Festool Fan Club Thread - Page 109 - Tools & Equipment - Contractor Talk
Old 06-05-2014, 07:10 PM   #2161
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Re: Festool Fan Club Thread
Originally Posted by PrestigeR&D
I respectfully disagree..... Has something to do with even spacing......accurately .... For me.... JMPOV.....
Tom is right. The fence could be at a 45 degree angle as long as the fence is straight the fluting will be dead straight too.
www.bcconstructionllc.com
BCConstruction is offline
Old 06-05-2014, 07:11 PM   #2162
rrk's Avatar
Rewards Points: 1,628
Originally Posted by tjbnwi View Post
Even fluting it does no matter. If the bit center is 2" from the fence it stays 2" from the fence no matter what angle the fence is to the edge of the table.
Straight is critical, square is not.
So the sliding table would be useless then?
rrk is offline
Old 06-05-2014, 07:23 PM   #2163
Wood Craftsman
PrestigeR&D's Avatar
Rewards Points: 4,642
Arrow
Straight vs accurate scaled measurements are 2 separate entities.......
If your not square to the feild plate markings - guess what happens".......
Jmo,
B,
PrestigeR&D is offline
Old 06-05-2014, 07:34 PM   #2164
Trade: Construction
There's no measurements on the festool table. I always measure of the fence. I have never owned a table with measurements. If my bit center is 30mm of the fence then its 30mm off the fence. Can't really go wrong on a table if the fence ain't square to the table.
Old 06-05-2014, 07:37 PM   #2165
Wood Craftsman
Arrow
I do.....
Woodpecker quick lift......
And I use the field plate markings to accurately separate flute spacing.....
Just saying.....not trying to be argumentative.....
B,
Old 06-05-2014, 07:42 PM   #2166
Trade: Construction
I do..... Woodpecker quick lift...... And I use the field plate markings to accurately separate flute spacing..... Just saying.....not trying to be argumentative.....
Which means it makes no difference being square but you prefer your way lol
I never trust any gauges. I always get a tape and double check what the stuff says its on anyway. Even my festool table saw which is dead on to the 64th of an inch I check with a tape each time I cut. Belt and braces
Old 06-05-2014, 07:46 PM   #2167
Wood Craftsman
Arrow
We all have our own way....
Peace....
Nothing personal....
B,
Old 06-05-2014, 07:53 PM   #2168
tjbnwi's Avatar
Rewards Points: 3,478
I think the issue here is semantics.
I consider a flute to be a groove created with the long edge running against the fence.
A dado, running cross grain will (normally) need to be square to the end grain of the board.
The dado will use the sliding table, the flute/groove will run along the fence. If I'm detailing the edge of a panel all the sides run along the fence. If I'm detailing the edge of a board, I'll use the fence on the long edge, fence and sliding table on the end grain.
tjbnwi is offline
Old 06-05-2014, 08:03 PM   #2169
Wood Craftsman
Arrow
No semantics.....
Think of a scale- centered perpendicular to the center point of a bit....
Now if your fence is off by several degrees front or back....the scale is useless.....
When I want to flute a center of a 5-1/4 inch flat - I back the fence up until I hit the 2-5/8 field mark on plate. And it is exactly 2-5/8......
Throw that parallel square relationship off...just a bit ....
And it will be off....if I go by my scale....
I don't use a tape measure.....not necessary.....IF my fence is square to the markings on the field plate....which it is. 2-5/8 will be 2-5/8- centered....
Just the way I work.....
B,
Old 06-05-2014, 08:11 PM   #2170
Trade: Construction
If you have tapes on your table that's all well and good but the festool don't nor do many others. It takes 5 seconds to measure from the fence to your bit. If I was changing bits out 20x a day and adjusting for numerous different size boards I would add some of that adhesive tape to the rear of the fence and do it your way. I use router table about 5x a year. Most of the time I use my of1400 with the track or guides.
Old 06-05-2014, 08:18 PM   #2171
Wood Craftsman
Arrow
I'm not knocking anything BC......
As I said ,...we all have our way of doing things....
Peace.....
B,
The Following User Says Thank You to PrestigeR&D For This Useful Post:
BCConstruction (06-05-2014)
Old 06-05-2014, 08:31 PM   #2172
Trade: Construction
I'm not knocking anything BC...... As I said ,...we all have our way of doing things.... Peace.....
Oh no I get ya. Your ways perfectly fine to me.
