Festool Fan Club Thread - Page 152 - Tools & Equipment - Contractor Talk
Old 12-19-2014, 05:16 PM   #3021
BBuild's Avatar
Trade: Remodeling & repair
Rewards Points: 1,100
Re: Festool Fan Club Thread
Originally Posted by BCConstruction View Post
If you got girly hands like me then you can use it like a barrel grip. If you got hulk hands maybe not so much.
I tried holding it like a barrel grip but I have to keep my hand at a weird angle because my wrist hits the handle. I guess if I cut from underneath that wouldn't happen.
The main reason I'm considering the barrel grip is because the handle just feels way too small and chintzy. I've never even used a barrel grip and both my bosch jigsaws are d handle but the Carvex just feels weird.
One thing I would have to get used to is an on/off switch versus a variable speed trigger. I have a habit of throttling down as I start and stop the cut.
BBuild is offline
Old 12-19-2014, 05:24 PM   #3022
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
i been meaning to put some kind of grip on mine like hockey tape or racket grip tape. It is way to thin when holding it by the handle. Yeah when you cut from underneath your hand wont hit the grip. I use the splinter guards though so no real need to cut from underneath. even without the guards its a pretty splinter free cut.
www.bcconstructionllc.com
BCConstruction is offline
Old 12-19-2014, 05:45 PM   #3023
Tylerwalker32's Avatar
Trade: General contractor
Rewards Points: 1,844
So I'm looking into a Cxs drill after using a co workers last week. Do any of you all own one? Likes? dislikes?
Tylerwalker32 is offline
Old 12-19-2014, 06:02 PM   #3024
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 338
I love it. It's my go to drill for anything less than a 3" screw. It will also drive 3" screws just not as fast as my impact driver. Get the set, the right angle attachment is great to have.
It has a small battery so the battery life is a bit short but with two batteries you always have one ready. We did 20 replacement windows today with 4 screws each plus a picture window with probably 16. That was on a partially used battery and it went all day.
Size and weight is awesome. It's very ergonomic. It doesn't have a ton of torque so it won't drill a spade bit or even some larger twist bits. It has more torque in speed one than speed two though if you need it.
Xtrememtnbiker is offline
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
BlueRidgeGreen (12-20-2014)
Old 12-19-2014, 06:08 PM   #3025
I currently have a good makita 18 volt set. And an older c12 set but I really want something nice and small to carry around.
Old 12-19-2014, 06:18 PM   #3026
Trade: Construction
i just built out 900sqft deck with the cxs and it worked great. battery charges before the other is dead even when doing hundreds of screws a day into the deck boards. Its a very nice light weight drill and there's really no down points to it.
Old 12-19-2014, 07:00 PM   #3027
BBuild's Avatar
I can't think of anything I don't like about the CXS. It fits my hand perfectly and has a lot of torque for such a small drill. The right angle attachment is very handy and has saved the day more times than I can remember.
BBuild is offline
Old 12-19-2014, 07:10 PM   #3028
BBuild's Avatar
Next year festool is coming out with a t shaped version called the TSX. They are also upgrading the CXS batteries to 2.6ah but who knows how long until they reach the states.
BBuild is offline
The Following User Says Thank You to BBuild For This Useful Post:
overanalyze (12-19-2014)
Old 12-19-2014, 08:26 PM   #3029
MDjim's Avatar
Trade: General Contracting/Insurance Repair
I have a cxs and love it also. Definitely get the kit.
MDjim is offline
Old 12-19-2014, 08:38 PM   #3030
jlyons's Avatar
Trade: capenter
Rewards Points: 219
The 2.6 batteries I think would be a really nice upgrade. Yeah the batteries charge fast, but I would rather they lasted longer and had just a little more oomph. I wish I could run 3" screws into construction lumber on speed 2. As far as the drill body is perfect.
jlyons is offline
Old 12-19-2014, 09:17 PM   #3031
skillman's Avatar
Rewards Points: 1,968
Okay I did some use today with the CT wings . It works great on walls holding up material that is same thickness . I was hanging a T.V and tried it with my 8' level .
When I tried testing it on ceiling with wide ( Trim ) material it would fall out . Used a 2" wide material it work's and holds up . But I would say nothin wide . The side where it does not fit on wing it tips out . Festool fan club thread-imageuploadedbycontractortalk1419041832.089386.jpgFestool fan club thread-imageuploadedbycontractortalk1419041848.945923.jpgFestool fan club thread-imageuploadedbycontractortalk1419041862.688833.jpg
skillman is offline
The Following User Says Thank You to skillman For This Useful Post:
Gary H (12-20-2014)
Old 12-19-2014, 10:52 PM   #3032
tjbnwi's Avatar
Rewards Points: 14
I have 2 CSX drills, rarely take out my T-15 anymore.
tjbnwi is online now
Old 12-19-2014, 10:55 PM   #3033
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 806
When I tried testing it on ceiling with wide ( Trim ) material it would fall out . Used a 2" wide material it work's and holds up . But I would say nothin wide . The side where it does not fit on wing it tips out . Attachment 123145Attachment 123146Attachment 123147
You get used to those things and they're like gold.
Deckhead is offline
Old 12-21-2014, 10:48 PM   #3034
mgb's Avatar
Trade: Finishing Carpenter
Rewards Points: 1,116
My version of ron paulk's vacuum manifold. Only good if you're a one man show.
mgb is offline
The Following 3 Users Say Thank You to mgb For This Useful Post:
dkillianjr (12-21-2014), [email protected] (12-22-2014), StrongTower (12-28-2014)
Old 12-22-2014, 02:51 AM   #3035
Business Owner
JD@SBS's Avatar
Trade: Schluter Systems ASD, General Bathroom Remodeling
Rewards Points: 330
That's pretty awesome! Definitely a time saver when your running multiple tools in the shop
JD
JD@SBS is offline
Old 12-22-2014, 03:00 AM   #3036
Business Owner
JD@SBS's Avatar
Rewards Points: 330
Attachment 123137
I'm extremely happy with my CXS but always thought if they were going to improve it I would expect to see a brushless motor version.
JD
JD@SBS is offline
Old 12-22-2014, 09:29 AM   #3037
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
That's cool... where'd you get the flat stock ABS?
-Steve
TimelessQuality is offline
Old 12-22-2014, 12:32 PM   #3038
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
you can probably just heat up the pipe to make flatstock
Tom Struble is offline
Old 12-22-2014, 03:59 PM   #3039
mgb's Avatar
There's a plastics & paint supplier nearby. Find sheets of abs are handy to have around.
mgb is offline
Old 12-22-2014, 04:51 PM   #3040
tjbnwi's Avatar
Rewards Points: 14
onlinemetals.com has a plastics section. I've had excellent service from them.
Jigsaws...Bosch vs Festool jdeck Tools & Equipment 35 02-23-2016 08:43 PM
Fine Finish w/o Festool basswood Finish Carpentry 78 02-04-2013 08:32 AM
festool Planex and cleantex BCConstruction Tools & Equipment 10 05-11-2012 06:56 AM
Finally met Festool! Knighton Finish Carpentry 13 05-15-2010 07:41 AM
Festool john5mt Tools & Equipment 2 04-08-2010 10:16 PM
