Festool Fan Club Thread - Page 11 - Tools & Equipment - Contractor Talk
Old 05-23-2013, 11:55 AM   #201
Power-Whittler
Clarke Carpentry's Avatar
Trade: Custom Carpentry & Cabinetmaking
Re: Festool Fan Club Thread
That is nice. The wings are ******* expensive by themselves.
Clarke Carpentry is offline
Old 05-23-2013, 12:00 PM   #202
Fortune and glory, kid.
moorewarner's Avatar
Trade: Remodeler/Restorer
Rewards Points: 1,022
Originally Posted by tjbnwi View Post
Yours are the new style wings if you have the single leg. If you do not loosen the thumb screw enough to push the retaining tab far enough into the Kapex the wings will be very unstable. Do not loosen the thumb screw so far that it falls out. You must push the retainer in all the way and then tighten the thumb screw. I had issues with the wings being wobbly at first also, once I figured out I was not pushing the retainer in far enough the problem went away. The single leg is fine, once you get the attachment worked out.
My Bosch I have to move the fence to bevel past about 20. If I'm doing a lot of bevel work, I just take them off. Make sure you vacuum out the fence slots on the yoke before you reinstall the fences.
I've had little problems with the small projectiles, but I know that it is an issue. When cutting small pieces I either back them up or let the blade come to a stop before I raise the head, just the way I've always handled small pieces like self return cuts. I think (but don't know for sure) the dust collection has something to do with the flying small pieces. It may lift the small piece into the blade as it being raised.
Which clamp? If it's the material hold down clamp, all brands get in the way of bevel cuts.
Not sure a longer deck would help.
One of the biggest thing I like about the UG wings is they mount to my MFT3 and CMS.
You can also reverse the UG wings side for each to act as your crown stops.
I have used the MFT Kapex, with the wings, and that little extra space around the saw is pretty nice. I don't like setting up the old style wings with the twin legs and strut. The new wings on the MFT Kapex would be a really nice combination. Not having the UG cart you do give up a little bit of ease of transport though.
Yeah I saw that video of the set up. I have pondered and tried everything to get those buggers to attach solidly. I don't think I am doing anything different that the cat in the video.
It's solid from above, side to side not so much. Like I said, compare the UG wing attachment bracket to the crown attachment bracket, world of difference. If the UG had the crown bracket we wouldn't be having this conversation. That is the mystifying part to me, they have a fine example of what works with another of their own products.
If they can be useful with CMS, which is next on my list, there could be some redemptive factor to them.
A longer deck would let you get you your full bevel out of the saw, which with fences removed is 45 right and 39 left due to the clamp. Seems like another 2-4 " would get you to max.
Seems like an unnecessary design limitation.
I *want* to love it in every way. And like I said it cuts like a treat.
"If you don't have time to do it right, when are you going to have time to do it over?" ~ Wise Old Timer
moorewarner is offline
Old 05-23-2013, 12:04 PM   #203
Power-Whittler
Originally Posted by WarnerConstInc. View Post
I had to move at least one fence for bevels on my old makitas and bosch saws.
The issue on the kapex is the forward rails. To save space behind the saw, there is compromise, the rails will hit the fence on bevels over 25?
Yeah you have to move the fences on all saws but the Kapex is the only one I've used where you have to take the right hand fence all the way off. Still prefer to do that and have the rails up front though. Small compromise in my opinion.
Old 05-23-2013, 12:12 PM   #204
Yeah it's the rails, the kicker was being limited to 39 on a left bevel with no way around it, that's what really started to irritate me. It was like being home again on my old DeWault single bevel.
It seems as if they made the deck longer they could of delivered it all.
Old 05-23-2013, 12:32 PM   #205
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,706
It's not that big of a deal to slide the fence back. Bevel cutting probably accounts for 10% of my cutting max.
How are you limited to 39 left?
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 05-23-2013, 12:56 PM   #206
I'm on a boat!
J L's Avatar
Trade: Yacht carpenter
Rewards Points: 3,466
No joke. Hence the homemade wings...
J L is offline
Old 05-23-2013, 12:58 PM   #207
I'm on a boat!
