Festool Fan Club Thread - Page 25 - Tools & Equipment - Contractor Talk
Old 06-10-2013, 05:55 PM   #481
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Re: Festool Fan Club Thread
Originally Posted by Brian Peters View Post
Oh no...here we go again..
Oh yes
www.bcconstructionllc.com
BCConstruction is offline
Old 06-10-2013, 06:02 PM   #482
Fortune and glory, kid.
moorewarner's Avatar
Trade: Remodeler/Restorer
Rewards Points: 1,022
Originally Posted by BCConstruction View Post
Oh yes
... paper or mesh...
"If you don't have time to do it right, when are you going to have time to do it over?" ~ Wise Old Timer
moorewarner is offline
Old 06-10-2013, 06:12 PM   #483
tjbnwi's Avatar
Rewards Points: 4,102
Won't be from me. As much as I like my Festools and have a very slight understanding of them, I know each has their own wants needs and preferences.
On the 300, adjusting the blade holder is very important. Push the blade forward, tighten the blade clamp, begin to loosen the clamp until the blade just snaps back.
tjbnwi is online now
Old 06-10-2013, 07:44 PM   #484
rrk's Avatar
Rewards Points: 4,922
Just spray the hose with static guard and it solves the problem
The shock that you get from the hose is not much, but it does surprise you.
rrk is offline
Old 06-10-2013, 08:06 PM   #485
GC/carpenter
Calidecks's Avatar
Rewards Points: 9,138
What's this for?
Calidecks is offline
Old 06-10-2013, 08:19 PM   #486
Originally Posted by Californiadecks View Post
What's this for?
Attachment 93792
Cutting wood?? Is this a trick question?
The Following User Says Thank You to moorewarner For This Useful Post:
Calidecks (06-10-2013)
Old 06-10-2013, 08:25 PM   #487
tjbnwi's Avatar
What's this for?
Attachment 93792
It is the arbor bolt guard. Look at most miter saws, the arbor bolt is covered some how.
Loosen the center bolt, loosen the outer bolt, swing it out of the way, snug outer bolt to hold out of the way when changing the blade. When done, put back in place.
FYI, the bolt is left hand thread. Righty, loosey, lefty tighty.
You do know the green knob on the right side of the guard housing is the FadtFix to change the blade-----right?
Old 06-10-2013, 08:32 PM   #488
CITY DECKS INC's Avatar
Trade: DECK BUILDER. RESIDENTIAL. COMMERCIAL
Rewards Points: 4,608
Originally Posted by californiadecks View Post
what's this for?
Attachment 93792
did you find the wrench behind the cord / handle?
That mini wrench loosens it up then you access the blade bolt. It's on ther for saftey in case the arbore bolt comes loose. You tube videos and take a min to go over throgh the manual.
CITY DECKS INC is offline
The Following User Says Thank You to CITY DECKS INC For This Useful Post:
Old 06-10-2013, 08:32 PM   #489
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,838
That part is for us in NA, it was a UL thing. The saw also has a slip clutch/disc under the arbor bolt. That way you don't ruin the gears if something binds up, it will just slip the blade.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 06-10-2013, 08:45 PM   #490
tjbnwi's Avatar
Real question is, did Mike find the allen wrench for adjusting the lasers in the packaging????
Old 06-10-2013, 08:47 PM   #491
I like Green things
The real question is he going to piss and moan like all the tool dorks on thr FOG about poking a hole in a sticker?
Warner Mill Works
Facebook
YouTube
Old 06-10-2013, 08:56 PM   #492
Trade: Construction
I used my festool counter sink bit to make the holes look tidy after I bitched to my wife about them being popped open and untidy.
Old 06-10-2013, 09:06 PM   #493
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
I'd never use the term faggot in a derogatory manner...unless it was to describe certain members of that site.
Inner10 is offline
WarnerConstInc. (06-10-2013)
Old 06-10-2013, 09:10 PM   #494
tjbnwi's Avatar
I bet there is a part number in the ekat for the sticker.
It would be funny if Festool started sending 3 new stickers with each saw.
I treat my tools well, but in the end they're still just a tool. have to get the work done.
Old 06-10-2013, 09:16 PM   #495
duburban's Avatar
Trade: building
Rewards Points: 1,796
i was playing around with the festool drills at the store today. just drooling really. if they made a cordless circ saw and decent impact i'd switch in a heart beat. the biggest reason for me not to buy one is knowing how much the old guys i work with would pick on me after they found out the $$
duburban is offline
Old 06-10-2013, 09:17 PM   #496
GC/carpenter
Calidecks's Avatar
Yes I didi know that, thanks
Old 06-10-2013, 09:22 PM   #497
GC/carpenter
Calidecks's Avatar
I did find the Allen, however the laser can be a little hard to see outside. I am doing 1400 s.f. of floor this week. I'm hoping I can bring the set up inside now that I have the vac. I will play with the adjustment in the morning
Old 06-10-2013, 09:31 PM   #498
Tylerwalker32's Avatar
Trade: General contractor
Rewards Points: 1,844
Almost pulled the trigger on a kapex today. It was a kapex and a stand for 900 bucks. If I didn't already own 3 mitersaws.
Tylerwalker32 is offline
Old 06-10-2013, 09:32 PM   #499
Interior Remodeling
Eric K's Avatar
Trade: Interior Remodeling
Rewards Points: 570
How big of crown can you cut with the kapex? (Nested)
Eric K is offline
Old 06-11-2013, 12:59 AM   #500
GC/carpenter
Calidecks's Avatar
From what I was told it will cut 5-1/4" crown that has a 4- 5/32" drop, meaning while nested the height is 4- 5/32"
Jigsaws...Bosch vs Festool jdeck Tools & Equipment 35 02-23-2016 08:43 PM
Fine Finish w/o Festool basswood Finish Carpentry 78 02-04-2013 08:32 AM
festool Planex and cleantex BCConstruction Tools & Equipment 10 05-11-2012 06:56 AM
Finally met Festool! Knighton Finish Carpentry 13 05-15-2010 07:41 AM
Festool john5mt Tools & Equipment 2 04-08-2010 10:16 PM
