Festool Fan Club Thread - Tools & Equipment - Contractor Talk
Old 04-15-2013, 08:13 PM   #1
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
So here it is. A thread especially for the koolaid drinking fanboyz.
Lets see your Festool setups and projects your using these tools on.
Here's my new toy all setup.
www.bcconstructionllc.com
BCConstruction is offline
The Following 4 Users Say Thank You to BCConstruction For This Useful Post:
Doc Halideigh (01-16-2014), K&K Carpentry (08-30-2013), moorewarner (04-19-2013), steex (06-07-2013)
Old 04-15-2013, 08:19 PM   #2
Tom M's Avatar
Rewards Points: 8,198
Re: Festool Fan Club Thread
Nice!
Tom M is online now
Dave Mac (10-27-2016)
Old 04-15-2013, 08:21 PM   #3
tjbnwi's Avatar
Rewards Points: 1,870
I have a CMS, just the "yankee" version. I want the saw insert, I think we need to talk.
Made this using just a Domino, Kapex and OF 1400 off this one jig.
tjbnwi is online now
The Following 3 Users Say Thank You to tjbnwi For This Useful Post:
BCConstruction (04-15-2013), Dave Mac (10-27-2016), moorewarner (04-19-2013)
Old 04-15-2013, 08:25 PM   #4
skillman's Avatar
Rewards Points: 1,968
You may need some help . . They have places for people like you .
skillman is offline
The Following User Says Thank You to skillman For This Useful Post:
Old 04-15-2013, 08:25 PM   #5
tjbnwi's Avatar
Made these, TS 55, Kapex and Domino.
Festool fan club thread-img_1426.jpg   Festool fan club thread-img_1510.jpg   Festool fan club thread-img_1407.jpg
CITY DECKS INC (04-15-2016), Dave Mac (10-27-2016), moorewarner (04-19-2013)
Old 04-15-2013, 08:32 PM   #6
Trade: Construction
Tom how did you curve that top like that?
The Following User Says Thank You to BCConstruction For This Useful Post:
Old 04-15-2013, 08:48 PM   #7
Joseph A. Capece
CENTERLINE MV's Avatar
Trade: Builder - General
Rewards Points: 1,432
...loads of grinding, sanding, and hand planing is my guess...
Follow us on FACEBOOK
www.centerlinebuilders.net
Martha's Vineyard General Contractors - Builders -
Commercial/Residential - Additions - Renovations
CENTERLINE MV is offline
The Following User Says Thank You to CENTERLINE MV For This Useful Post:
Old 04-15-2013, 09:11 PM   #8
tjbnwi's Avatar
Thanks for reminding me, MFT 3 and RO 125 were also used------- to curve the top.
Using the rail on the MFT and 1400 with a 3/4" bit, I started in the center of the seat plunged 10 mm, moved seat 3/4" plunged 9.5 mm, moved seat 3/4" plunged 9 mm. Nine plunges each direction 0.5 mm height adjustment each plunge. Did the upper of the seat first, so when I flipped it to do the bottom it was nested on the ends. Another 18 plunges, shaped with the 125. Easier to do than type.
The only things holding this together are glue and dominos. There are 12 in each leg at the bow tie. I had to make some 3" dominos to retain the top and go through the bow tie tying the legs together. There are 12 dominos in each leg at the bow tie.
Here are the dominos through the top 3" long quarter sawn white oak.
Old 04-15-2013, 09:15 PM   #9
skillman's Avatar
Wouldn't a table saw be better than that put together made one with circular saw . Just seems a little to gimmicky for my likening .
skillman is offline
The Following 5 Users Say Thank You to skillman For This Useful Post:
Calidecks (04-16-2013), Cole82 (04-16-2013), Dave Mac (10-27-2016), donerightwyo (04-15-2013), jkfox624 (06-02-2013)
Old 04-15-2013, 09:19 PM   #10
tjbnwi's Avatar
How not to raise a panel;
Old 04-15-2013, 09:20 PM   #11
tjbnwi's Avatar
How to fix raised panel;
Festool fan club thread-img_0079.jpg   Festool fan club thread-img_0081.jpg   Festool fan club thread-img_0083.jpg
Old 04-15-2013, 09:39 PM   #12
Trade: Construction
Yes and no. Depends what you want from it. I don't use my table saw to cut thick material or large sheets so no need for a big table saw. This setup kills 2 birds with one stone. It's a router table and saw. It has built in legs so no need to carry a stand around so frees up my mft that i use for a stand with my current saw and it uses tools I currently already have. Space is at a premium in my trailer so having tools like this saves on weight and space. I can also use my UG stands and MFT's if I'm running. Longer material though the saw. it's a light weight setup as well which is nice when you carrying it through a house.
The Following 3 Users Say Thank You to BCConstruction For This Useful Post:
CarpenterSFO (04-15-2013), Dave Mac (10-27-2016), moorewarner (04-19-2013)
Old 04-15-2013, 09:51 PM   #13
skillman's Avatar
What does that cost as set up
With out saw .
skillman is offline
Old 04-15-2013, 10:06 PM   #14
Dirtywhiteboy's Avatar
Rewards Points: 13,122
Dirtywhiteboy is online now
Old 04-15-2013, 10:09 PM   #15
bmcquin's Avatar
Trade: deck builder
Rewards Points: 1,646
BCC,
I wonder if Makita makes something like that...................
Just kidding! LOL
bmcquin is offline
The Following 2 Users Say Thank You to bmcquin For This Useful Post:
asevereid (04-15-2013), Dave Mac (10-27-2016)
Old 04-15-2013, 10:22 PM   #16
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,746
The cost is a lot. Wrap up a couple g's in it I suppose.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
Old 04-15-2013, 10:31 PM   #17
skillman's Avatar
That's just crazy for that . I can buy a lot of dew with that . . Do the dew . I think if I stopped drinking so much maybe I could get a setup of festool tools . At least drink 3 12 oz bottles a day.
skillman is offline
Old 04-15-2013, 10:33 PM   #18
President of the world
world llc's Avatar
Trade: general contractor
Rewards Points: 2,001
i'll take my place here on page 1...
how did you get the table mod over here?
world llc is offline
The Following 2 Users Say Thank You to world llc For This Useful Post:
Old 04-15-2013, 10:34 PM   #19
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,074
Now c'mon guys don't start any arguments in this thread just play by the following rules:
Inner10 is offline
The Following 4 Users Say Thank You to Inner10 For This Useful Post:
aptpupil (04-15-2013), Dave Mac (10-27-2016), ICBuilds (07-03-2013), moorewarner (04-19-2013)
Old 04-15-2013, 10:34 PM   #20
skillman's Avatar
That's just wrong man .
skillman is offline
Jigsaws...Bosch vs Festool jdeck Tools & Equipment 35 02-23-2016 08:43 PM
Fine Finish w/o Festool basswood Finish Carpentry 78 02-04-2013 08:32 AM
festool Planex and cleantex BCConstruction Tools & Equipment 10 05-11-2012 06:56 AM
Finally met Festool! Knighton Finish Carpentry 13 05-15-2010 07:41 AM
Festool john5mt Tools & Equipment 2 04-08-2010 10:16 PM
