Festool Fan Club Thread - Page 165 - Tools & Equipment - Contractor Talk
Old 01-15-2015, 10:01 PM   #3281
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 340
Re: Festool Fan Club Thread
Originally Posted by Inner10 View Post
Craig said the same thing about the TS55 lacking balls.
Maybe so. I personally am quite pleased with it. With the proper blade that is clean and sharp, it has not failed to deliver great results.
Xtrememtnbiker is offline
Old 01-15-2015, 10:01 PM   #3282
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,838
Those are real woods...
Yeah, I don't even notice its cutting when cutting pvc.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Xtrememtnbiker (01-15-2015)
Old 01-15-2015, 10:10 PM   #3283
GC/carpenter
Calidecks's Avatar
Rewards Points: 9,062
I cut tons of composite and it's lacking balls. It actually gets hot. The Makita has better power.
Calidecks is online now
Old 01-15-2015, 10:11 PM   #3284
GC/carpenter
Calidecks's Avatar
I have both saws.
Old 01-15-2015, 10:13 PM   #3285
Tom M's Avatar
Rewards Points: 11,306
The first I felt after using my TS55 was wow it labors, smooth, nice tool but labors
Tom M is online now
Calidecks (01-15-2015)
Old 01-15-2015, 10:23 PM   #3286
BBuild's Avatar
Trade: Remodeling & repair
Rewards Points: 1,100
Originally Posted by Californiadecks View Post
So all my festool tracks will work with that mt55? How's it compare in size? Is it closer to the ts55 or the ts75?
Yes I would think it would work with Makita rails also. It uses the same size blade as the ts55 with 2mm more cut depth.
BBuild is offline
The Following User Says Thank You to BBuild For This Useful Post:
Old 01-15-2015, 10:34 PM   #3287
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
The only time my my TS55 had a issue was cutting 2" thick hard maple rips. Used the 75 and it went through it like butter.
www.bcconstructionllc.com
BCConstruction is offline
Old 01-15-2015, 10:50 PM   #3288
Tylerwalker32's Avatar
Trade: General contractor
Rewards Points: 1,844
I have experienced the same but it is only when my dust extractor isn't plugged directly into an outlet. Other than that I've never bogged my 55 down.
Tylerwalker32 is offline
Old 01-15-2015, 10:55 PM   #3289
Trade: Construction
I notice that when I run an extension to my trailer with a cord from real to trailer then a cord from trailer to splitter then from splinter to vacuum and then vacuum to tool. There's a massive difference in output for sure. The only way to get full power is run vac straight to outlet.
Old 01-15-2015, 10:58 PM   #3290
I like Green things
I think thats why they put a 20' cord on the CT's.
Warner Mill Works
Facebook
YouTube
Old 01-15-2015, 11:06 PM   #3291
Trade: Construction
The cords stupid thick 2 which prob helps a bunch on that long length.
Old 01-15-2015, 11:11 PM   #3292
David7586's Avatar
Trade: General
Rewards Points: 185
I believe I read somewhere that the mafell rail is thicker or thinner than the festool. This means that when beveling the saw the blade will not rest against the anti splinter strip or may actually cut more off when using a festool guide rail. Not too big of a deal, but for $800 I'd want all the features to work.
David7586 is offline
Old 01-15-2015, 11:12 PM   #3293
icerock drywall's Avatar
Trade: drywaller
Rewards Points: 930
this sucks I need to spend 1800 on a sander...I need to do it soon...................I miss my old sander so so much
dont work hard...work smart
icerock drywall is offline
Old 01-15-2015, 11:14 PM   #3294
GC/carpenter
Calidecks's Avatar
I've never needed the bevel. Pretty much only need the saw for seam boards and parameter boards, which are straight. Sometimes ply but not often.
Old 01-15-2015, 11:16 PM   #3295
I like Green things
It's 12 ga.
Warner Mill Works
Facebook
YouTube
Old 01-15-2015, 11:37 PM   #3296
David7586's Avatar
Trade: General
Rewards Points: 185
I don't remember reading why you're selling off your ts55. Why the change? Why not the makita which sits in between the ts55r and ts75 in terms of power?
The Following User Says Thank You to David7586 For This Useful Post:
Old 01-15-2015, 11:55 PM   #3297
GC/carpenter
Calidecks's Avatar
The only reason I would get the Mafell is the quality. I have a Makita, and it has good power. I'm still debating,
That ts55 will be go to the highest bidder. It's less than a year old. If I decide to sell.
Old 01-16-2015, 12:27 AM   #3298
Business Owner
JD@SBS's Avatar
Trade: Schluter Systems ASD, General Bathroom Remodeling
Rewards Points: 330
Just get a TS75, lets all face it even the best tools develop problems over time and need to be serviced and if you live in the US and your Mafell Develops issues your screwed!
Thats the only reason I wouldn't buy a Mafell, I believe they are exceptional tools but until they come across the pond and set up shop ready to sell and service their tools I'm not buying...
If Festool didn't warranty and service tools the way they do I wouldn't buy them either
JD
JD@SBS is offline
Old 01-16-2015, 01:10 AM   #3299
GC/carpenter
Calidecks's Avatar
I've only had one experience with festools service (that was today) and it was chit, to say the least. You won't sell me quite yet on thier service.
Old 01-16-2015, 01:33 AM   #3300
GC/carpenter
Calidecks's Avatar
The Mafell is just a cut above all of them.
Mafell MT55 Demonstration.: http://youtu.be/POprMeRfDXE
Jigsaws...Bosch vs Festool jdeck Tools & Equipment 35 02-23-2016 08:43 PM
Fine Finish w/o Festool basswood Finish Carpentry 78 02-04-2013 08:32 AM
festool Planex and cleantex BCConstruction Tools & Equipment 10 05-11-2012 06:56 AM
Finally met Festool! Knighton Finish Carpentry 13 05-15-2010 07:41 AM
Festool john5mt Tools & Equipment 2 04-08-2010 10:16 PM