The Following User Says Thank You to BCConstruction For This Useful Post:
PrestigeR&D (06-05-2014)
Old 06-06-2014, 12:32 PM   #2173
pro
country_huck's Avatar
Trade: Capenter/ Remodeler
Rewards Points: 768
I found the cms system on eBay, many will ship the the states.
What does that cost? How easy is to put the saw in and take it back out, is the router module the same as the one we can buy here?
Nathaniel Huckins (huck)
Facebook
country_huck is offline
Old 06-06-2014, 10:21 PM   #2174
tjbnwi's Avatar
Not sure what it costs to ship the item. I bought mine used from a FOG member for a very good price.
The riving knife has to be changed to use the blade guard. Not hard to change out at all. I have the TS-75 module, I use the 75 less than my 55's, so the 75 used was well worth it to me.
Yes, the module for the router is identical.
One other thing, dust collection is impressive on the CMS 75.
tjbnwi is offline
Old 06-06-2014, 10:25 PM   #2175
tjbnwi's Avatar
It works on plaster also.
Festool fan club thread-image-3622260865.jpg   Festool fan club thread-image-170093318.jpg   Festool fan club thread-image-1400447343.jpg   Festool fan club thread-image-3814167958.jpg   Festool fan club thread-image-398345383.jpg
tjbnwi is offline
Old 06-07-2014, 06:27 AM   #2176
BlueRidgeGreen's Avatar
Trade: Craftsman
Rewards Points: 3,500
Plaster?
I'm always so reluctant to cut dusty, nasty chit with my TS's.
I have a big soapstone job coming up, and I have to build an integrated apron sink.
You would feel comfortable using your 75?
I know they test them by blasting em with Arkansas sand or something, but it all seems so "destructive".
BTW....how do you make your rail levitate on that ceiling?
"Timid men prefer the calm of despotism to the tempestuous sea of liberty". Thomas Jefferson
BlueRidgeGreen is offline
Old 06-07-2014, 06:38 AM   #2177
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,080
Originally Posted by BlueRidgeGreen View Post
Plaster?
What's the point in owning it if you don't use it.
Inner10 is offline
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
jhark123 (06-16-2014), WarnerConstInc. (06-07-2014)
Old 06-07-2014, 06:41 AM   #2178
J.C.'s Avatar
Rewards Points: 162
Plaster?
I've cut a couple slabs of soapstone with my TS55 before and plan on cutting more in the future. I just made sure to have the vac hooked up. The vac kept everything fairly clean but I did give it a final cleaning with an air hose.
I do not prize the word "cheap." It is not a badge of honor...it is a symbol of despair. Cheap prices make for cheap goods; cheap goods make for cheap men; and cheap men make for a cheap country. ~ William McKinley
J.C. is offline
The Following User Says Thank You to J.C. For This Useful Post:
BlueRidgeGreen (06-07-2014)
Old 06-07-2014, 06:45 AM   #2179
Wood Craftsman
Arrow
Well,
I can see where blueridge is coming from. I have 3 CS's . One for junk cutting, one for out in the field and one for the shop , strictly for using on sheet/ply wood material only.
JMPOV,
B,
Old 06-07-2014, 06:53 AM   #2180
tjbnwi's Avatar
Plaster?
Arizona sand (I know---- sad that I know that, supposedly it is the most abrasive sand there is).
I use my tools, if it breaks or wears out, I fix it or buy a new one. They're tools not museum pieces. Not saying abuse them, just use them as you would any other. I cut drywall and cement board with it.
Clean the rail and saw after use. I have 3 TS's so I can pick and choose.
Dust extraction is great the bag does clog up faster. I believe Festool does not sell the cement blades here because we do not get the M dust class CT's here.
I have the cement board blade for the 55 so I would use the 55 on soapstone.
I'm considering having a diamond blade punched to use on concrete.
I used screws in the holes in the ends of the rail. I usually use 2 sided tape, easier to set the rail over head, did not have it with me.
tjbnwi is offline
Jigsaws...Bosch vs Festool jdeck Tools & Equipment 35 02-23-2016 08:43 PM
Fine Finish w/o Festool basswood Finish Carpentry 78 02-04-2013 08:32 AM
festool Planex and cleantex BCConstruction Tools & Equipment 10 05-11-2012 06:56 AM
Finally met Festool! Knighton Finish Carpentry 13 05-15-2010 07:41 AM
Festool john5mt Tools & Equipment 2 04-08-2010 10:16 PM
