Easier Way To Mark Tools In Case Of Theft? - Tools & Equipment - Contractor Talk
Old 12-26-2018, 11:32 AM   #1
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 1,709
I'm updating a spreadsheet with tools and serial numbers in case I get my tools stolen again.
I'm trying to etch my drivers license number on everything with a dremel. It's slow and tedious. My DL number is 12 freaking digits.
The only helpful thing the detective offered after the last break in was that street cops are trained to look for markings. A street cop can't run serial numbers if he stops a car full of suspected stolen tools. (or won't bother) But, if it has a drivers license number in the same format he is accustomed to seeing its much more likely the tools are recovered and returned.
I'm wondering if there is a better permanent way than a dremel to mark everything? I have a set of metal punches but that won't work on power tools.
I can get a custom branding stamp from Amazon for about 50 bucks. Think I could carefully brand all my tools on the plastic housings and the batteries?
The gunsmith at my range uses a $3500 laser engraver. Any of you fellas have a better method?
WBailey1041 is offline
Old 12-26-2018, 07:10 PM   #2
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,740
Re: Easier Way To Mark Tools In Case Of Theft?
Dont have anything to add but i am subscribing to this for ideas
Obviously any sort of paint or marker could easily be removed with a shot of brake cleaner so I would think the best bet would be to branding the plastic with hot numbers like i think you are suggesting
Something like this maybe? Try searching for a Branding iron
https://brandingirons.com/collections/plastic
Windycity is online now
The Following User Says Thank You to Windycity For This Useful Post:
WBailey1041 (12-31-2018)
Old 12-26-2018, 09:56 PM   #3
Windycity's Avatar
Trade: Masonry
Doing a little research they do have electric branding irons with heads that have interchangeable letters and numbers in various sizes from 3/16 inch up to whatever. I think this is kind a neat because it would be a nice clean hot stamp of whatever info you wanted on your tools and batteries
The irons are not too bad pricewise however you have to buy each individual letter or number and there about 20 bucks apiece which would add up a little
But I do like the fact that you can plug it in, wait till it heats up and brand away as opposed to fooling with scribing individual letters/numbers or holding a flame to it to heat it up
Old 12-26-2018, 10:05 PM   #4
Lettusbee's Avatar
Rewards Points: 1,506
How is a branding iron gonna work on a little room that has mostly round surfaces. Sanders, drills, routers. What do you do for your metal tools?
Also, I'd think having your DL# on your tools is almost as bad as posting your ss# on everything.
Not that I have any better ideas.
I just photograph every tool, including making sure serial #s are legible in the pictures. That along with the spreadsheet. May not help as much with recovery, but will help with insurance
Lettusbee is online now
The Following User Says Thank You to Lettusbee For This Useful Post:
KAP (12-30-2018)
Old 12-27-2018, 11:33 AM   #5
Dan_Watson's Avatar
Rewards Points: 2,748
FWIS - When our trailers were recovered, the cops started calling the phone numbers on the stolen tools. I received a few calls from different officers as they found tools throughout the property.
Dan_Watson is offline
The Following 3 Users Say Thank You to Dan_Watson For This Useful Post:
AustinDB (12-30-2018), Calidecks (12-27-2018), KAP (12-30-2018)
Old 12-30-2018, 07:29 PM   #6
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
I use an old vintage craftsman engraving pen...have owned it forever...marks anything, plastic, metal etc...
supersealconstruction.com
superseal is offline
Old 12-30-2018, 10:47 PM   #7
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,958
Once a drivers license has expired can your old number still be run?
I was told by a police officer friend the tool serial number can be entered into a data base and if you have reported it stolen it will then come back to you. BUT, that is not done by street officers but more likely by the officers investigating thefts etc. takes time no doubt. He also said it is amazing how many times people reporting stolen items can not produce the serial number.
I wonder how many stolen tools are found by on the spot checking by street officers vs those that turn up after investigations for other crimes? therefore i question the value of any marking beyond recording the serial number.
I record serial numbers of my more expensive tools, but could do better.
Ohio painter is offline
Old 12-30-2018, 10:55 PM   #8
Lettusbee's Avatar
I've had the same DL# since I was 16.
tgeb (12-31-2018)
Old 12-30-2018, 11:35 PM   #9
GC/carpenter
Calidecks's Avatar
Rewards Points: 9,118
In this state you will only have one license number for the rest of your life, regardless of its status.
Mike.
_______________
Calidecks is online now
griz (12-30-2018)
Old 12-31-2018, 02:12 AM   #10
Trade: Gutters
Mike.
_______________
True In all but 5 states.
The Driver License Compact is an interstate compact used by States of the United States to exchange information concerning license suspensions and traffic violations of non-residents and forward them to the state where they are licensed known as the home state. Its theme is One Driver, One License, One Record. The home state would treat the offense as if it had been committed at home, applying home state laws to the out-of-state offense. The action taken would include, but not be limited to, points assessed on a minor offense such as speeding and suspension of license or a major violation such as DWI/DUI. It is not supposed to include non-moving violations like parking tickets, tinted windows, loud exhaust, etc.
