Festool Fan Club Thread - Page 19 - Tools & Equipment - Contractor Talk
Old 06-06-2013, 10:42 PM   #361
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,248
Re: Festool Fan Club Thread
There is a couple options for a vac. Are they both comparable in strength?
Calidecks is online now
Old 06-06-2013, 10:43 PM   #362
GC/carpenter
Calidecks's Avatar
Originally Posted by tjbnwi
Mike, does the noise go away when you cut the deck boars?
Yes it does. Cuts very phucking nice
Old 06-06-2013, 10:44 PM   #363
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,858
Only difference in the CT vacs is the capacity, mini, midi, 26 and 36.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 06-06-2013, 10:49 PM   #364
tjbnwi's Avatar
Rewards Points: 4,762
Then the noise is the electronic feed back system. With no load it is hunting and the gears are going through a load/no load cycle.
As Darcy said all of the new Festool CT's have the same motor/lift specs. You won't need the AC unless you're thinking about the Planex.
tjbnwi is offline
Old 06-06-2013, 10:58 PM   #365
GC/carpenter
Calidecks's Avatar
I do mostly outside work, how's it for leaving outside, providing it doesn't rain of coarse. I don't usually roll up all my chit at the end of the day. I can just leave it in the back yards. So if a little dew got on it would it be alright?
Old 06-06-2013, 11:02 PM   #366
Brian Peters's Avatar
Trade: remodeling and some new construction
Rewards Points: 972
I know I'm not gonna try it to find out...if I was going to leave mine out, (which I doubt I ever will, ) I would at least throw a tarp or plastic or something over it.
Brian Peters is offline
Old 06-06-2013, 11:08 PM   #367
I like Green things
I am not leaving my 1400 dollar saw outside over night.
I have been caught in the rain and snow before, but I am not going to leave it unattended over night
Warner Mill Works
Facebook
YouTube
Old 06-06-2013, 11:15 PM   #368
CITY DECKS INC's Avatar
Trade: DECK BUILDER. RESIDENTIAL. COMMERCIAL
Rewards Points: 4,608
I do with a tarp. i just can't possibly take down 3-5 stories pack in the sprinter and do it all over again the next day. I said it before and I'll say it again you suburban guys got it made.
CITY DECKS INC is offline
Old 06-06-2013, 11:20 PM   #369
Do you still use the vac even when your outside? Rockler said if I want the vac I can get 10% off, if I decide I still want it in the next 30 days
get them both. I use vac in / outside all the time. Pt ipe whatever. I have the midi vac it just fits better all around. you can bigger because you have the space. Also just don't want to clean up. What ever is left is not worth a conversation. Just finished a bad ass ipe deck and over 24gal of ipe dest was collected.
Old 06-06-2013, 11:22 PM   #370
here's a pict. The window washers came creeping down on us. pretty narly....
Old 06-06-2013, 11:56 PM   #371
GC/carpenter
Calidecks's Avatar
It's "Gnarly" damn eastern boys
Old 06-07-2013, 01:32 PM   #372
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Sweet there's even a spot for them in the systainer that looks like it was made for them lol
www.bcconstructionllc.com
BCConstruction is offline
Old 06-07-2013, 01:40 PM   #373
thanks..hahaha
Old 06-07-2013, 01:44 PM   #374
Attachment 93658
Attachment 93659
sweet indeed. I love that thing. When I dominoing all that ipe i couldn't stop thinking of all of the other things I could use thing for.
Old 06-08-2013, 12:21 AM   #375
GC/carpenter
Calidecks's Avatar
Originally Posted by redwood
Mike, if you get the vac., make sure you get the bigger hose.
I'm now using Fast Cap saw hood to catch my dust. That allows me to use my vac in other areas.
Getting the 26 tomorrow.
Mark, which hose are you recommending that is better? Not familiar with any of this stuff.
Old 06-08-2013, 12:25 AM   #376
GC/carpenter
Calidecks's Avatar
Is the ct26 rated for RRP
Old 06-08-2013, 12:53 AM   #377
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
Yes.
EricBrancard is offline
The Following User Says Thank You to EricBrancard For This Useful Post:
Calidecks (06-08-2013)
Old 06-08-2013, 01:28 AM   #378
BBuild's Avatar
Trade: Remodeling & repair
Rewards Points: 1,100
Yes all festool's current vacs are rrp rated except the 36 AC. For the kapex your going to want the 36mm hose. There's no real advantage to the anti static hose when using the kapex and they are very rigid and suck to roll up and store. I usually use my festool or bosch non AS 36mm hose. The bosch hose is usually on amazon for around $30. Its a little longer than festool hose and has the same tool end as the 27mm hose so it can be used with their sanders.
BBuild is offline
The Following User Says Thank You to BBuild For This Useful Post:
Old 06-08-2013, 06:48 AM   #379
tjbnwi's Avatar
Not sure why you wouldn't need an AS hose. If is still creating dust. Guess I'm about to learn something. I've never had a problem rolling up a hose. I did a video of storing the hose and cord in the Mini garage.
Which ever 36 mm (If you get the Bosch with the 27 mm end, I'm not sure your'e going to gain much) hose you get, set the vac in a location as close to the dust port as convenient. Cut the hose as short as practically possible. The shorter the hose, the better the dust collection.
Pick up a box of bags for the 26 away, sucks to need a bag and not have one. Some empty an reuse them. I'm way to lazy to do that.
Next a cleaning kit. And the long green and blue spiral begins.
Edit; you can order replacement cuffs for the Festool hose that way you can still use the cut off, not sure about the Bosch.
tjbnwi is offline
Old 06-08-2013, 06:53 AM   #380
Trade: Construction
After using AS hoses I won't go back to standard ones. I used to hate getting shocked bybthe dam vacs all the time. Used to get so annoying and the hose would have more dust on it than I sucked up. AS for me every time now. Think I have 5 AS hoses in all different lengths now to suit different setups.
The Following User Says Thank You to BCConstruction For This Useful Post:
Jigsaws...Bosch vs Festool jdeck Tools & Equipment 35 02-23-2016 08:43 PM
Fine Finish w/o Festool basswood Finish Carpentry 78 02-04-2013 08:32 AM
festool Planex and cleantex BCConstruction Tools & Equipment 10 05-11-2012 06:56 AM
Finally met Festool! Knighton Finish Carpentry 13 05-15-2010 07:41 AM
Festool john5mt Tools & Equipment 2 04-08-2010 10:16 PM