J L's Avatar
If you don't slide the fence over any, the rails hit at 39. If you slide the fence over a bit, it clears the full 47
J L is offline
Old 05-23-2013, 01:39 PM   #208
Material clamp?
Old 05-23-2013, 01:41 PM   #209
Then what saw am I using?
I get 45 right, max with fence removed; and 39 left, as it hits the material clamp.
Old 05-23-2013, 01:43 PM   #210
I like Green things
I just drug mine out and checked. Yup. My saw looks like hell.
Festool fan club thread-forumrunner_20130523_144058.jpg   Festool fan club thread-forumrunner_20130523_144221.jpg
Warner Mill Works
Facebook
YouTube
Old 05-23-2013, 02:03 PM   #211
tjbnwi's Avatar
Rewards Points: 1,116
Photos of the bracket from the front and rear.
Video of the connection yours should be this solid;
http://youtu.be/p5ki5tqtOqE
Festool fan club thread-image-3052888997.jpg   Festool fan club thread-image-3116412588.jpg
tjbnwi is offline
moorewarner (05-23-2013), timraleigh (02-05-2019)
Old 05-23-2013, 02:06 PM   #212
Thanks Tom, I am clearly not getting something right. That is what I am looking for. I will screw around with it and then come back and eat crow/shut my pie-hole.
Old 05-23-2013, 02:08 PM   #213
And clearly the clamp *can* be removed. This is getting better by minute. RTFM.
Old 05-23-2013, 02:30 PM   #214
I like Green things
Spin it 180 degrees a pull it out.
Warner Mill Works
Facebook
YouTube
Old 05-23-2013, 02:36 PM   #215
Yeah... I'm going to need me to move my stuff to the basement, that would be great.
Let's forget I even posted shall we?
Old 05-23-2013, 03:46 PM   #216
I'm on a boat!
J L's Avatar
That's what she said!
J L is offline
The Following User Says Thank You to J L For This Useful Post:
DaVinciRemodel (05-23-2013)
Old 05-23-2013, 04:05 PM   #217
tjbnwi's Avatar
Without pictures I have no clue.
The UG wings on my MFT3, the last pic is of the CMS fence on the MFT3 using it as an additional fence and stop. I don't have any pics of the wings on the CMS, but I have used them on it.
Some day I may have to actually buy a Kapex and the stand.
Festool fan club thread-img_1581.jpg   Festool fan club thread-img_1584.jpg   Festool fan club thread-img_1585.jpg
tjbnwi is offline
Old 05-23-2013, 04:13 PM   #218
tjbnwi's Avatar
Darcy,
I drive an Excursion, the UG stand and wings work out well for me. I find it very easy to swing it up into the truck while on the stand. There are 3 doors a vanity, 1 sheet 1/2" MDF, MFT3, Kapex on UG stand with wings,35 systainers, Rolair Jc10, MM, a tub of other stuff and then some in my truck in these pics.
It is one of the things I like best about the Festools, you can neatly pack a lot of stuff in a vehicle.
Festool fan club thread-img_1492.jpg   Festool fan club thread-img_1493.jpg   Festool fan club thread-img_1495.jpg
tjbnwi is offline
Old 05-23-2013, 04:33 PM   #219
GC/carpenter
Calidecks's Avatar
Rewards Points: 2,914
Made these, TS 55, Kapex and Domino.
Is that a saw kerf on your track? :
Calidecks is offline
Old 05-23-2013, 04:34 PM   #220
GC/carpenter
Calidecks's Avatar
Originally Posted by californiadecks
is that a saw kerf on your track? :
At the bottom of the track it looks like a kerf from a kickback
Jigsaws...Bosch vs Festool jdeck Tools & Equipment 35 02-23-2016 08:43 PM
Fine Finish w/o Festool basswood Finish Carpentry 78 02-04-2013 08:32 AM
festool Planex and cleantex BCConstruction Tools & Equipment 10 05-11-2012 06:56 AM
Finally met Festool! Knighton Finish Carpentry 13 05-15-2010 07:41 AM
Festool john5mt Tools & Equipment 2 04-08-2010 10:16 PM
