Dust Extractors, HEPA Or Not? - Tools & Equipment - Contractor Talk
Old 11-14-2016, 09:43 PM   #1
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,052
Finally looking to pick up a dust extractor to comply with the new OSHA silica requirement and cant decide if I should get a HEPA vac or not. 99% of my work will be outside and will mostly be used for tuckpoint grinding and concrete saw collection so it will be ALOT of brick dust. I read that OSHA dropped the hepa requirement and i dont do lead rrp removal so thats not an issue. My concern is the cost of the hepa filter and the expensive hepa vac getting beat up on the job with my bonehead eh i mean highly valued employees. I was looking at the dustless technologies line of vacuums since i can get their wonderbags locally at Home Depot and they offer both non hepa and hepa dust extractors. Of coarse the non hepa is significantly less so i wont be so worried about it getting abused being outside especially around scaffolding with stuff being dropped on it.
What are your thoughts? Is a hepa vac really necessary for my case? Or is it an unnecessary expense?
Windycity is online now
Old 11-14-2016, 10:40 PM   #2
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
Re: Dust Extractors, HEPA Or Not?
About how many pounds a week do you guess you will collect if you were to capture 95% of the dust you make?
Do you run a tuck point grinder 5 hours a week? Daily? once a month but then for 6+hours?
Based on your answer to these questions we can give you a better idea of what tooling may serve you best.
charimon is offline
Old 11-15-2016, 04:48 PM   #3
Windycity's Avatar
Trade: Masonry
Pounds per week? I would have no idea! Some weeks i would use it alot, 4-5 hours a day and other weeks it wouldn't leave the truck.
Usually i would use it for 1 grinder maybe 2 and occasionally use it for my concrete saw when i dont want to deal with the water
At most probably a bag of dust a week
Old 11-15-2016, 07:21 PM   #4
charimon's Avatar
I would look at the following from cheapest to most expensive from cheap and easy to awesome.
4 Gal Ridgid and a dust deputy (Use bags in Vac) ~$250
Festool Midi and a dust deputy (Use bags in Vac)~$650
Ermator S13 ~$1600
The The Ermator is an industrial Vac designed for tuck pointing applications. Bagging and disposal is super easy and clean. It can be split and hung from the side rail on a scaffold. I have an S26 that has 700+ hours on the meter and is still going strong.
charimon is offline
The Following User Says Thank You to charimon For This Useful Post:
TNTRenovate (12-12-2016)
Old 11-22-2016, 02:34 PM   #5
madmax718's Avatar
Trade: General
Rewards Points: 3,272
its more than just a vac. Its also a time and duration factor. I hope its not brick dust and its mortar dust.
There is nothing wrong with getting a HEPA- but they often flow less. If you do tuck pointing, a vortex add on such as the dust deputy will pay for it self in short time.
I pretty much prefer bags whenever I can, and have found that very little dust gets past the paper filter. My Ridgid HEPA vac runs this way- paper bag, cloth pre filter, then the hepa filter.
it does NOT have as much suction as an identical sized vac (Ridgid or otherwise). So you trade off some performance for the filtration.
I've had very good luck with the Wunderbags.
madmax718 is offline
Old 12-12-2016, 06:03 PM   #6
GC/carpenter
Calidecks's Avatar
Rewards Points: 18,606
This things a beast!
http://www.acmetools.com/shop/tools/...HO4aAtY68P8HAQ
Calidecks is online now
Dan_Watson (12-12-2016)
Old 12-12-2016, 06:17 PM   #7
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 4,108
Originally Posted by Californiadecks View Post
I believe that is a Starmix rebadge.
Inner10 is offline
Calidecks (12-12-2016)
Accessories for Festool Dust extractors CrpntrFrk Tools & Equipment 10 05-09-2016 05:43 AM
7" angle grinder dust control platinumLLC Flooring 8 12-09-2014 08:47 PM
8X8 PT with sand dust foundation steps Red Dog Solar Landscaping 1 01-20-2013 03:52 PM
Simple multi dust extraction set ups Roofcheck Carpentry 2 01-19-2013 11:56 PM
Dust extractors Mike- Tools & Equipment 6 08-21-2011 11:45 AM
