Festool Fan Club Thread - Page 166 - Tools & Equipment - Contractor Talk
Old 01-16-2015, 01:36 AM   #3301
Business Owner
JD@SBS's Avatar
Trade: Schluter Systems ASD, General Bathroom Remodeling
Rewards Points: 330
Re: Festool Fan Club Thread
Originally Posted by Californiadecks View Post
I've only had one experience with festools service (that was today) and it was chit, to say the least. You won't sell me quite yet on thier service.
What problem did you have with them?
In my experience they have been some of the most courteous and helpful people...
JD
JD@SBS is offline
Old 01-16-2015, 01:48 AM   #3302
GC/carpenter
Calidecks's Avatar
Rewards Points: 9,062
So I just got my Kapex back. Phucking thing is still broke. They couldn't of possibly of looked at my repair order. I went through great details on what needed fixed. The only thing they did was replace my betterly insert with one of there's. I didn't want that changed. So they fixed chit that wasn't broke and sent back the saw with the chit, I sent it to them for still Phucking broken.
Now I have to send it back. I'm very pissed to say the least.
Start Here and you can continue reading
Calidecks is online now
Old 01-16-2015, 05:36 AM   #3303
I'm on a boat!
J L's Avatar
Trade: Yacht carpenter
Rewards Points: 3,468
Straight line ripping mahogany or maple or walnut with the TS55 is definitely too much for it. One or two cuts, it's fine. But every time I do a stack of boards I get about 6 cuts in and it gets smoking hot and goes into a some protection mode where it barely spins so you have to wait for it to cool off before you continue. The TS75 is on my wish list.
J L is offline
Old 01-16-2015, 07:02 AM   #3304
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 340
What blade are you using on it?
Xtrememtnbiker is offline
Old 01-16-2015, 07:23 AM   #3305
I'm on a boat!
J L's Avatar
28 tooth
J L is offline
The Following User Says Thank You to J L For This Useful Post:
Xtrememtnbiker (01-16-2015)
Old 01-16-2015, 01:27 PM   #3306
GC/carpenter
Calidecks's Avatar
The ts55 req, just went up for sale in contractor swap.
Old 01-16-2015, 10:24 PM   #3307
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Guys where can I order a good quality kapex blade with tooth count around 40 for cutting PT. Any recommendations.
www.bcconstructionllc.com
BCConstruction is offline
Old 01-16-2015, 10:41 PM   #3308
GC/carpenter
Calidecks's Avatar
Old 01-16-2015, 11:05 PM   #3309
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 6,886
I got a cmt for like $75 and am quite pleased. Its my got to as an in between sharpening.
Mike, is the 55 that less of a machine? Just curious because I got rid of mine and only use the 75 and havent had any problems. I prefer the 75 anyhow though.
Deckhead is offline
Old 01-16-2015, 11:11 PM   #3310
skillman's Avatar
Rewards Points: 1,968
So will that be up for sale when it comes back from repair the second time around .
skillman is offline
Old 01-16-2015, 11:18 PM   #3311
GC/carpenter
Calidecks's Avatar
No. The problems with the saw was of my doing. I have a problem with the customer service. I may have a of1400 for sale though. I'm thinking of getting the 2200 in its place. I believe the 2200 has the better power when I use it to cut radius decks. That 1400 was just a little too small.
Old 01-16-2015, 11:22 PM   #3312
tjbnwi's Avatar
Rewards Points: 4,080
The 2200 is a beast, you'll really like it. I'd suggest holding on to the 1400 for smaller work.
tjbnwi is online now
Old 01-16-2015, 11:23 PM   #3313
GC/carpenter
Calidecks's Avatar
I thought seriously about the 75 but I really like the size of the Mafell it's small enough to fit between posts before either the front hits or the back, depending on which direction I'm pushing the saw. Also that mafell mt55cc is 836 bucks not much more than the 75. I have to admit there's also a curiosity factor with that mafell.
Old 01-16-2015, 11:27 PM   #3314
GC/carpenter
Calidecks's Avatar
I think in hindsight I asked a little too much from that 1400 on the deck with the radius. I think the 2200 would've been perfect. I haven't used it since though. I enjoyed that deck, I might push another one.
Old 01-16-2015, 11:52 PM   #3315
GC/carpenter
Calidecks's Avatar
I think you will need to get one bored. But your spot on with that tooth count for pt.
Old 01-16-2015, 11:55 PM   #3316
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
If you sell the ts55 because it lacked balls are you sure the mt55 will be a big enough upgrade?
Inner10 is offline
Old 01-16-2015, 11:56 PM   #3317
GC/carpenter
Calidecks's Avatar
I believe the closest one to that count that's comes from the factory, is the Tenyru 72t. Which i have and is a nice blade, but a little too many teeth for pt. I would look for a Tenyru that you can get bored.
Old 01-17-2015, 01:03 AM   #3318
GC/carpenter
Calidecks's Avatar
After talking to Timberwolf they said the power difference is very noticeable. It's also reflective in the specs. It spins at 1000 rpm's more than the ts55 (if needed) and has 1400 vs.1200 watts.
Old 01-17-2015, 01:13 AM   #3319
GC/carpenter
Calidecks's Avatar
Nothing against the ts55, but this seems to me to just be a better saw all around. I was cutting sheets of pressure treated plywood into strips, two sheets at a time, the ts55 got very hot and just bogged down on me.
I'm sure because of the chemical in the pt ply it was pretty wet, but I'll bet the mt55 will cut it better.
I will give an honest review of it when I get it, even if it means I have to eat Crow. I won't have a problem saying I phucked up. But I expect it to give me the extra umph I'm looking for.
charimon (01-26-2015)
Old 01-17-2015, 01:25 AM   #3320
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
You're building decks, not fine high-end built-ins; you should be using a worm drive...
m1911 is offline
Jigsaws...Bosch vs Festool jdeck Tools & Equipment 35 02-23-2016 08:43 PM
Fine Finish w/o Festool basswood Finish Carpentry 78 02-04-2013 08:32 AM
festool Planex and cleantex BCConstruction Tools & Equipment 10 05-11-2012 06:56 AM
Finally met Festool! Knighton Finish Carpentry 13 05-15-2010 07:41 AM
Festool john5mt Tools & Equipment 2 04-08-2010 10:16 PM
