casing cutlist. Total cost with saws, blades, stand, and wings is still about a grand cheaper than the Festool saw by itself.
Agreed on the HKC. It's gutless. Mine gets used mostly for cutting jamb legs, Anything heavier and it struggles.
The Following User Says Thank You to Justin Huisenga For This Useful Post:
Old 12-17-2018, 08:27 PM   #7170
Deckhead's Avatar
Trade: Carpentry,
All valid points.
Something I would definitely consider if I did more trim work. Being as I don't do a bunch, I'm happy with the kapex. I just started using the CMT blade for the kapex and I like it a lot more than the Leitz blades or whatever festool blades are. If the armature of mine goes out I'll probably actually just do a 716 and a unipoint separately. Unipoints can be had for pretty cheap and have the added benefit of having a huge cutting capacity for shop work.
Old 12-17-2018, 08:30 PM   #7171
Deckhead's Avatar
Trade: Carpentry,
Out of curiosity Justin, why do you have your rule on the opposite of your fence? I am thinking about building a new table and thought about putting one vertical on the fence and then another on top. Never thought to put one on the outside.
By the way, how's the pup?
Old 12-17-2018, 08:42 PM   #7172
The rules on the wings are for measuring short point to short point. I usually feed left to right when cutting casing so I cut a left hand miter, line the short point up with the t-track edge on the wing which is zero on the rule, and mark whatever length I need. The one on the left hand wing is set up reverse to the right. My fences have a bunch of "programmed" rep stops for all my common casing lengths but double heads vary enough that I just use the fence rules and set the stops using the marked piece. Pic shows the index stops on the fences.
The big dog is hanging in there. Tough bastard. Still happy and still comfortable.
The Following 2 Users Say Thank You to Justin Huisenga For This Useful Post:
overanalyze (12-17-2018), TRThomas (12-18-2018)
Old 12-17-2018, 08:49 PM   #7173
Deckhead's Avatar
Trade: Carpentry,
Gotcha.
Good to hear about your buddy. Can't ask for much more for an old giant breed. If they're comfy, they're happy.
The Following User Says Thank You to Deckhead For This Useful Post:
Justin Huisenga (12-17-2018)
Old 12-17-2018, 10:22 PM   #7174
john5mt's Avatar
Rewards Points: 1,500
Have you considered the cordless 716? Or would you say just stick with the corded version?
Remodelling Fool
Helena Siding Windows
https://helenasiding.com/
john5mt is offline
Old 12-17-2018, 10:38 PM   #7175
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,508
I had the cordless ordered but cancelled after I talked to Justin and found out it wouldn't handle a full kerf blade.
overanalyze is online now
john5mt (12-18-2018)
Old 12-18-2018, 12:40 AM   #7176
TRThomas's Avatar
Trade: Residential Remodeling/Everything
Rewards Points: 382
Those extensions you made are really nice. Do they attach to the saw or lock onto the stand? I made a stop similar to that t-track/knob you have there but nowhere near as nice or convenient.
TRThomas is offline
Old 12-18-2018, 10:02 PM   #7177
Currently they attach to the stand. Bolted a piece of aluminum to a couple of the extension supports and the wings mount to those with threaded rod and a couple star knobs. Gonna redo all of that and make brackets that attach to the saw with a pair of heavy duty toggle latches to lock them in.
The Following 3 Users Say Thank You to Justin Huisenga For This Useful Post:
Calidecks (12-18-2018), Philament (12-31-2018), TRThomas (12-19-2018)
Old 12-18-2018, 10:29 PM   #7178
JFM constr's Avatar
Trade: remodel,finish&trim
Rewards Points: 2,362
why would it not handle a full kerf blade . same saw componets as far as i can tell .plus all my blades are full kerf .certainly no lack of power
a reason to stay with his nonslider vrs the cordless slider .weight and size .sucker is that much heavier that for me it shows up . doesn't pass through dr ways as easy either .
JFM constr is offline
Old 12-18-2018, 10:35 PM   #7179
Always Learning
Full kerf is much wider and heavier than thin kerf. Lots more stress on the motor I guess.
Old 12-18-2018, 10:59 PM   #7180
JFM constr's Avatar
the last one i got is a dhs790 ,this the cordless saw .no lack of power . I see no less power then the 706 .
Jigsaws...Bosch vs Festool jdeck Tools & Equipment 35 02-23-2016 08:43 PM
Fine Finish w/o Festool basswood Finish Carpentry 78 02-04-2013 08:32 AM
festool Planex and cleantex BCConstruction Tools & Equipment 10 05-11-2012 06:56 AM
Finally met Festool! Knighton Finish Carpentry 13 05-15-2010 07:41 AM
Festool john5mt Tools & Equipment 2 04-08-2010 10:16 PM
