Festool Fan Club Thread - Page 131 - Tools & Equipment - Contractor Talk
Old 10-16-2014, 06:29 AM   #2601
tjbnwi's Avatar
Rewards Points: 48
Re: Festool Fan Club Thread
Originally Posted by CITY DECKS INC View Post
i sold mine off to a festie freek. i can't stand those things.
have these http://www.senecawoodworking.com/pro...a-t-track-plus
Why did you own the LR-32 system? It does not appear to fit your line of work.
tjbnwi is online now
Old 10-16-2014, 10:45 AM   #2602
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Found these 10" blades on amazon.
http://www.amazon.com/gp/aw/d/B00BWW...&robot_redir=1
www.bcconstructionllc.com
BCConstruction is offline
Old 10-16-2014, 12:01 PM   #2603
Brian Peters's Avatar
Trade: remodeling and some new construction
Rewards Points: 972
Originally Posted by BCConstruction View Post
Now THAT is what I call a mega blade! If it will cut straight that would be great for notching a 6x6...
Brian Peters is offline
Old 10-16-2014, 12:40 PM   #2604
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,672
Longest is 145mm approximately 5 1/4" cut depth.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 10-16-2014, 07:31 PM   #2605
Artist and not a curator
Deckhead's Avatar
Trade: Carpentry,
Rewards Points: 820
Just got some today that I have to use tonight... We'll see how true they cut. I've got to cut some 5" diameter full round cypress.
All the other long blades I've used are trash because they're so thin.
Deckhead is offline
Old 10-17-2014, 07:55 AM   #2606
Rewards Points: 972
How can a 10" blade cut only 5"?
Old 10-17-2014, 08:04 AM   #2607
Trade: Construction
He's talking about festools longest blade. the S145/4
Old 10-17-2014, 01:02 PM   #2608
Rewards Points: 972
Makes more sense now that I read back further in the thread...
Old 10-17-2014, 01:04 PM   #2609
Trade: Construction
I used the Bosch blade today. Fir how deep its cutting its really not that bad. I was forcing it through the material as well.
This was on my carvex
Front of cut
Back of cut
Old 10-18-2014, 05:18 PM   #2610
Home wood's Avatar
Trade: carpentry
Rewards Points: 386
I have always been a Makita guy but I have just bought into team green.
Planex sander and ct36 vacuum
And lucky for me I have some unfinished drywall to sand in my own basement.
Home wood is offline
The Following 5 Users Say Thank You to Home wood For This Useful Post:
joe dirt (10-18-2014), MDjim (10-18-2014), overanalyze (10-18-2014), skillman (10-18-2014), Xtrememtnbiker (10-18-2014)
Old 10-18-2014, 06:05 PM   #2611
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 962
I was going to order a planex when the 40% sale was announced...a little late to the dance for that one. Congrats!
overanalyze is online now
Old 10-18-2014, 06:34 PM   #2612
Trade: Construction
Originally Posted by Home wood
I have always been a Makita guy but I have just bought into team green. Planex sander and ct36 vacuum And lucky for me I have some unfinished drywall to sand in my own basement.
Welcome to the club. Your gonna love that sander.
Old 10-18-2014, 07:12 PM   #2613
I like Green things
The vecturo is pretty sweet.
Warner Mill Works
Facebook
YouTube
Old 10-18-2014, 07:48 PM   #2614
Hack
asevereid's Avatar
Rewards Points: 476
Now the big question .. Are the blades proprietary or will Fein/Bosch etc work with it?
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is offline
Old 10-18-2014, 07:54 PM   #2615
I like Green things
They are the same blades as the super cut ones.
Warner Mill Works
Facebook
YouTube
asevereid (10-18-2014)
Old 10-19-2014, 06:57 PM   #2616
Home wood's Avatar
Trade: carpentry
Rewards Points: 386
Wow used my new sander today. Twice as fast without breaking a sweat. Came home and laid down on the couch without getting told to " GO SHOWER NOW".
Totally worth every rediculous dollar they charge.
So here is my plan to have the ultimate set up
There is some obvious spots that will still require some hand work and or touch ups.
So my plan is to buy the sys 5 box and leave it on the vacuum.
It will hold some spakle, couple knives, sanding sponges, sand paper, vacuum hose, and whisk end for the hose.
The Following User Says Thank You to Home wood For This Useful Post:
overanalyze (10-19-2014)
Old 10-19-2014, 07:06 PM   #2617
I like Green things
To do corners and hard to sand spots, try the dts400.
Warner Mill Works
Facebook
YouTube
Old 10-20-2014, 11:38 PM   #2618
GC/carpenter
Calidecks's Avatar
Rewards Points: 26
Anyone have issues with popping breakers using the TS75 and vac? That's a lot of amps. I would use it mostly outdoors where GFI's are very common and could also be an issue.
Calidecks is online now
Old 10-20-2014, 11:43 PM   #2619
skillman's Avatar
Rewards Points: 1,968
I pop breakers with the TS55 . Depends on what source your using . Some home got so much stuff of on breaker . Or there AFCI ones that trip easy to .
skillman is offline
Old 10-20-2014, 11:56 PM   #2620
GC/carpenter
Calidecks's Avatar
Rewards Points: 26
I would like to buy one, but I don't think it would serve me well if it's always popping breakers. Isn't the ct 10 amps? That together with the TS75 that's 13 amps, total 23 amps, not to mention a surge at startup.
Jigsaws...Bosch vs Festool jdeck Tools & Equipment 35 02-23-2016 08:43 PM
Fine Finish w/o Festool basswood Finish Carpentry 78 02-04-2013 08:32 AM
festool Planex and cleantex BCConstruction Tools & Equipment 10 05-11-2012 06:56 AM
Finally met Festool! Knighton Finish Carpentry 13 05-15-2010 07:41 AM
Festool john5mt Tools & Equipment 2 04-08-2010 10:16 PM
