Festool Cleaning Kit.. - Tools & Equipment - Contractor Talk
Thread Tools
Old 03-10-2013, 04:12 PM
Repair & Renovation
Rich D.'s Avatar
Trade: R. Damato Construction
Rewards Points: 2,598
Hey guys.. as some of you may know i just got a ct 36 ac extractor.. i want to compliment it with a cleaning kit i can attach to the hose dock..
My question is, is the festool compact cleaning kit compatible with the 36mm hose the AC comes with? Its listed as 36mm attachment but i heard it only works with the smaller diameter hose..
http://www.festoolproducts.com/Festo...a-p/497697.htm
“The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
Rich D. is offline
Old 03-10-2013, 05:04 PM
WilsonRMDL's Avatar
Trade: Carpenter/Remodeler
Rewards Points: 532
Re: Festool Cleaning Kit..
I think the 36mm hose fits over the attachments, the 27mm goes inside. Check out the forums at festoolownersgroup to get more info
I have the midi and the smaller hose fits inside the attachments, that's where I came up with that
Innovative Remodeling LLC
Licensed and Insured
WilsonRMDL is offline
Old 03-10-2013, 05:16 PM
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Rich if i remember correctly that kit will work with both hoses but not the planex hose.
www.bcconstructionllc.com
BCConstruction is offline
Old 03-10-2013, 06:09 PM
Five Star's Avatar
Rewards Points: 1,010
I got the installers kit, it comes with a 36 m hose, its got the metal vac ext accerories
The Bitterness of Poor Quality Remains longer
Than The Sweetness Of A Low Price Is Forgotten
Five Star is offline
Old 03-10-2013, 07:11 PM
Repair & Renovation
Rich D.'s Avatar
If the 36mm fits over the attachment, the planex hose should work with it. Shane from festool told me the 36mm planex hose will work with my ts 55..
Rich D. is offline
Old 03-10-2013, 07:17 PM
Trade: Construction
Yep the planex hose only works with tools where the hose is the female not the male end. But that kit looks like it is a female fitting for the one. Post some bigger pics of it.
Old 03-10-2013, 07:26 PM
tjbnwi's Avatar
Rewards Points: 2,866
The Planex hose WILL NOT fit the Compact Cleaning set or any other set where the hose is the male and the wand is female. It will work when the hose is the female and the wand is the male.
The Compact Cleaning set will work with a standard 36 mm hose.
tjbnwi is online now
Old 03-10-2013, 07:28 PM
T-Hussy's Avatar
Rewards Points: 134
The compact kit is kinda weak. I started with the compact kit but returned it and got the installers kit instead - worth every dollar if you will be using it regularly. The plastic pieces in the compact kit would not hold up to everyday work and are not suited to picking up anything more than sawdust. Also, after just a few uses, the plastic was caking up with drywall dust.
T-Hussy is offline
Old 03-10-2013, 07:41 PM
Repair & Renovation
Rich D.'s Avatar
Ok so I'm guessing the planex hose won't work with any cleaning kit? I just didn't want to get a kit that included a hose since I already have the planex hose..
But is it true that the small hose fits inside the cleaning wand and the large 36mm hose fits on the outside? If that's the case the planex hose will work with the compact kit..
Rich D. is offline
Old 03-10-2013, 08:32 PM
tjbnwi's Avatar
I believe the only kit that does not include the hose is the Compact. If you really want to use the hose with the Compact set, you can cut the bell off the hose end of the bend section of the wand. The hose will then slip over the wand hand piece. The hand tools slip into he hose without modification.
I've had my Compact set for 4 years. It's done well for me.
Thread Tools
Rate This Thread
IM ABOUT TO DO IT!!! festool planex. Rich D. Tools & Equipment 97 05-15-2013 05:45 AM
Unboxing festool CMS BCConstruction Tools & Equipment 11 10-17-2012 08:24 PM
Festool 494369 crown stops for kapex BCConstruction Contractor Swap 4 10-02-2012 09:37 AM
PROOF that cleaning ladies don't know how to clean wood floors lawndart Flooring 4 09-20-2012 07:46 PM
Pressure Washing & Window Cleaning Tips Jas2012 New Member Introductions 13 08-14-2012 05:22 PM
