Festool Fan Club Thread - Page 103 - Tools & Equipment - Contractor Talk
Old 05-18-2014, 06:54 AM   #2041
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Re: Festool Fan Club Thread
Originally Posted by sancho
Hey bud, How are those jessum guides working for you? Do they replace a feather board? Ive been considering getting them for my CMS
Have not run a lot of material through them but so far so good. I have a feather board for my CMS but these working as a hold down to really save a lot of messing around on the CMS.
www.bcconstructionllc.com
BCConstruction is offline
Old 05-18-2014, 10:40 AM   #2042
Trade: Construction
Getting there. Just need to get a sheet of mdf and get a insert cut to accept the jessem lift.
Old 05-18-2014, 11:18 AM   #2043
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
You ever gonna build something with all this fancy sh!t?
Inner10 is offline
Old 05-18-2014, 12:01 PM   #2044
Trade: Construction
No they are shelf queens lol
Old 05-18-2014, 12:03 PM   #2045
Inner10's Avatar
Have you ever watched p0rn on that big fancy computer of yours?
Inner10 is offline
Old 05-18-2014, 12:13 PM   #2046
Trade: Construction
What a stupid question. Of course I have lol 3 at a time.
The Following User Says Thank You to BCConstruction For This Useful Post:
Inner10 (05-18-2014)
Old 05-18-2014, 12:19 PM   #2047
Inner10's Avatar
My next question was going to be if you ever drove your fancy truck in the rain.
Inner10 is offline
Old 05-18-2014, 12:22 PM   #2048
Trade: Construction
I do but I wash it right after. I used Gtechnic exo v2 on it a while back so its well easy to keep clean now. That stuff stays on for 2 years.
Old 05-21-2014, 10:13 AM   #2049
Trade: Construction
Got it done at last. What a pain in the ass making a template to cut the hole out for the router. But I have tested it a few times already and it works great. The dust extraction is unreal even with the upper guard removed. The jessem material feed guides work great to. Plus I still have use of the table for the kapex do no need to carry around a extra table for the router. It will also function as a jointer too which is nice fir some bits on site I need to straiten up.
Base is 2 pieces of 3/4 ply glued up and with a slight hump in the middle that drops to almost dead flat when the router is installed.
Festool fan club thread-image-416471795.jpg Festool fan club thread-image-1578078180.jpg Festool fan club thread-image-2663990489.jpg
Old 05-21-2014, 12:15 PM   #2050
john5mt's Avatar
Rewards Points: 1,500
What do you figure thay setup cost you?
Remodelling Fool
Helena Siding Windows
https://helenasiding.com/
john5mt is offline
Old 05-21-2014, 03:41 PM   #2051
Trade: Construction
I already had every part sitting around doing nothing except the kreg router supports $19.99 and a sheet of cabinet grade mdf $40.
But if I figured everything there from scratch prob about $1800 for the complete router table setup + the vac.
My goal was to be able to use what I had left over from my CMS-GE but not take anymore room up in the trailer but still have full use of every tool. Its not very often I need a router table on site but now I can set one up in the MFT kapex in mins its handy to have.
Old 05-21-2014, 03:42 PM   #2052
Trade: Construction
Here is it back as a normal table for kapex.
Old 05-21-2014, 07:33 PM   #2053
tjbnwi's Avatar
Rewards Points: 4,006
Next time you have to make a temple around a square use your Kreg jig to join pieces that lace around the square. A top bearing bit follows the inside of the template.
I use a 1/4" bit with 2 top bearings.
tjbnwi is offline
Old 05-21-2014, 07:58 PM   #2054
Trade: Construction
Originally Posted by tjbnwi
Next time you have to make a temple around a square use your Kreg jig to join pieces that lace around the square. A top bearing bit follows the inside of the template. I use a 1/4" bit with 2 top bearings. Tom
I thought about doing that or buying the festool jig kit for $500 as it would be handy to have. I got it to within about a 32nd but I wanted it perfect. My mates currently building a cnc that can fit that size sheet into so next time he's milling it on that lol.
I'm tempted to glue some kind of phenolic sheet over the mdf. Any recommendations on where to purchase some to put over it.
Old 05-21-2014, 07:58 PM   #2055
Tenon Cutter's Avatar
Trade: Timber Framming, Framing and Trim Carpenter
Rewards Points: 80
Does anyone here have any feedback on the Ti15? I just had Acme order one in for me to look at. From what I can see, it's a bad ass impact that is also seemingly larger than my Makita brushless. Also, I'm wondering if the drill setting is as powerfull as I want it to be. Basically, is it both an impact AND and drill, or just an impact that can drill
Any thought appreciated before I drop $560.
Thanks
Tenon Cutter is offline
Old 05-21-2014, 08:01 PM   #2056
Trade: Construction
Originally Posted by Tenon Cutter
Does anyone here have any feedback on the Ti15? I just had Acme order one in for me to look at. From what I can see, it's a bad ass impact that is also seemingly larger than my Makita brushless. Also, I'm wondering if the drill setting is as powerfull as I want it to be. Basically, is it both an impact AND and drill, or just an impact that can drill Any thought appreciated before I drop $560. Thanks
If your gonna ever pick one tool not to buy made but festool that's the one. You won't find hardly anyone who rates it.
chris klee (05-22-2014)
Old 05-21-2014, 08:02 PM   #2057
Rewards Points: 80
Okay. Why is that?
Old 05-21-2014, 08:14 PM   #2058
tjbnwi's Avatar
Being a hybrid, it does not appear to work well for most. I have read posts from some who love the Ti15.
tjbnwi is offline
Old 05-21-2014, 08:17 PM   #2059
Trade: Construction
Okay. Why is that?
It's not really great at being a drill or impact. It's really under powered compared to even a $250 impact or even my 7 year old makita impact. It def has the typical festool quality and feel but falls short on performance by quit a bit. Had over to FOG and check the reviews out. Most are not good. There's even been a couple guys on here buy it then return it.
But test it for 30 days and see how you get on with it. I tried it out and it done what I asked it to but it just didn't do enough for $500+ I bought the cxs and kept my makita drill and impact and I'm gonna add a second cxs because I love it so much.
Old 05-21-2014, 08:35 PM   #2060
Rustbucket's Avatar
Trade: Remodel/Deck
Rewards Points: 1,754
On a side note.... Anyone ever get any of their 35$ tloc iiis from amazon yet? I just got an email saying they're sourcing them again, when I have previous emails that said they should of arrived last week. I wonder what's happening now
My credit card was just charged, and the Amazon site says it's preparing to ship. Fingers crossed!
Rustbucket is offline
Jigsaws...Bosch vs Festool jdeck Tools & Equipment 35 02-23-2016 08:43 PM
Fine Finish w/o Festool basswood Finish Carpentry 78 02-04-2013 08:32 AM
festool Planex and cleantex BCConstruction Tools & Equipment 10 05-11-2012 06:56 AM
Finally met Festool! Knighton Finish Carpentry 13 05-15-2010 07:41 AM
Festool john5mt Tools & Equipment 2 04-08-2010 10:16 PM
