-   Tools & Equipment (https://www.contractortalk.com/f40/)
-   -   Festool fan club thread (https://www.contractortalk.com/f40/festool-fan-club-thread-133655/)
BCConstruction 04-15-2013 08:13 PM
10 Attachment(s)
So here it is. A thread especially for the koolaid drinking fanboyz.
Lets see your Festool setups and projects your using these tools on.
Here's my new toy all setup.
Attachment 90473
Attachment 90474
Attachment 90475
Attachment 90477
Attachment 90476
Attachment 90478
Attachment 90479
Attachment 90480
Attachment 90481
Attachment 90482
Tom M 04-15-2013 08:19 PM
Nice!
tjbnwi 04-15-2013 08:21 PM
842 Attachment(s)
I have a CMS, just the "yankee" version. I want the saw insert, I think we need to talk.
Made this using just a Domino, Kapex and OF 1400 off this one jig.
skillman 04-15-2013 08:25 PM
You may need some help . . They have places for people like you .
tjbnwi 04-15-2013 08:25 PM
842 Attachment(s)
Made these, TS 55, Kapex and Domino.
BCConstruction 04-15-2013 08:32 PM
Tom how did you curve that top like that?
CENTERLINE MV 04-15-2013 08:48 PM
...loads of grinding, sanding, and hand planing is my guess...
tjbnwi 04-15-2013 09:11 PM
842 Attachment(s)
Thanks for reminding me, MFT 3 and RO 125 were also used------- to curve the top.
Using the rail on the MFT and 1400 with a 3/4" bit, I started in the center of the seat plunged 10 mm, moved seat 3/4" plunged 9.5 mm, moved seat 3/4" plunged 9 mm. Nine plunges each direction 0.5 mm height adjustment each plunge. Did the upper of the seat first, so when I flipped it to do the bottom it was nested on the ends. Another 18 plunges, shaped with the 125. Easier to do than type.
The only things holding this together are glue and dominos. There are 12 in each leg at the bow tie. I had to make some 3" dominos to retain the top and go through the bow tie tying the legs together. There are 12 dominos in each leg at the bow tie.
Here are the dominos through the top 3" long quarter sawn white oak.
skillman 04-15-2013 09:15 PM
Wouldn't a table saw be better than that put together made one with circular saw . Just seems a little to gimmicky for my likening .
tjbnwi 04-15-2013 09:19 PM
842 Attachment(s)
How not to raise a panel;
tjbnwi 04-15-2013 09:20 PM
842 Attachment(s)
How to fix raised panel;
BCConstruction 04-15-2013 09:39 PM
Yes and no. Depends what you want from it. I don't use my table saw to cut thick material or large sheets so no need for a big table saw. This setup kills 2 birds with one stone. It's a router table and saw. It has built in legs so no need to carry a stand around so frees up my mft that i use for a stand with my current saw and it uses tools I currently already have. Space is at a premium in my trailer so having tools like this saves on weight and space. I can also use my UG stands and MFT's if I'm running. Longer material though the saw. it's a light weight setup as well which is nice when you carrying it through a house.
skillman 04-15-2013 09:51 PM
What does that cost as set up
With out saw .
Dirtywhiteboy 04-15-2013 10:06 PM
:ninja:
................................................. :glare:
,,,,,,,,,,,,,,,,,,,,,,,:wacko:
bmcquin 04-15-2013 10:09 PM
BCC,
I wonder if Makita makes something like that...................
Just kidding! LOL :clap::clap::clap::clap:
WarnerConstInc. 04-15-2013 10:22 PM
The cost is a lot. Wrap up a couple g's in it I suppose.
skillman 04-15-2013 10:31 PM
That's just crazy for that . I can buy a lot of dew with that . . Do the dew . I think if I stopped drinking so much maybe I could get a setup of festool tools . At least drink 3 12 oz bottles a day.
world llc 04-15-2013 10:33 PM
i'll take my place here on page 1...
how did you get the table mod over here?
Inner10 04-15-2013 10:34 PM
Now c'mon guys don't start any arguments in this thread just play by the following rules:
http://img863.imageshack.us/img863/3121/ruler.jpg
skillman 04-15-2013 10:34 PM
That's just wrong man .
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