Old 12-31-2018, 02:16 AM   #11
Trade: Gutters
20 bucks a letter? Can I buy a vowel? Iíll borrow against the house
Did you see the image in my original post? I think thatís the electric branding iron...?
Old 12-31-2018, 02:33 AM   #12
Trade: Gutters
You are 100% correct about insurance. See my old thread linked above. I got questioned on my spreadsheet until I sent screen shots of purchases from eBay, amazon and Hdepot. Erie insurance still doubted my claim. When I sent pictures of new tools and pictures of jobs that showed some of the tools they changed their tune. They overnighted payment which was more than 25% of my coverage limit. One of the few times Iíve come out ahead after telling the complete truth, I didnít pad the numbers.
Old 12-31-2018, 09:41 AM   #13
Windycity's Avatar
Trade: Masonry
My dad told me that before that law or whatever agreement he had several truck driver friends back in the 60s that have numerous drivers licensees from different states.....one state suspends your license it was no biggie since they could keep on trucking....i think they would be ďhiddenĒ from arrest warrants as well by having different licenses since it wouldnít show up on traffic stops. They would just avoid going through the state where the warrant was issued
People used to get away with so much back then
20 bucks a letter? Can I buy a vowel? Iíll borrow against the house:
Yes you can but vanna white isnt going to get it for you....lol
Old 01-01-2019, 08:26 AM   #14
RichVT's Avatar
Rewards Points: 1,255
A neighbor had some tools stolen. He said that the thieves didn't touch anything that was marked.
A large, obvious marking will also help prevent another worker on the job site from "accidentally" thinking that your tool is theirs.
RichVT is offline
Old 01-01-2019, 08:37 AM   #15
Joasis's Avatar
Rewards Points: 1,786
You can buy a set of number/letter stamps...and we used to heat them and then stamp a few places on the cordless tools and cases....and on laser bodies and detectors....etc. Then model paint and wipe off.
Everyone paints their batteries a different color of rattle can paint....
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
Old 01-01-2019, 08:37 AM   #16
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Someone pull the trigger on the branding iron because I like this idea and want to know if it works.
Inner10 is offline
Old 01-01-2019, 12:58 PM   #17
Windycity's Avatar
Trade: Masonry
LOL i agree, i think wbailey should pull the trigger so we can see how well it works!
I did some work at a factory where they had serial numbers nicely etched into their powertools and i was wondering how they did it, obviously they used a branding iron since most etchings i see look like an etch-a-sketch was used and these numbers were nice looking
Old 01-01-2019, 05:35 PM   #18
META's Avatar
Trade: General and Trades
Rewards Points: 7,142
Replacement value insurance and a photo log of all tools along with their model and serial numbers as was mentioned.
Funny, though. I had a $10k claim about 6 years ago. It took me months to recover the loss even though I had replacement value insurance...thankfully. I ended up solving my own case, though, by visiting a pawn shop about 20 minutes away and identifying tools that I had painted hot pink.
It is amazing what people will risk and do for $40 dollars from a pawn shop.....
META is offline
Old 01-01-2019, 06:11 PM   #19
Jonbuild's Avatar
Trade: Log home builder
Rewards Points: 492
I have an electric branding iron, that I have the letters I & J on it (I & J is my business name) Iíve marked a few of my batteries, you need to be careful on plastic it will kinda smear if you set it on to long, I just havenít got around to doing all my tools yet, it wonít brand on metal but most tools have plastic on them somewhere.
I canít remember if I got it from woodcraft or Rockler but it the one where you have to special order and only can fit three letters
Sent from my iPad using Tapatalk
Jonbuild is offline
Old 01-01-2019, 08:40 PM   #20
KAP's Avatar
Trade: Custom
Rewards Points: 39,906
Put a sign on the door of your trailer...
"All equipment/contents are recorded and registered for recovery/tracking purposes by law enforcement. Premises and interior of trailer is under wireless video surveillance. Violators will be recorded real-time and prosecuted to the fullest extent of the law".
Then install a flood light that automatically shines when they open the door... and a fake code keypad...
If they want your stuff, there's nothing going to stop them from taking it, so deterrence is about all you can hang your hat on (and insurance...) and hope they pick a target with less risk...
With the advent of cellular/wireless systems, be on the watch for alarm companies to begin marketing these type of solutions more...
KAP is offline
Dewalt tools Michaeljp86 Tools & Equipment 86 02-07-2015 02:14 AM
Mark Andrews - The 2nd (Business Growth Expert) MarkAndrews (2) New Member Introductions 1 04-08-2013 05:20 AM
Don't forget about Dremel tools MarcP Finish Carpentry 8 01-30-2013 05:26 PM
Premium tools...worth it (warning, long post) samthedog General Discussion 25 12-31-2011 06:57 AM
Ipad Otterbox Defender case review BCConstruction Technology 1 07-13-2010 08:04 PM
